knife oil
testmonket
knife oil
Forgive the question if it has been answered elsewhere... I couldn't find it in a web search....
What is the recommended oil for spyderco knives? Is there any variation between lock types, handle material, or usage? Any tips or info I should know?
Thanks!
Andrew
Thanks!
Andrew
well, I use either tuf glide or militec. I think it depends on the washer which varies from modle to modle. I like to give all of my lockbacks at least a militec treatment to lube the lock bar against the "tang". After that it depends. For me, the paramilie works better with tuf glide than militec, so does the calypso jr. However militec worked better on my native and on my meerkat.
Tuf glide will work pretty well on most knives, and militec wont do such a great job on some, since its designed for metal on metal contact. Despite this it really likes my native which is strange since there are no liners. As for the paramil, i think its plastic washers so I dont get a metal to metal contact.
I usually have to experiment to see what works.
Agreement but.......
I agree with the Militec because it is good stuff. I also like Break Free for all around lubrication of deep moving parts like that of lockback knives. I also like Ballistol for overall clean up.
:spyder:
- Stormdrane
- Simple Man
- Michael Cook
- TheMikeOfSteel
- Stormdrane
Militec is a fine lubricant and rust preventative especially on firearms, but in my experience, it seems to attract dust and pocket lint when I have used it on my knives, mostly in the pivot area where you can't easily clean up excess after lubrication. If they made Militec in barbecue flavor I probably woudn't mind the taste, but when camping and backpacking I do use my knives in food prep and prefer to taste the food not the lube. Tuf-Glide dries and leaves no residue or taste, that's why I prefer it or Inox. White Lightning is also supposed to be good, though I haven't tried it yet. If you had to, you could even use vegetable, peanut or olive oil as a lubricant/rust preventative, just don't forget it's a knife instead of a spoon and lick it off
Try explaining stitches in your tongue. So, try what's out there and see what works best for you.
Winston Wolf
