Excellent MR. You can even see the imperfection (a bit blurry) in the print on the paper in the reflection on your edge bevel. Or, is the print on your bevel and it is reflected by the paper? :) Hard to tell a difference. Now you have the perfect edge you have been searching for. :D What WILL you do now? :)
Here is an edge I altered a bit on a CRKT Stubby. I couldn't help but buy this knife when I saw it. I still haven't needed the chisel tip when working instead of needing to run and get a chisel but I'm hoping one day I will. :) I felt the bevel needed to be MUCH lower on what I would use as the bottom (flat side) of a chisel.
Sorry it's not a Spyderco. Maybe I'll grind down my Chaparral 2 to a chisel tip stubby? :eek:
Holland wrote:looks amazing jack! but i cringed when you said you would do that to a chap2
Thanks, and thanks MR also. As long as I got one cringe out of that joke I'm happy. :) I have the edge in good shape to use as a chisel in a multi-tool type situation. Meaning if you need a REAL screwdriver the one on a multi-tool may not do or would be a little awkward. For intricate work the blade spine might be in the way (for chisel type work) but the 90 degree angle (on the blade) makes for a VERY sturdy cutting tool right at the tip/corner. What really pisses me off is I physically can't do the work I now have knives for. Back issues. But this knife gives a knife carrier a lot of different abilities with such a different blade. I carry it even if I don't use it much. :D If I buy it, I'm gonna at least carry it or trade/sell it. :D
