I'm limited to 10x, 60x, and 200x. I also wish I could adjust the light, but it is a kids toy. I have a sweet scope, well I should say a family member does, an they won't let me touch it (for now)
I read this and was going to say, "Isn't that the pot calling the kettle black" after reading about your adventures with Nano-oil, then I read further and understood :)jackknifeh wrote:You guys are definately getting obsessive with this edge thing. I think it's crazy.
Great pictures. Thanks to you and others I now know how ugly my beatiful edges really are. :)Clip wrote:Got the micros of the edge after fully sharpening the Manix2.
M4 - FFG, Lansky full diamond set, stropped with black and green compounds after. Sharpened to Lansky's 17° on the logo side and 20° on the origin side. Looks like the edge is definitely smoother than factory.
First, a macro to show the visible edge, slightly matte. Need to make a soft box in the near future. You can see at the left side the grind got noticeably steeper and I didn't care to reprofile all the way, but the edge is sharp.
50x
100x
200x
500x
1000x
M4 will take a little longer. I love that steel. The reason the angles are not the same on the factory edge is the knives are hand held against a grinding wheel or belt. Maybe not at all factories but one video I saw they used a grinding wheel. Due to human error the angles are a little different once in a while. Doesn't take away from being very sharp though. :)Clip wrote:These were the closest to the factory angles on both the 154CM and the M4 Manix2s. After a year of carrying it with the factory angles, I completely reprofiled the origin side of the 154CM Manix2 so it would be (Lansky) 17° both sides. I'll probably do the same with the M4 after a while, but it definitely takes longer to shape.
I'm interested in this also. I've been using ceramic stones (Spyderco of course :) ) for a while now.Lagrangian wrote:Hi Clip,
There was a discussion about ceramics and abrasives in general in the WEPS forums, and I was thinking,"Hmm.... it is difficult to get good pictures of what the surface of a ceramic stone looks like, because they are rough and it is hard to focus on their surfaces..." Then I though,"Oh yeah, Clip!"
So if you have a chance, maybe you could use your microscope to take pictures of ceramic, diamond, and SiC stones? And with a micron length scale, plus Komitadjie's Grand Unified Grit Chart, it would be quite interesting!
Sincerely,
--Lagrangian
