Post here if you've sent your knife to Golden
Django
Post by Django »
Just wanted to see how many people actually send their knives in, and why?
Avatar courtesy of diAlex
TheKnifeCollector
Post by TheKnifeCollector »
I had an SS Police that I sent in because I snapped off the tip at work. I was working night security. And I was assisting in closing a store. Well the person that locked the dorr, snapped off the key in the lock. I used my knife to get the piece of key out. But, it sacrficied the tip. So, I sent it in.
"He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion."
BlackNinja
Post by BlackNinja »
I sent my CF Millie in because of the lock. It was returned about a month later with the lock engaging properly. I was very pleased with the service. If I have a problem with another :spyder: , I will not hesitate to send that one in.
Let your opponent graze your skin and you smash into his flesh;
Let him smash into your flesh and you fracture his bones;
Let him fracture your bones and you take his life!
-Bruce Lee-
-Joe
Ted
Post by Ted »
two - for sharpening
Woody
Post by Woody »
I sent a large and small Dyad in a year or so ago for striped screws... Out come was far beyond what I expected.... Amanda rocks.... :D Turn around was about 3 weeks or so...
BTW......... Did I mention Amanda rocks........ :cool:
Easer to ask for forgiveness than permission…. :p
4077th
Post by 4077th »
I sent a Police Model in and was well taken care of. I also sent a C55 Starmate in once for eccentric pivot adjustment. Not such a great experience. I later learned that the W&R department was going through changes at that time. I've since learned how to adjust Spyderco's eccentric pivots myself.
I have owned three factory re-tipped knives and they were all flawlessly done. If I ever snap a tip off, I know the folks in Golden are highly skilled in that area.
boxer93
Post by boxer93 »
I've sent:
BFC Native - tip regrind and sharpen.
Mili - tip regrind.
UKPK - hard to open. Looked like washer was jammed in pivot.
All came back in great shape.
I have also received a Q clip in the mail for replacement.
Chris
Be Excellent to each other.
BOK
Post by BOK »
Gunting drone for warranty work. Lock engagement problem.
bowarrow2000
Post by bowarrow2000 »
Para Military returned to Golden in Jan 06. Had a little problem with the lock and closing was rather stiff. REturned about 3 weeks later in perfect condition. This was my second Para.
gull wing
Post by gull wing »
Just two out of the many Spydercos I own.
Jonny8642
Post by Jonny8642 »
Last month picked up my delica 3 SE from sharnening and tip repair. My friend's delica 3 CE for sharpening and action repair. and one of the black belts from my tae Kwon-do class pro-grip needed to be sharpened and cleaned. Basicly when any of my friends need to have their :spyder: repaired for some reason they usually call me. I don't know if thats a good thing or a bad thing. :rolleyes: :D
Outlaw
Post by Outlaw »
I've sent in a number of knives over the years for sharpening, then I finally got a Sharpmaker. ;)
The latest I sent off was a Gray Calypso Jr. It had this really weird dodo type grind at the tip, right out-of-the-box so....
I used the knife 'till it was dull, then dulled it some more at work cutting fiberglass :eek: before sending it off. It came back with a new super nice (read even) grind! :D
Michael Cook
Post by Michael Cook »
:spyder: My blue dodo went into the shop for lock repair. It came back tuned and rock solid. :spyder:
More of what does not work will not work. Robin Cooper, Rokudan; Aikikai.
There is great power in the profound observation of the obvious. John Stone, Rokudan; Aikikai
ghostrider
Post by ghostrider »
I sent back my Crossbill’s PE and CE for a sharpening/re-grind. Both knives came with an uneven grind. The CE even had a one serration that was 40 degrees while the others were 30 degrees. After numerous hours on the diamond rods, I decided it was taking too long to put a decent bevel on them, and contacted W & R.
I can’t be certain about the time frame, but I think it was between 4-6 weeks when I got them back. Unfortunately, all they appeared to do was sharpen them at 40 degrees. Amanda explained to me that the byrd steel couldn’t handle the 30 degree angle, and that was the cause of the problem. She also told me that the byrd steel couldn’t get as sharp as the VG-10. Because they didn’t do anything about the uneven grind, there was no real improvement over when I sent them in. Actually worse since the CE is chisel ground at 30-40 degrees inclusive, and since they sharpened it at 40 degree inclusive, it now appeared to have a 50 degree angle on it, and the serrations were more rounded than before.
I resigned myself that I would have to solve the problem myself (and did), although the CE still has one serration at 40 degrees.
[INDENT]
Thread for tying tips:
Avatar provided by DAYWALKER
Post by The Deacon »
Sent them a Rainbow Spyderfly that had one very stiff pivot. Got it back a few weeks later, perfect.
Blades
Post by Blades »
I tried to get a clip for a ltwt Goddard, but they gave me an 800 number for the Spydie store. I haven't got around to calling, I'm worried it is going to cost money to get a new clip.
I have sent knives in for lock failure(Police, new Police was sent back to me), and a resharpen on my Delica(excellent job).
Blades
ghostrider
Blades wrote:I tried to get a clip for a ltwt Goddard, but they gave me an 800 number for the Spydie store. I haven't got around to calling, I'm worried it is going to cost money to get a new clip.
Blades
Clips don't cost very much, but since the model is discontinued you shouldn't put it off.
[INDENT]
bigcat
Post by bigcat »
Its been about a year ago. Sent 9(nine) knives in for grips, clips, and sharpening. They did a great job.
BigCat
"The Power that made the body, Heals the body."
greencobra
Post by greencobra »
Sent a Persian in because the blade was not centered and rubbed on the liner. Got a replacement back.
Avatar by Dialex
Peter1960
Post by Peter1960 »
I've to claim only 2 spydies from >50; but we in Europa first send it back to our traders and only in special cases to Golden:
Delica FRN - strong blade play
Kopa Evrina - bad factory sharpening
Both were replaced :)
I claimed a 3rd one (Persian), but this was my misunderstanding/fault :o
Spyderco's company motto
