First crack at 3d printed Mule Scales
Re: First crack at 3d printed Mule Scales
Now I really want to print a set of glow in the dark scales.... Are y'all using upgraded nozzles for your glow in the dark filaments? I thought I read that most (all?) phosphorescent filaments we're filled with small hard particles that would quickly abrade brass nozzles, any truth to that? If so what upgraded nozzles do you use for abrasives?
- FullScaler
Gtscotty wrote: ↑Tue Dec 21, 2021 1:48 pmNow I really want to print a set of glow in the dark scales.... Are y'all using upgraded nozzles for your glow in the dark filaments? I thought I read that most (all?) phosphorescent filaments we're filled with small hard particles that would quickly abrade brass nozzles, any truth to that? If so what upgraded nozzles do you use for abrasives?
I just used a cheap 0.2mm nozzle, but I think it is bored out to at least 0.3 or bigger after a few sets. Lol. I have not been happy with my results yet. Using Eryone3d filament and it is tough to get a good print. It glows real nice but even after drying it strings a lot and bed adhesion is poor compared to most other filaments.
Anybody got an amazon hardware list? Need to attach some scales.
Michael Janich
Dear gpattikjr:
Stay safe,
Mike
Stay safe,
Mike
FullScaler (who has an arrangement with Josh) printed me a set of mule scales in translucent green. Wow they are nice. The grip pattern is great, just the right amount of height differential to enjoy a secure but comfortable grip. Currently, hardware and final fitting is up to the recipient. I think my barrel connectors are a little fatter than the Halpern hardware, so I did a light ream of the holes with a 3/16 flat bottomed milling bit (just twisting it by hand), though a 3/16 drill bit would probably have done the same job. Then I used three 3/16 x .312 barrel connectors and six 4-40 x 1/4 button head screws to complete the job. Sweet. Thanks FullScaler! And thanks for the fast printing & shipping also. Got the scales in time for Christmas!
If interested in ordering hardware, mine from USAKnifeMaker:
3/16 x .312 barrel connectors: FKP LT Connector 8510 (need 3, $1.67 each)
4-40 x 1/4 button head screws: Button Head Screw #4-40 x 1/4” (pack of 20, $2.79).
- Josh Crutchley
Thats my scale design. I believe your confusing me with GTScotty.Bolster wrote: ↑Sat Dec 25, 2021 6:51 pmFullScaler (who has an arrangement with GTscotty) printed me a set of mule scales in translucent green. Wow they are nice. The grip pattern is great, just the right amount of height differential to enjoy a secure but comfortable grip. Currently, hardware and final fitting is up to the recipient. I think my barrel connectors are a little fatter than the Halpern hardware, so I did a light ream of the holes with a 3/16 flat bottomed milling bit (just twisting it by hand), though a 3/16 drill bit would probably have done the same job. Then I used three 3/16 x .312 barrel connectors and six 4-40 x 1/4 button head screws to complete the job. Sweet. Thanks FullScaler! And thanks for the fast printing & shipping also. Got the scales in time for Christmas!
Joshcrutchley1 wrote: ↑Sat Dec 25, 2021 7:42 pm
Sorry about that. Corrected. Nice job, may I add. I really like the depth of the pattern on the surface. It's just the right amount. I'd not want it any more shallow, or deeper.
- Josh Crutchley
Thanks, it took me a while to figure out the pattern. I will say if it wasn't for GTScotty making his first and proving to me it was possible in Fusion I probably wouldn't have made them.
Joshcrutchley1 wrote: ↑Sat Dec 25, 2021 10:59 pmThanks, it took me a while to figure out the pattern. I will say if it wasn't for GTScotty making his first and proving to me it was possible in Fusion I probably wouldn't have made them.
I'm very happy to have a copy! It's fitting to have transparent hi-tech scales on a high-tech blade!
Mule Team Army 001 (patched)
MNOSD 008
Stable Mules; Z-Max, Z-Wear, Magna Cut, Magna Max, SRS13, Rex 76, Rex T15.
MNOSD 008
