CPM REX 45 | Edge Performance
Pelagic
Re: CPM REX 45 | Edge Performance
#81
Post by Pelagic »
Amazing that the s110v military had over twice as many cuts as the s90v military. I've owned both and they're extremely close in performance.
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
jpm2
#82
Post by jpm2 »
I expected it to be on par with k390.
I don't think k390 is a hss.
Ankerson
#83
Post by Ankerson »
The Meat man wrote:
Tue Dec 25, 2018 6:27 pm
Interesting! Thanks Jim!
That is not quite what I thought it might come to. I thought it would be closer to Maxamet, at least over a thousand.
Still that is a terrific amount of cutting. Higher than K390.
How did you find the edge bite or aggression to be compared to other HS tool steels like Maxamet, K390, CPM M4, etc.?
20 cuts here or there at that level is nothing, really could have gone either way.
It's very aggressive with my 400 grit edge.
Ankerson
#84
Post by Ankerson »
Pelagic wrote:
Tue Dec 25, 2018 6:41 pm
S110v at the same hardness beats S90V, raise that hardness about 3+ points and make it thinner behind the edge.... Like those blades that I tested and there is the difference.
Ankerson
#85
Post by Ankerson »
Deadboxhero wrote:
Tue Dec 25, 2018 4:03 pm
Ankerson wrote:
Tue Dec 25, 2018 3:15 pm
Finished the rope cutting, it did excellent IMO.
Added here:
https://www.bladeforums.com/threads/ran ... pe.793481/
Wow, 840 cuts, cut more then 4v and M4, Very nice. That hardness really helps.
Thanks Jim
Not sure what the HRC hardness is, but I could tell it was way up there.
Bloke
#86
Post by Bloke »
Many Thanks for your hard work Jim! :cool:
Ankerson
#87
Post by Ankerson »
Bloke wrote:
Tue Dec 25, 2018 8:07 pm
Still have the rest of the testing to do yet on that one.
Then the Serrated Caribbean after that. :eek:
Pelagic
#88
Post by Pelagic »
Ankerson wrote:
Tue Dec 25, 2018 7:47 pm
I must have missed the stats on the s90v military.
Ankerson
#89
Post by Ankerson »
Pelagic wrote:
Tue Dec 25, 2018 8:25 pm
S90V Military was 60 HRC and .025-.027 behind the edge, same as the PM2 I tested.
Bloke
#90
Post by Bloke »
Ankerson wrote:
Tue Dec 25, 2018 8:09 pm
That’ll keep you off the streets for a while. :p
All jokes aside, its a mountain of work and I genuinely appreciate what you do.
Merry Christmas! :)
Ankerson
#91
Post by Ankerson »
Bloke wrote:
Tue Dec 25, 2018 8:33 pm
Merry Christmas! :)
Thanks, and Merry XMAS. :)
The Caribbean is going to take a long time I think cutting rope.
EngDevGr3
#92
Post by EngDevGr3 »
Hello Jim,
I was just curious if you have used the PM2 or Para 3 in the Rex 45. I have noticed on the s110v military , it has a slightly higher hrc than the Manix 2 or PM2. I am wondering if this may be the case for the Rex 45 family, or if all models seem to have the same performance. Thanks
Ankerson
#93
Post by Ankerson »
EngDevGr3 wrote:
Fri Dec 28, 2018 1:02 pm
Hello Jim,
No idea, you can ask Spyderco.
attila
#94
Post by attila »
wrote:
Fri Dec 28, 2018 2:28 pm
Hello Jim,
Spyderco won't answer that question, unless if you can convince Sal.
Every time I've asked about HRCs of knives, they've responded that they don't know or its proprietary info. We usually need to rely on independent testers for actual numbers.
Want: SPY27, K490, Swick 5
edge-e
#95
Post by edge-e »
I have access to a bench top HRC hardness tester. If I get around to taking my Rex 45 military apart I will share the info here. I’m hoping for 66-67 rc. I just got the knife and the factory edge is the sharpest I’ve ever seen out of any brand or model. I think this steel will take a killer keen edge.
edge-e
#96
Post by edge-e »
I got a repeatable reading of 66 HRC on my CPM Rex 45 Spyderco Military model. Happy with that number.
#97
Thanks for sharing!
The Meat man
#98
Post by The Meat man »
Thanks edge-e, good to know!
Do you have a Maxamet blade to compare?
- Connor
edge-e
#99
Post by edge-e »
Your welcome guys! Meat man, sorry I
Currently don’t have a maxamet blade to test. Hope to get one in the future.
Ankerson
#100
Post by Ankerson »
edge-e wrote:
Sat Jan 05, 2019 12:22 pm
Figured it was up there. :D
Looks like Spyderco nailed it.
