Show your mods!
Your contact's are good Donut
I let it tumble for a hour but I used smaller rock and more oil and metal polish mix than normal
I like the effect but I can't take a pick of it'
It's got a light stone gloss finish it's different.
It came out very even.
I like it :)
I like it :)
My favorite Spyderco is the one I'm carrying now  :p
						Shared these in the Wood Scale Mods thread too, but thought I solicit thoughts from here also.
Decided to "striderize" my Persistence with more of a gunstock shaped butt end a straighter top line using some yellowheart wood.
Not quite as shiny and poliched as it will be once I am finished, but its rounding into form.
				haarspalter
Thanks.
Its a wood called Texas yellowheart. I think it is also sometimes called "Bois D'Arc" Great stuff to work with. It was not stabilized, but I am planning to put a few coats of gunstock refinishing oil on it which will accomplish pretty much the same thing. Once thats done, I'll put it on the buffing wheel with some polishing compound to give it a real shine. Maybe I'll post another pic or two upon completion.
I have been wanting to try Moly Resin to protect the steel on my Cruware mule (prevent long term corrosion), but I was a little worried about the 300F curing time for Moly Resin (same for Cerakote) as 300F is awfully close to the temperature for tempering many steels.  However, I found that Cruware's tempering temp is around 1000F, so 300F was not even close to affect its hardness, so I gave it a try.
After sandblasting the finish, I applied and cured the semi-gloss black Moly Resin (M390 mule shown for comparison):
Lets see how it holds up :D
Will
Will
Wanted: Superhawk - Found!
				Fred Sanford
Well I decided to try and stone wash my green tenacious sprint and this is the results. I did a practice run on a ukpk that came out more subdued that I might re-do.
The set up was far from sophisticated just a plastic bottle some rocks from a stream down the road and wd40. I had a particularly large rock that I think should have been left out as it made deeper indentations and a few gouges. Overall through I am happy with the out come and I think it works well with the green sprint color of this knife.
Next up I would like to try and wharncliffe a knife (probably the ukpk) any tips or knowledge would be appreciated as I have no clue how to proceed. I have a dremel tool that I was thinking could work.
Looks great!Tyv& wrote:Well I decided to try and stone wash my green tenacious sprint and this is the results. I did a practice run on a ukpk that came out more subdued that I might re-do.
I "wharnied" a Caly a while back. Just took a ruler and drew with a marker a straight line from the tip to the back of the blade. Then I ground it down (dip in water so it stays cool) with my Dremel and diamond bits and a diamond disk to make sure it was straight. Next, just sharpen the new edge. I'm sure the pic is at the start of this thread. It's a really easy mod. Good luck, and show us when you're done. :)
- best wishes, Jazz.
- Must_Seagate
- razorsharp
It isn't as heavy as I thought it was going to be. It is very comfortable to carry with jeans. I also carried it with khaki shorts and it didn't feel to heavy, but I don't think the clip is in the perfect position for angled pockets
									-Brian
A distinguished lurker.
Thanks, Donut. One thing I don't like about some collaborations is the clips. I like the usual Spyderco ones. I don't like wire clips on titanium, though - just don't go together. That's the only thing I don't like about my Sage 2. I know, why am I rambling in the pic gallery? :rolleyes:
- Must_Seagate
