New Spyderco: The WolfSpyder
Liquid Cobra
Re: New Spyderco: The WolfSpyder
#61
Post by Liquid Cobra »
Some folks already have them! I've seen pics in the wild!
@liquid_cobra
SpyderNut
#62
Post by SpyderNut »
Liquid Cobra wrote:Some folks already have them! I've seen pics in the wild!
Where are these pics that you speak of?? :D
:spyder: -Michael
Liquid Cobra
#63
The unofficial Facebook group.
@liquid_cobra
Leeroy37
#64
Post by Leeroy37 »
Couple of lads in the uk got theirs today
demoncase
#65
Post by demoncase »
Pictures in the wild you ask?- Then I shall deliver, post-haste and forthwith :)
Smaller than I remember at the Amsterdam Meet (but that's my memory at fault).
Going to be much less scary than the PM2 to non-knife-peeps. Fits fairly well into a pocket, the pointed rear gives some grip area to draw the blade.
Grip is very comfortable- The large cut out makes the perfect site for the thumb while scraping or doing fine work with the index on the rear of the blade. I keep going for a liner lock that isn't there- it'll take a tiny little bit of hand education.​
Rear shape is comfy in a normal grip but perfect in a reverse grip from scraping and bark stripping.
Smooth opening or closing but not the drop free of a PM2 or Yo2.
Jimped spine and G10 section makes for a sensible grip and the comp lock isn't. Again. Feels right.
(note- the jimping on the G10 is clean and crisp- it's pocket fluff and dodgy lighting making it look rough)
Build looks super solid too- plus that thick blade looks robust with the Scandi grind
US 10c, EU 20c and UK 10p for size scale.​
farnorthdan
#66
Post by farnorthdan »
I like it, probably be some time before mine makes it across the pond though,
Thanks posting up some pics sir :D
twinboysdad
#67
Post by twinboysdad »
So if I get one and can't resharpen Scandi, can I just conventional sharpen on my SM??
SpyderNut
#68
Post by SpyderNut »
Muchas gracias, Demon. :D I especially appreciate your in-hand pictures. That really helps to explain the functionality of the funky-looking handle. :) How do you like it?
:spyder: -Michael
demoncase
#69
Post by demoncase »
twinboysdad wrote:So if I get one and can't resharpen Scandi, can I just conventional sharpen on my SM??
Stick a microbevel on it with your SM and Bob's yer uncle.
demoncase
#70
Post by demoncase »
SpyderNut wrote:Muchas gracias, Demon. :D I especially appreciate your in-hand pictures. That really helps to explain the functionality of the funky-looking handle. :) How do you like it?
I like it- not saying I love it yet.....that big cut out for the opening hole is taking some getting used to in comparison to over knives.
You can ( as I've shown) hook the index finger into it or press a thumb into it.
The feel of it suggests that it will take a real beating in use- it's super solid, and that I do love.
I will say The Better Half picked it up and instantly said "Wow....This is really well thought out"
SpeedHoles
#71
Post by SpeedHoles »
I like it! Probably never have one though...
Even though I'm not a fan of the occluded Spydiehole on one side, I'd imagine you could compression drop the blade out if desired.
I know it's got a proper intended use, but I just see those sharp handle ends and just think it'd be torture on my pants and car seat bolsters!!
Going back to Caly.
demoncase
#72
Post by demoncase »
Comparison shots for size with some common models
twinboysdad
#73
Ok, ^^ that shows it is smaller than I thought and the Spyderhole is quite small. I had originally wondered if Demon was hamfisted, but it looks like his paws are normal size and this is just a smaller than expected design. Thanks for the pics, I now have a lot to consider...
demoncase
#74
Post by demoncase »
twinboysdad wrote:I had originally wondered if Demon was hamfisted...
You aren't the first and you won't be the last on that score, let me tell you :D
SpyderNut
#75
Post by SpyderNut »
Thank you for the comparison pictures, Demoncase. As TBD stated, this knife is a LOT smaller than I previously anticipated--which is a good thing. I love knives in this exact size range. This will give me a lot to consider also. :D
:spyder: -Michael
SpeedHoles
#76
Reminds me of an Enzo Birk with a larger handle and comp-lock. Similar size, too.
Going back to Caly.
farnorthdan
#77
Wow, that's a lot smaller than I envisioned, thanks for posting the comparison Demon.
Holland
#78
Post by Holland »
Doesn't look like it is slicey enough for my taste :o
#79
It is smaller than I expected, too small as a primary knife in the bush. Looks like a nice sized folder to carry with a scandi FB like a Bushcraft or Mora. Question is, if you already carry a scandi FB, why would you need a small scandi folder? Carving? Or a backup to your FB? I'm not really sure where it should fit into the whole bushcraft theme. :confused:
I know I will always reach for a scandi FB with a roomy and comfortable round handle to make feather sticks or split kindling rather than a tiny folder.
Warrior1
#80
Post by Warrior1 »
The Wolfspyder has landed on this side of the pond, after a long trip from: Golden, Colorado to England then back to Albany, New York!
As others have said it is on the small size but very stoutly built... Almost heavy in the hand. I like it a lot.
It probably won't replace my Techno as my EDC, but it's sure to find a way into my pocket on the weekends. Great for those weekend hammock trips.
The older I get, the better I was...!
