Posted: Wed Jul 24, 2013 7:44 pm
... or $69, this suckers fate was cast when forged, no babyin' here, them thar flames from the heat treat were a warnin' of what was ta come
chuck_roxas45 wrote:Thinking points I take away from this discussion.
*Steel choice comes down to what bevel angles we use on on our knives.
*How much performance difference is there between a 15 dps or 10 dps bevel and 5 dps?
*Is there anything to be gained by normal EDC uses in such thin angles over slightly thicker ones?
*Do the advantages of such a thin bevel outweigh the probability for edge damage?
*How long does the high sharpness on extremely thin angles really last?
I re-profiled the S110V the other day using a 140 grit diamond plate and then congress mold masters and I'd say it wasn't too bad either. Did not take as long as I thought it would and ended up with a very nice edge.Ankerson wrote:Reprofiled and sharpened the K390 Mule today for testing. :)
Wasn't bad with the SIC stones, it's fine grained and seems to be very clean, sharpened up very well.
Yep, I'll be checking your thread frequently. Thanks for doing this. :)Ankerson wrote:Reprofiled and sharpened the K390 Mule today for testing. :)
Cutting with it now, coarse edge, looks like they got it right so it's going to be awhile.....chuck_roxas45 wrote:Yep, I'll be checking your thread frequently. Thanks for doing this. :)
That's a bandwagon I would surely love to jump on. The Cruwear will hold me until then, but I'm ready to pay now...Ankerson wrote:Lets just say we really need a K390 Military tomorrow done with the same process. :cool:
xceptnl wrote:That's a bandwagon I would surely love to jump on. The Cruwear will hold me until then, but I'm ready to pay now...
How is the native doing? K390 Millie would be awesomeAnkerson wrote:Put it this way, no other production knife will even come close to K390, not even on the same planet.....
It just blew everything else away (Production knives) I have seen yet and I am still in the process.
Won't get the Native until next week..Popsickle wrote:How is the native doing? K390 Millie would be awesome
Can you give an idea how long did it take to reprofile Native on 140 grit diamond plate and what angle did you reprofile it to?senorsquare wrote:I re-profiled the S110V the other day using a 140 grit diamond plate and then congress mold masters and I'd say it wasn't too bad either. Did not take as long as I thought it would and ended up with a very nice edge.
Are you sure about that? I thought K390 wasn't a knife steel..I quote Mr. Stamp:Ankerson wrote:Put it this way, no other production knife will even come close to K390, not even on the same planet.....
Philo Beddoe wrote:Are you sure about that? I thought K390 wasn't a knife steel..I quote Mr. Stamp:
"K390 isn't a knife steel, K390 is simply an attempt to increase the secondary hardening response of A11 which in general is a cycle which should be avoided in knives entirely because it sacrifices all other properties to gain heat resistance. This is why you will rarely see hot work tool steels used for cold work as they don't have an advantage there."
I was being sarcasticAnkerson wrote:Yeah OK...... ROFL
At 60% increase in edge retention over S90V I think Bohler would disagree....
