G-10 over the years...
Hello all,
I've been buying Spyderco knives since 1996 or so and am just loving the new models coming out. I have a question about one model from back in the old days, the G-10 Harpy.
When I bought this knife back in 1997 (or so), after using it for just a few weeks I remember the G10 handles started to turn grey and were not as tacky as they were when the knife was new. I ended up trading it for a pro-venator, but I digress...
I just got a black Dodo a few months ago and was pleased to see this "greying" is not happening.
Has there been any advance or improvements in the actual G-10 materials being used over the last 6-8 years? I loved the G-10, but was not pleased with what happened to the Harpy. Is this a normal occurrence for this material, or was this just a characteristic of the (then) new G-10 handles? Or, did I just get a strange piece of G-10? I was considering picking up this knife again, or perhaps getting a rookie, but I thought I would check and see first.
Thanks in advance for the info,
xrob
xrob
- The Deacon
Only got into this about two years back. All I can tell you for certain is that I currently own a range of G10 Models, from some of the earliest unlined specimens to the SpyKer. Out of them, only one ever "greyed out" like your Harpy, and I strongly suspect that some "dressing" put on by the previous owner was the cause. I have heard that the surface can dry out, so another possibility might be excess heat in transport or storage.
Other treatments
I have found that there is a chemical called "Ballistol" which does a superb job of rejuvenating G-10. I have been told that there are quite a few products on the market that are specifically meant for the preservation/rejuvenation of polymers of all types. I too an interested of knowing of more of them.
WD-40 from what I have been told has a lot of negative properties to it. I have also been told by another Forumite that a high quality mineral oil will do a great job as well. JD :spyder: O
Hello,
In a thread where all the ameliorations over the years that was made to the military model, one was that they changed the way they dyed the g-10 scale.
Hope it helps,
Simon
Hope it helps,
Simon
"Everyday above the ground and vertical is a good day".
-Sir A. Hopkins in "The world's Fastest Indian"
"If it hurts, it means you're not dead..."
-Kayakist Marie-Pier Cote
The Spyderco Cookbook
Follow-up
All,
I managed to get my hands on another 97 Harpy. And the G-10 material used for this knife is dramatically different to the newer stuff used on the Dodo and Yojimbo. I've attached pictures for comparison. The older stuff (this knife has had VERY little use) is somewhat more grey. Any thoughts?
xrob
xrob
- Attachments
- harpy-yojimbo2.jpg (77.91 KiB) Viewed 1533 times
- harpy-yojimbo1.jpg (83.95 KiB) Viewed 1514 times
