Spyderco/Fox Volpe
spydutch
Spyderco/Fox Volpe
Post by spydutch »
I just saw a picture of the Volpe (Spyderco/Fox collab) .The steel of this knife is N690Co. Can anybody tell me more about that steel? I have a Fox skinningblade folder of the same steel(the 432A)
When this knife goes in production I will most certainly order it. What a beautiful knife it is( the Volpe that is)
HoB
Post by HoB »
Wasn't that the european version of 440C (more or less)?
spydutch
Post by spydutch »
I really don't know. When I bought that Fox I searched and asked everywhere but I couldn't find any info on the steel so I stopped searching. But now spyderco brings out a knife with that steel too I wondered if there is more info about that steel.
HoB
Post by HoB »
N690- An Austrian made stainless steel, which is comparable to 440C in performance and value. Keen edge qualities with excellent corrosion resistance.
Yes, that is indeed....from the Benchmade :o webpage. I recalled that they were using it in some of their knives. So everything you read about 440C should mostly hold for N690. I believe the compostion is slighly, but not significantly different from 440C.
spydutch
Post by spydutch »
Thanks HoB. It figures. Most of the Fox knives are 440C.
Milu
Post by Milu »
N690C is also used by Extrema Ratio. In my limited experience the one used by Fox is not heat treated as well as ER and is at a lower hardness level: Translation: It's easier to sharpen but does not hold an edge as well. Fox is not so much a manufacturer as a marketing company - a bit like Cold Steel but without the hype.
Photos of the Spyderco/Fox Volpe please!
My father always taught me not to trust a man who was not interested in cars, guns and knives.
Senate
Post by Senate »
here it is... :)
Alexandre.
Ted
Post by Ted »
There's a better one on my site (just updated it yesterday) (and in the 2005 catalog insert PDF)
Ted
dani
Post by dani »
N690co it's good, better than 440C but not so different from it.
I have a Col Moschin ER, but it's only for collection, so I've never tried this steel.
FOX uses N690 in its last knives production presented at the IWA.
hannes w
Post by hannes w »
If you look at the composition of N690 it looks more comparable to VG10 then to 440c
N690
Comp.: C 1,07; Si 0,40; Mn 0,40; Cr 17,0; Mo 1,10; V 0,10; Co 1,50
Werkstoffnummer: 1.4528
EN: X105CrCoMo18 2
g
Hannes
Mr Blonde
Post by Mr Blonde »
Thanks for posting those supersized pics ted!
Wouter
Last website update: 07-31-2025 Instagram
