Page 50 of 97
Re: New to me
Posted: Mon Feb 09, 2015 9:33 am
by phillipsted
noseoil wrote:Here's the superblue mule I found. It was used & dull, sporting a partial patina & in need of some tlc when it arrived. Here's a couple of pictures, before & after shots. Still working on the finish, using danish oil so the pores will be filled up sooner or later, purple heart with ebony spacers & copper pins. It's 11/16" at the fattest part & tapers a bit at the ends to a shy 5/8", very comfortable grip. Turning out OK this time. Gotta love that superblue.
Nicely done, Noseoil!
TedP
Re: Show your Mule
Posted: Fri Feb 27, 2015 5:31 am
by elmeringalo
This is my last Mule, MT09P in Cobalt Special "san mai" and African Palo Rojo handle and mosaic pins
Re: Show your Mule
Posted: Fri Feb 27, 2015 9:38 am
by phillipsted
Elmer - I really like that Palo Rojo (which is sometimes called Padouk in the U.S.). Leaving the open grain exposed is really good looking - and will provide quite a bit of grip for the scales. Also love the attention to detail and the contours, especially near the ricasso area.
Well done!
TedP
P.S. - My experience with Padouk is that it will darken significantly over time and exposure to sunlight. I built a small jewel box for my wife this Christmas, and it has darkened to a deep maroon two months later. Some of my other projects have darkened to a deep reddish-brown within a year. Something to look forward to!
Re: Show your Mule
Posted: Sat Feb 28, 2015 3:26 pm
by elmeringalo
Hi Phillipsted, Thanks for your words. I think also that padouk will go to Dark maroon with The light, but It's good too. I'm new with Knives and I like to try diferent materials
Re: Show your Mule
Posted: Tue Mar 10, 2015 9:36 am
by mark_england
ok just ordered my first Mule (08 Super Blue) and looking for some advice please.
I'm thinking of micarta scales (probably black), what size scales do i need and what size pins?
forgive the dumb questions,, this will be my first knife build
Re: Show your Mule
Posted: Wed Mar 11, 2015 12:12 am
by jabba359
mark_england wrote:ok just ordered my first Mule (08 Super Blue) and looking for some advice please.
I usually buy a pair of 1.5"x5" (or 6") scales, 1/4" or 3/8" thick. If you like thicker handles, perhaps 1/2" thick would work for you. The larger holes in the mule are 3/8" while the smaller are 3/16". The lanyard hole is 1/4". Always test out the holes before gluing, as sometimes they're not completely clean and it's hard to get the pins through them without some sanding/dremeling to clean up the holes. I've pinned a few with 3/16" pin stock and my current project will be pinned with 3/8", but for the vast majority I buy 3/16" pivot screws and bolt the scales on, as it makes then easy to remove and swap out later.
If pinned on, you typically want to epoxy the handles on, which will usually cause you to destroy the handles if you ever decide to remove them. You want to make sure that you scratch up the handle as well to give the epoxy a surface it can bite into. Using epoxy on the Super Blue should also help seal up all the holes in the handle, making it less likely to corrode.
Re: Show your Mule
Posted: Sat Mar 14, 2015 2:05 pm
by mark_england
elmeringalo wrote:
love this,, may i ask what size pins and lanyard tube you used on this?
Re: Show your Mule
Posted: Sat Mar 14, 2015 5:30 pm
by SpeedHoles
I actually just attained my first Mule recently as well, also a #08 Aogami Super Blue! :D
Nothing original to look at, unfortunately... but still looks cool bare!
Re: Show your Mule
Posted: Sat Mar 14, 2015 9:56 pm
by jabba359
mark_england wrote:
Unless he drilled the holes out larger (which would be a lot of unnecessary work , those look to be 3/8" pins and 1/4" lanyard tube.
Re: Show your Mule
Posted: Mon Mar 16, 2015 5:28 am
by mark_england
ok about to order pins,,, last dumb question i promise..
what size is the hole in the blade please?
Re: Show your Mule
Posted: Thu Mar 26, 2015 12:23 am
by GnifeGnut
Fooling around in the shop with something different.
Re: Show your Mule
Posted: Thu Mar 26, 2015 1:37 am
by jabba359
mark_england wrote:ok about to order pins,,, last dumb question i promise..
I measured my Super Blue Mule blade hole at 7.65mm/0.3"
Re: Show your Mule
Posted: Thu Mar 26, 2015 7:04 pm
by elmeringalo
mark_england wrote:
Hi! Sorry for my late answer. The laynard tube is 1/4' same like knife hole. The pins are slightly smaller than big knife holes, 1/3'
Re: Show your Mule
Posted: Thu Mar 26, 2015 7:51 pm
by elmeringalo
The four Mules (by the moment)
Re: Show your Mule
Posted: Thu Mar 26, 2015 7:57 pm
by elmeringalo
Wearing their clothes
Re: Show your Mule
Posted: Thu Mar 26, 2015 8:02 pm
by elmeringalo
My next one will be an MT05 with Black micarta handle and orange G10 bolsters and two hole pins in nickel. Soon I will show here
Re: Show your Mule
Posted: Fri Mar 27, 2015 9:55 am
by phillipsted
I always use the 3/16" (0.1875") holes for my pins.
TedP:
Re: Show your Mule
Posted: Fri Mar 27, 2015 3:04 pm
by elmeringalo
Here are!
Here are!
Re: Show your Mule
Posted: Fri Mar 27, 2015 10:11 pm
by jabba359
elmeringalo wrote:Image
Beautiful sheathwork. Do you make those as well?
Re: Show your Mule
Posted: Sat Mar 28, 2015 5:41 pm
by elmeringalo
Yes, I do
