Got my new Dodo for xmas - have just given it it's first clean-up with hot water and soap. Dried it off and applied a few drops of Ballistol to the hinge and lock spring.
Now, if I open the Dodo fast, or moderately fast, its gets to be a SERIOUS pain to make the ball-bearing lock disengage. If I open it really slowly, then it's no problem to disengage.
So I'm guessing this ball-bearing is getting jammed too hard into the tang. Anyone else found this, or can help with suggestions ?
Thanks
DoDo Lock - disengagement
Welcome to the Forum! Call Spyderco warranty. This is only the fourth time I have heard this. Don't let it scare you off the Dodo. It is one of my fav Spydies and is totally awesome. Some though(4) have had a ball bearing lock problem. Call them and they will be most helpful. Stick around and enjoy the forum, Take Care!!!
"everything else is just a jeep"
Welcome to the <img src="spyder.gif" width=15 height=15 align=middle border=0> Forum, Waf.
Shiden-Kaj
<IMG SRC="http://www.bladeforums.com/forums/avata ... 1073689062" ALT="Lux et Libertas">
Shiden-Kaj
Hi, thanks for the welcome.
My DoDo lock isn't failing - ie. the knife is not closing on me. The probem is more the opposite - very very difficult to make the lock disengage. I sometime need to use a little screwdriver as a pry-bar to shift the ball back so the knife can cose.
I reckon the ball is getting jammed in the tang, or alternatively there is something obstructing the spring (in the knife handle). Hard to say without taking the knife apart.
- Joyce Laituri
Mr. Bombastic
