Behind the edge database!
Cambertree
Re: Behind the edge database!
#61
Post by Cambertree »
My Waterway came in at -
3.03mm/0.119" spine (in front of plunge line
0.62mm/.023" BTE averaged from three readings.
The Meat man
#62
Post by The Meat man »
Spyderco Delica exclusive CPM Cru-wear:
Stock thickness: 2.44 mm
BTE: 0.025"
- Connor
#63
The Meat man wrote:
Mon Aug 05, 2019 2:33 pm
BTE: 0.025"
We're pretty close Connor. I got .095" Blade Stock and .0225" BTE directly beneath the Spydie logo
The Meat man
#64
Sharp Guy wrote:
Mon Aug 05, 2019 4:12 pm
BTE: 0.025"
Yeah I measured the BTE at the heel, middle, and tip, and they averaged 0.0253".
- Connor
spyderg
#65
Post by spyderg »
Looked but didn’t see, anyone measured a Smock yet? I don’t have a good enough set of calipers but mine seems crazy thin with that hollow grind.
#66
Updated. I need to get around to organizing those by model.
Cambertree
#67
Thanks for keeping this list up to date, D.
I just noticed I have a HAP40 Manbug which still has a (very nicely ground) factory edge:
Manbug HAP40
Spine (in front of plunge line) 2.08mm/0.082”
0.40mm/0.015” BTE
Pelagic
#68
Post by Pelagic »
Interested to see how the Native Chief measures up!
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
#69
SNK Lil' Native 4V
Blade stock thickness: .125"
BTE: .022" avg
#70
Evil D wrote:
Fri Jul 12, 2019 3:19 pm
I bought a caliper set recently but I'm really not impressed with the quality or I'd measure mine. I plan on getting a different one and I have a new Caribbean in the mail so I'll work on this, at least for the SE version, not sure if anyone is interested on SE numbers.
D you can get a set of Husky brand digital calipers at Home Depot for like $30. I bought a set when I started 3D printing because everything's metric. I've tested them on a Mitutoyo gauge block and they measure right on the money. I actually use those more now than the set by Brown & Sharpe I've had for years.
Cambertree
#71
Received my leaf blade Caribbean in PE.
Pleasantly surprised to see it came in at:
Spine thickness: 3.42 mm/0.134”
0.44mm/0.017” BTE
(As always, spine thickness is just in front of the plungeline, and BTE is averaged from 3 readings: just in front of the ricasso, middle, and about 5 mm from the tip.)
Pelagic
#72
Post by Pelagic »
Cambertree wrote:
Thu Sep 12, 2019 7:52 pm
0.44mm/0.017” BTE
Thank you!
Deadboxhero
#73
Post by Deadboxhero »
Police 4 K390
0.110" stock
0.030"bte
28dps
Big Brown Bear
Triple B Handmade Knives
Cambertree
#74
Pelagic wrote:
Thu Sep 12, 2019 7:56 pm
Thank you!
No worries!
Deadboxhero wrote: Police 4 K390
28dps
Youch! :eek:
Just as well we know: 'It's what's on the inside that counts'! ;) :D
attila
#75
Post by attila »
Deadboxhero wrote:
Thu Sep 12, 2019 9:20 pm
Police 4 K390
0.110" stock
0.030"bte
28dps
Whoa! I'm surprised by a factory edge being fat and obtuse at the same time!
My only 0.030" BTE when new Spydie was the XHP Manix LW, but it's around 15 dps. The Cruwear Military was close, though, at 0.027" and at around the same angle.
Thanks for the info.
Want: SPY27, K490, Swick 5
DukeNiemand
#76
Post by DukeNiemand »
Shaman 4V:
0.144" spine
0.025" bte
Pelagic
#77
Post by Pelagic »
DukeNiemand wrote:
Mon Oct 14, 2019 8:46 pm
Shaman 4V:
0.144" spine
0.025" bte
Thanks!!!
SteveMidwest
#78
Post by SteveMidwest »
I forgot to post this last week.
Spyderco Shaman Cruwear/Micarta C229MPCW Date Code 'FS'.
Blade thickness - 0.1455"
Behind the edge thickness (BTE)
Half inch from the tip - 0.026"
Mid-blade - 0.025"
Half inch from the plunge grind - 0.024"
attila
#79
Post by attila »
BTE at 1/4" from the ricassso/at the middle of the edge/1/4" from the tip, followed by stock thickness.
Crucarta Shaman
0.021/0.023/0.023
stock thickness 0.145
Xplorer
#80
Post by Xplorer »
Cambertree wrote:
Sun Jul 28, 2019 5:57 pm
This one caught my attention because I recently made a custom Vanax Waterway for Lance, and to do that I had to carefully study the dimensional measurements of the Spyderco version.
The spine thickness listed here is basically the same as what I have measured. I get .119" just behind the plunge line with my calipers and .120" using a micrometer on a precision granite slab.
BTE measurements can be a little more difficult. I expect to see variances around +/- .002" from one person to the next for a variety of reasons. The only reason I bring this one up is because the BTE measurement listed above is nearly double what I am finding.
My Waterway measures .119" at the spine and .012" BTE .
Best,
CK
@ckc_knifemaker on Instagram.
