ATS-55: A Brief but Interesting Era in Spyder History
Invective
#61
Post by Invective »
JNewell wrote:How many of you guys pleading for 440V blades have actually owned, used and (here's the real catch) sharpened these blades? :spyder: :)
I've sharpened up a full SE Military, full SE Native and a Combo-Edge Chinook.
Not fun at all but diamonds are a guys best friend :D Not as bad as sharpening up S90V or S110V although the SE definitely present more of a challenge. Takes more care since you have to focus on the scallops but other than that I haven't had any problems.
RobC2
#62
Post by RobC2 »
Always enjoy these threads by JD Spydo.
JNewell
#63
Post by JNewell »
Invective wrote:I've sharpened up a full SE Military, full SE Native and a Combo-Edge Chinook.
My experience with S60V and S90V and S110V is that S60V is a lot harder to get a good edge on. I find it very hard to get rid of the wire edge on S60V with any medium, but I don't have any similar troubles with S90V or S110V. There may be tricks for S60V that I haven't learned. :)
NoFair
#64
Post by NoFair »
I've used my Lil'Temp extensively for several years. Sharpening is a bit slow, but not really difficult. Edge holding is good, not had any chipping issues either.
#65
Post by JD Spydo »
NoFair wrote:I've used my Lil'Temp extensively for several years. Sharpening is a bit slow, but not really difficult. Edge holding is good, not had any chipping issues either.
Even though this is an ATS-55 thread I can still appreciate where you all are coming from talking about 440V ( S60V) because I've always liked that steel better than it's successor S30V. Also the 440V era was happening at about the same time the ATS-55 era was in play. I truly think that both those steels were much better than AUS-6, AUS-8, GIN-1, or 3 others I could name.
I always thought that ATS-55 and 440V both would have been great in a fixed blade. But I will admit that I do like VG-10 slightly better than both of them which is why I like Spyderco>> they go with what they deem is the best and quality is truly the name of their game. But to this day I would never turn down a model I liked if it had either one of those blade steels.
Another thing I want to mention about the ATS-55 Era are the great new models that came out of that era and the great improvements on older/existing models that they switched and used ATS-55 on. The Rookie, the Big C-44 Dyad and the G-10 Harpy all should be in the Spyder Hall Of Fame that is if they ever have one.
Oh and by the way>> the one brother is absolutely right because 440V is truly a monster to sharpen in PE or SE
Donut
#66
Post by Donut »
JNewell wrote:My experience with S60V and S90V and S110V is that S60V is a lot harder to get a good edge on. I find it very hard to get rid of the wire edge on S60V with any medium, but I don't have any similar troubles with S90V or S110V. There may be tricks for S60V that I haven't learned. :)
Isn't the ultimate trick in eliminating any wire edge to use alternating strokes?
From just your statement, I assume you are doing free hand or using the edge pro.
-Brian
A distinguished lurker.
JNewell
#67
Post by JNewell »
Donut wrote:Isn't the ultimate trick in eliminating any wire edge to use alternating strokes?
Yes. Sharpmaker. S60V doesn't easily give up the wire edge, at least not for me using the SM. Have you had different results?
Invective
#68
Post by Invective »
JNewell wrote:Yes. Sharpmaker. S60V doesn't easily give up the wire edge, at least not for me using the SM. Have you had different results?
Is yours plain edge or SE? Maybe it's cuz I'm doing SE but I haven't had a problem with wire edges and don't have any PE to sharpen.
JNewell
#69
Post by JNewell »
invective wrote:is yours plain edge or se? Maybe it's cuz i'm doing se but i haven't had a problem with wire edges and don't have any pe to sharpen.
pe.
Donut
#70
Post by Donut »
I've never jumped on anything in S60V. Everything I had previously read about it makes it sound like there are better options.
-Brian
JNewell
#71
Post by JNewell »
That's sort of my point and why Spyderco switched. It's a great steel but it's tempermental. For most uses and most users I think it's fair to say there are better options today.
#72
Post by JD Spydo »
JNewell wrote:That's sort of my point and why Spyderco switched. It's a great steel but it's tempermental. For most uses and most users I think it's fair to say there are better options today.
I think the reasons that they changed from 440V in the Golden Colorado USA Earth Spyders and the reason they changed from ATS-55 to VG-10 on the Japan made Spyders are for completely different reasons all together.
440V was truly a monster to sharpen but the S30V bandwagon was so powerful and noteworthy knifemakers like Chris Reeve were really highly touting it at the time and most of the knife magazines said it was the best cutlery steel to come along in a generation. The people at Crucible told me that 440V was originally intended for the tool & die industry so it stands to reason that knife companies would accept S30V with open arms as many of them did in the early 2000s.
Now I can't really give you all a pin point reason as to why VG-10 dethroned ATS-55 but I do remember Sal saying a long time ago that they tested to 2 steels side by side and VG-10 won out so I'm guessing that must have been the sole reason. What is really initeresting about ATS-55 is that Spyderco as far as I know was the only American knife company to have used the steel commercially. I never even heard of any custom knifemakers using ATS-55 although I could name you a big bunch of big names that used it's predecessor ATS-34. I would really like to know the straight scoop about ATS-55 and how it came and went so fast.
It is interesting however that both 440V and ATS-55 were the mainline Spyderco blade steels during close to the same time span and both steels were used in many super classic collector Spyders. But the more I think about it I believe ATS-34 was used in fewer models than ATS-55 was.
Like the title to the thread I still do find it interesting that ATS-55 had such a notable mark in Spyderco history.
Donut
#73
Post by Donut »
JD Spydo wrote:But the more I think about it I believe ATS-34 was used in fewer models than ATS-55 was.
Noooo!
I've been wanting an ATS-34 blade. I guess I need to go full throttle on finding one.
By the way, I really like reading this thread. :)
-Brian
#74
Post by JD Spydo »
Donut wrote:Noooo!
One model in ATS-34 that I always wanted but just never was able to snag and that is the Jess Horn model C-27 with the stag handle. It is one of the very few Spyders that didn't have the hole in the blade>> it had a trapezoidal indent instead of the hole. Two other ATS-34 models were the titanium Salsa and the late 90s Military model.
Like I said there were not many Spyders made in ATS-34 but it does seem like all of them were special models.
Donut
#75
Post by Donut »
I was reading that about the hole-less models on Paul's website the other day.
I'm 99% sure there is a model with NO hole in the blade, but I can't remember what that model was.
There is a lot of interesting history to talk about in this thread.
-Brian
#76
Post by JD Spydo »
Donut wrote:I was reading that about the hole-less models on Paul's website the other day.
That C-27 Jess Horn model didn't have a hole>> I had a friend that had both the PE & SE C-27 models. The serration pattern on the C-27 is a very unusual pattern and I never seen it on any other Spyder. The C-27 was the most unusual Spyder ever made. Also I believe the handle scales on that knife was real sambar stag from what I'm told.
Donut
#77
Post by Donut »
Now that I look at pics of the C27, yeah, that's the one I was thinking of. Interesting serrations, no scallops.
-Brian
yowzer
#78
Post by yowzer »
JD Spydo wrote:What is really initeresting about ATS-55 is that Spyderco as far as I know was the only American knife company to have used the steel commercially. I never even heard of any custom knifemakers using ATS-55 although I could name you a big bunch of big names that used it's predecessor ATS-34. I would really like to know the straight scoop about ATS-55 and how it came and went so fast.
From what I remember of the research I did (Searching here and Bladeforums) when I first got an ATS-55 Dyad, it was a collaboration between Hitatchi and Spyderco to make a cheaper variant of ATS-34 that worked as well for knives, while sacrificing some of the high speed/temperature characteristics of -34 that weren't needed in a knife blade. I don't think it was ever offered up to other companies to use.
Newest :spyder: in hand: Halloween Handle Hap40 Endura and Delica.
#79
Post by JD Spydo »
yowzer wrote:From what I remember of the research I did (Searching here and Bladeforums) when I first got an ATS-55 Dyad, it was a collaboration between Hitatchi and Spyderco to make a cheaper variant of ATS-34 that worked as well for knives, while sacrificing some of the high speed/temperature characteristics of -34 that weren't needed in a knife blade. I don't think it was ever offered up to other companies to use.
I think you are absolutely right about that "yowzer" because I've never seen another ATS-55 blade made by any other company over the years. I would have to look at my old past issues of "Tactical Knives" magazines because they did a write up on it once in their section called the "Steel Bin". And From what I can remember they were the ony ones that ever did a review on it. I always had fairly good luck with ATS-55 myself and would still use a knife made with it and I still do use my original C-44 Dyad whenever I venture out in the woods. It seemed like a good steel for Spyderedges too.
Donut
#80
Post by Donut »
I was looking through my "storage" for Foliage Green stuff to compare the Elmax Para with... and I didn't trade both ATS-55 Rookies away!
I will try to give it some use. :)
I found the Cricket (it was right infront of me) and on close inspection, the tip was banged up and someone straightened the tip out. I will probably use my arc'd DMT stone and try to make it a hook again.
-Brian
