Page 2892 of 2925
Posted: Fri Feb 27, 2026 12:40 pm
by 8th_Note
Rookie Spyderedge in ATS-55
Posted: Fri Feb 27, 2026 1:14 pm
by BeggarSo
That's cool was this before the Police? They look a bit alike.
Posted: Fri Feb 27, 2026 1:42 pm
by 8th_Note
it's the small version of the 1st gen Police. 3" blade and 6.75" OAL. Produced from 1998 - 2000
Posted: Fri Feb 27, 2026 7:44 pm
by mikey177
CruWear Smock
Posted: Fri Feb 27, 2026 8:46 pm
by sv4
Spyderedge Saturday : Rescue 93mm with finger indexing cutout.
Posted: Sat Feb 28, 2026 2:10 am
by Wartstein
Skitouring with - no surprise here - the featherlight superperformer Salt 2 SE...
Posted: Sat Feb 28, 2026 4:33 am
by Paul Ardbeg
Posted: Sat Feb 28, 2026 4:46 am
by jwbnyc
Posted: Sat Feb 28, 2026 5:17 am
by Aladinsane
Posted: Sat Feb 28, 2026 5:20 am
by Manixguy@1994
ImageMG2
Posted: Sat Feb 28, 2026 9:38 am
by Stas
Beautiful knife. I love the ergonomics and the hollow grind on this 20CV blade... Unfortunately, my example also has the issue I read about here: on the show side, the blade sits too close to the scale. I even feel like there may be slight marks on the blade from it touching. I’m still not sure what to do about it.
Posted: Sat Feb 28, 2026 1:06 pm
by magicdad
The Spyderco Cricket (plain edge) which arrived 10 minutes ago.
Posted: Sat Feb 28, 2026 1:34 pm
by anycal
Posted: Sat Feb 28, 2026 4:01 pm
by Tristan_david2001
One my first favorites from spyderco, awesome, unique, and highly functional little piece, hope it serves you well sir
Posted: Sat Feb 28, 2026 4:08 pm
Fri Feb 27, 2026 3:17 am
Tristan_david2001 wrote:
Thu Feb 26, 2026 3:00 pm
As usual I’m carrying a knife from the caly/calypso family.
Today I’m carrying my og calypso jr. One of if not my favorite knife of all time..
I put a fresh new 17 degree edge on it today for the first time and it’s sharp as a razor, always feels good when one of your favorite performing and looking knives has a super sharp edge on it.
Also hi fellow spyderco forum community, hope ur all doing well
Nice!
/ You've been away from the forum fir a while?
A little while yeah. I still check in pretty regularly but haven’t posted much in a while
Posted: Sat Feb 28, 2026 6:39 pm
by Wowbagger
I am very relaxed with my knife hobby .
I give myself permision to leave some marks on the sides of the blades from rubbing on the deck of the Edge Pro .
. . . scratches on the blade ? Sure ; they get that way from using them .
(when I resharpen this Endrua I will put box tape on the blade to protect this patina ; has some nice blue in it so I want to keep the patiina as nice as I can )
But mostly I am pretty relaxed about the way they look as long as they make me smile when I cut stuff .
I took the oval dot of gun grip film off the Endura and put it on the Pattadese to see how it would stick after first being on the other knife . Surprisingly good . (you got to heat it up with a heat gun to get it to stick tight in any case .)
I bought this second Pattadese quite a while ago to cut jimpping grooves into the sides of the G-10 . Then I discoverd the grip film a couple years ago . So far so good .
I will probably cut more of the excess hot glue from around the edges of the grip tape but just did this last night and wanted it to "harden" as much as possible first .
In case you didn't see this in the handle material thread ; I filled in the FRN pattern with two layers of hot glue , let them harden then added the grip tape.
Lumpy but it sure works .
So these were with me at work today .
Posted: Sat Feb 28, 2026 7:07 pm
by Wowbagger
You could try loosening all the handle screws , then put a dense cardboard shim between handle and blade then tighten all the screws . First shim to center it and if it goes back too far to that side when you remove the shim then maybe shim it to where it is off center to the opposite side .
Cool knife in any case .
Posted: Sat Feb 28, 2026 11:43 pm
by Wartstein
BeggarSo wrote:
Fri Feb 27, 2026 6:34 am
Ya just gota Get a Gooney!!
This must be a great combo indeed! (Though from real experience I can only talk about the green part of it yet...;) )
I am a bit torn between getting a Gooney or a Retract next... "torn" in the way that the solution probably will be the usual answer here: "Get both"... ;)
Posted: Sun Mar 01, 2026 12:32 am
by sv4
Salty Sunday : Salt 1 from 2004.
Posted: Sun Mar 01, 2026 5:03 am
by Manixguy@1994
ImageMG2
