Page 1 of 2
Cleaning Tri-Angle Sharpmaker ceramic stone
Posted: Fri Jun 24, 2005 1:51 am
by Andyy
I have fine and medium ceramic stones that has been used to the point were it's so cower inn metal particles they don't take off much metall from the blade.
Have any one had this problem?
Can any one give me a tip on how to clean them?
Posted: Fri Jun 24, 2005 2:14 am
by thenick
didn't you watch the video that came with your sharpmaker?
some comet with a scouring pad will do a perfect job :)
anyway welcome to the Spyderco world :)
Posted: Fri Jun 24, 2005 4:02 am
by LONE WOLF
You seem familar :p But any ways, I use a scouring pad and old dutch cleaner.
Posted: Fri Jun 24, 2005 5:38 am
by 224477
Hello,
for cleaning I use classical kitchen cleaning powder and old toothbrush, works great for me.
Posted: Fri Jun 24, 2005 6:45 am
by dialex
Welcome aboard. As my forespekers said, scouring powder is OK. But I preffer a pencil eraser. :eek: It does the trick just fine in a matter of seconds :)
Posted: Fri Jun 24, 2005 7:11 am
by greencobra
I've tried both ways, eraser and powder and pad. I prefer the cleanser and scouring pad. I do it my own way having never seen the video.
I'll fill the sink with warm soapy water and let the rods soak for as long as until I feel like having a go at them. Then do the power and pad bit, rinse, and dry. Works for me.
I'm no expert but felt I got better results this way. I suppose as far as both go, there isn't a good or bad, both methods work.
abrasive properties return
Posted: Fri Jun 24, 2005 7:30 am
by JD Spydo
I know exactly what "andyy" is trying to get right. I myself notice that if you don't occasionally give your 204 Sharpmaker a very thorough cleaning that you will lose the abrasive cutting ability and uniform abrasive honing/polishing qualities. It will in my opinion require an occasional thorough cleaning of the stones. I am not trying to take away from or disrespect the other guys/gals methods of cleaning the stones. But If you do want to restore the 204 Stones to their new "out of the box" cutting/polishing ability then you have to do it right.
What I do is to soak the stones in hot soapy water for a few minutes. Then I scrub the stones with Ajax or any other high abrasive cleanser. Then after that I use a specialty cleanser known as "Bar Keeper's Friend". I take a stiff bristle brush and really do an intense scrubbing and then rinse in very hot water. It not only returns the "brand new" abrasive qualities of the stones but also really gives them the ability to put on a superlative edge that can compare with any professional grade sharpening device. JD :spyder: O
Posted: Fri Jun 24, 2005 8:50 am
by Dr. Snubnose
Barkeepers friend... I love that stuff!!...Doc
snicker-snack
Posted: Fri Jun 24, 2005 9:02 am
by Michael Cook
:spyder: I scrub my sharpening stones nightly before every use. I figure as much upkeep as I afford my knives the 5 minuets it takes to scrub my fine and ultra fine stones (medium means chipped or neglected blade to me) is small compared to the benefit of having a uniformly sharpened edge. :spyder:
Posted: Fri Jun 24, 2005 9:14 am
by rastus
This brought back a memory for me. A buddy of mine used to barrow my old Sharpmaker (not the self-contained 204), and the Lansky kit I had. The Lansky has you oil the stones, and , he was oiling the stones of my Sharpmaker too. I figured this out when I tried to sharpen my Endura of the time. The tiny metal particles and the WD-40 he used created a gunk that wouldn't sharpen much of anything. I had to soak the stones in hot, soapy water and then scrub with comet. Several times.
I've also found that if you gently "sharpen" one stone with the other of the same grit, you get a better "grab", when sharpening a dull blade or reprofilling. YMMV.
---Tom
Posted: Fri Jun 24, 2005 9:26 am
by Wali
I have tried all the above methods and these work best for me;
http://www.knifecenter.com/kc_new/store ... ml?s=XTRER
:D
Posted: Fri Jun 24, 2005 9:54 am
by gordonk
I use either a pencil eraser, actually, that white art eraser stuff, or those crepe blocks, mostly the crepe blocks. I found that the crepe block cleans without wearing out the abrasive surface. The art eraser works,but it just takes a bit more time. The crepe blocks are "stickier" for lack of a better term and just seem to work better. I use them for cleaning my discs and belts - just cut a small chunk off (you talk about stuff that'll bind your blade when cutting :eek: ). I don't have a sharpmaker, but do use ceramic rods a lot. I've gotten the crepe blocks from either Lee Valley tools, or Canadian Tire, but I would would suspect you should be able to get them in a variety of hardware type stores.
Hope this helps - gord
Posted: Fri Jun 24, 2005 10:59 am
by Joe Talmadge
Ah, the quarterly Sharpmaker cleaning thread ... is it summer already :)
The quickest, fastest way to clean the Sharpmaker is:
A steel wool scouring pad charged with detergent -- i.e., something like brillo or SOS.
This works signficantly faster than using those plastic scouring pads. It literally takes me just a few seconds to get a stone incredibly clean. Yes, I realize that what should happen is that the metal scouring pad gets "sharpened" by the stone, and clogs it up even worse. However, due an extremely complicated quantum tunneling effect, that you'd need to understand M-theory to even remotely fathom, this doesn't happen. Instead, the stones come out squeaky clean in seconds, no muss, no fuss, no special chemicals or erasers, no pre-soaking.
Joe
Posted: Fri Jun 24, 2005 11:01 am
by i.v
i read about the pencil eraser some time ago & decided to try it myself, works like a charm actually :p
You guys are too cool!!
Posted: Fri Jun 24, 2005 12:43 pm
by Andyy
Inn less than 24hours i got 13 replys.....thanks too you all.
Im new to this contry.... brillo or SOS (Comet?)? Can i find it at grosery stores??
Crepe blocks? Is that the "soft" eraser you can roll between your fingers??
http://www.knifecenter.com/kc_new/s...il.html?s=XTRER link has been added to favorites.
Barkeepers friend?? Whats that??
I scrub my sharpening stones nightly before every use. Ill do that from now.
You seem familar ? Yes... i hang out at knifeforum.com
I don't have the Sharpmaker... just one fine and one medium rod...wy don't they make them in ultra fine??
Posted: Fri Jun 24, 2005 2:18 pm
by dialex
Andyy wrote:I don't have the Sharpmaker... just one fine and one medium rod...wy don't they make them in ultra fine??
They do, actually. Ultra fine, fine, medium and diamond.
Posted: Fri Jun 24, 2005 2:31 pm
by Andyy
It's not on there web page. Only fine, medium and diamond.
http://spyderco.com/catalog/list.php?ge ... er_page=10
Posted: Fri Jun 24, 2005 2:47 pm
by Chris_H
The Ultra Fine rods do exist--
http://www.newgraham.com/spy7.htm
Spyderco Replacement Rods, Ultrafine - 204UF
Brillo, S.O.S. & Comet are easily found in grocery & some convenience stores.
Crepe Blocks
Good luck & happy sharpening!
reallyreallyreally sharp!
Posted: Fri Jun 24, 2005 6:27 pm
by Michael Cook
:spyder: Those ultra-fine stones really work. They get :spyder: 's sharper than the mind's eye. Super-duper sharp. :spyder:
Posted: Sat Jun 25, 2005 11:38 am
by Andyy
I tried the eraser. It works ok.
I tried soaking inn hot soapy water and scrubing with toothbrush. Didn't do much.
And i tried scrubing with comet and scour pads (scotch Brite, 3M). This worked the best for me.
I will have to get one ultra fine to.
And i'll stop by a hardware store and look for a crepe block
Thanks again.
