I've seen two different designations for the black Cara Cara and Meadowlark on several sites. In one cases, the same site offers both designations. Using the partial serrated black Cara Cara as an example, the two designations are:
BY03BKPSCP
By03BKPS.
When I received my first partial-serrated black Cara Cara, it had the designation BY03BKPSCP and was a powder-coated knife.
I'm wondering if this new designation, BY03BKPS, represents a black oxide finish rather than the powder coat? Sal or Kristi - please adise.
Thanks - Joe
Byrd Question
- The Deacon
I'd be inclined to bet that the CP on the end indicates Clam Pack, as it does with several Spyderco models. Some dealers prefer that packaging to reduce the risk of pilferage when using a self-service display. Assuming that's the case, then the BY03BKPS version is packed in a conventional cardboard box.
Deacon,The Deacon wrote:I'd be inclined to bet that the CP on the end indicates Clam Pack, as it does with several Spyderco models. Some dealers prefer that packaging to reduce the risk of pilferage when using a self-service display. Assuming that's the case, then the BY03BKPS version is packed in a conventional cardboard box.
You are absolutely correct!
Kristi
I really would like to know about Starling too. What kind of steel will this small knife made of?Joe Wright wrote:Hi Kristi & Deacon,
Thanks very much for your reply and help.
Kristi, any word on when we might see the Starling (or any other new Byrds)?
Thanks again - Joe
The Sharpest thing you need to have is your mind.
- smcfalls13
I would assume the same as the other Byrds the 8Cr13something or other.surawut wrote:I really would like to know about Starling too. What kind of steel will this small knife made of?
Sorry, can't ever remember exactly what it is. :o
:spyder: Scott :spyder:
"We make a living by what we get, we make a life by what we give."
-Sir Winston Churchill-
Do you know where will Starling produced? From the SHOT show report by Doug Ritter, he mentioned that this Starling will produce by Spyderco itself but will put it in Byrd line.
So I am not sure where it will be produced.
- smcfalls13
