Show your mods!
Jazz
#401
Post by Jazz »
jasperwilkens wrote:Gday guys, this is my first post and I thought I would share my EDC with you all. I have been waiting to see if there are any other stretch mods out there.
Welcome, Jasperwilkens. Cool - does that notch wave the knife open?
- best wishes, Jazz.
jasperwilkens
#402
Post by jasperwilkens »
Yes, it works quite well if you draw the knife horizontally out of the pocket. As the notch is shallow I can easily pull the knife from pocket without engaging the 'wave' if desired.
jasperwilkens
Stretch mod
#403
Yes the notch is quite effective if the knife is drawn horizontally from the pocket. As the notch is shallower than standard wave pattern it is easy to draw the knife without engaging the 'wave' action.
Douglas
#404
Post by Douglas »
So I wanted a Delica with a wire clip and a finger choil....
Functionally it's a failure, but the project was basically just to learn what's required. The wood is just a bit of oak I picked up from the Home Despot that I'm sure isn't stable enough to last. Then I wasn't quite accurate enough drilling the holes, and so the pivot screw doesn't get enough purchase on the scales and never tightens up properly. Horrible blade play. I'm sure I can solve those problems with a second attempt from better material. Think I might take a file to the ricasso to improve the choil, too.
Jazz
#405
Post by Jazz »
Douglas wrote:So I wanted a Delica with a wire clip and a finger choil....
Well, it certainly looks good. Thanks for sharing, and I hope you like your next attempt better (trust me - you can't stop the addiction ;) ).
KnOeFz
#406
Post by KnOeFz »
I love the work you guys did :)
Here's my Kiwi 3, inspired by Piet who also provided me with tips and materials:
:spyder: I don't mind going nowhere, as long as it's an interesting path. - Ronald Mabbitt
Piet.S
#407
Post by Piet.S »
That came out real nice.
Good work, well done.
All your knifelinks, http://www.knifelinksportal.com
Jazz
#408
Post by Jazz »
KnOeFz wrote:I love the work you guys did :)
Call me a dumbhead, but what did you modify? :o
Douglas
#409
Post by Douglas »
Jazz wrote:Call me a dumbhead, but what did you modify? :o
Kiwi 2 came in CF, but the Kiwi 3 is only in stainless or stag.
I've got a second set of wood Delica scales up to final sanding. Much better tolerances on the holes on this set, and made from a slab of cherry that had been sitting in Dad's shop for several years, so I'm optimistic they'll actually work.
KnOeFz
#410
Post by KnOeFz »
The original looked like this (stag, but my stag was less nice (more white, less structure) then this picture):
korbiaka
#411
Post by korbiaka »
I didn't do this mod, the knife was sent to me to refurb, but I really liked how the ATR looked without the hump at the blade tip. Figured others may want a peek at it too.
Jazz
#412
Post by Jazz »
KnOeFz - Sorry, I didn't even realize it was lockless. It looks great. Nice work. :cool:
korbiaka - That looks pretty cool done that way. Thanks for sharing.
BAL
#413
Post by BAL »
I can't look at this thread without wanting to run out and buy a dremel and order more knives.
Jazz
#414
Post by Jazz »
BAL wrote:I can't look at this thread without wanting to run out and buy a dremel and order more knives.
Do it. Try something on a piece o' crap butter knife or something - play around until you feel comfortable with the tool and then give 'er. :D Even if you don't like it, Dremels are useful for tons of things - great tool to have.
Bladespec
#415
Post by Bladespec »
Inlayed cf dogg, the kiwi slippie dont come in cf braa..
I have 8 :spyder:'s More to trade and more to come!
GRIFFIN HAWKS
#416
Post by GRIFFIN HAWKS »
The best way to use a Dremel Tool is to let the high speed do the work with a light touch (^;
Otherwise - You will chew up bits in seconds :eek:
That sucks cuz their not cheap !
START ON A HIGHER SPEED AND WORK DOWN FOR THE DESIRED EFFECT AND CONTROL (^;
BE WELL .. GH
Be really careful with Dremels and the high speed and for God's sake WEAR SAFETY GLASSES. Also, be selective of what brand bits you use...the cheap ones are notorious for coming apart at high RPM and you don't want pieces hitting you in the face when coming off a bit that's spinning at 30k RPM.
korbiaka
M4 Millie
#418
Post by korbiaka »
korbiaka
one more m4
#419
Post by korbiaka »
Donut
#420
Post by Donut »
Nice collection of M4 Millies. :)
-Brian
A distinguished lurker.
