What Knife would benefit from a button release.
Re: What Knife would benefit from a button release.
I love the button conversion idea to reduce hot spots when using it heavily. I'm not a fan of how proud that button looks like it is on the Ultra mod.
Regardless, I would like to have one some day.DansGearAddiction wrote: ↑Mon May 08, 2023 11:59 pmThis is just my opinion, but I feel that button-locks are a fad that will slowly start to die down as the market gets over-saturated.....
Mongo1958
****John3:16****
Is it true? Is it kind? Is it necessary?
****John3:16****
Hi Mushroom,
I don't know why we'd collaborate when we invented the lock, including the button version and we designed the knife?
I guess I don't know why you’d collaborate with them either.
In that case - when Spyderco releases a Paramilitary 2 with button compression lock it will be a game changer.
- Nick
Sal,
Is there a chance that Syderco will produce a compression lock knife with a button release?
Thanks
Mongo1958
****John3:16****
****John3:16****
It probably needs to stick out that fat to have enough travel for the lock to release, and that's probably one of the challenges of this design. It's similar on the Autonomy's, and I imagine it could suck a lot more for a lefty than for a righty. I personally don't even notice it's there, and particularly with the Autonomy there is tactile similarity between the feeling of a thumb hole and the feeling of the firing button and I really like that, it becomes very intuitive to use and feels natural. I'm not sure how they could do that with a manual opening knife but it would be pretty cool. The button on those does stick out a good bit when opened though and would always stick out further when the knife is closed since the lock bar is pushed all the way against the G10.
Safe bet - a Para 2 variant, that doesn't outright replace the standard version unless it ever reaches a point where the sales favor the button version so much that it makes sense to replace it.
My wish - Do that with the Shaman.
Or, if you're still developing a no choil Shaman, maybe double down and try to work that in too if it's going to be a compression lock design. Then you'll be bringing out a new model and that'll be an additional selling point.
- Buddafucco
I would think something like a Micarta Shaman would be a good candidate. Having the thicker scales might allow for a recessed divot area around the button. Possibly less button sticking out and/or also kind of a safety like the Boye detent?
•• Beau
What are peoples thoughts on the side for the button?
Would index finger or thumb operation be better? Either would be possible given both RH and LH models are produced.
ETA: Nvm after trying different grips etc myself it seems best it would be on the front / thumb side to prevent accidental disengagement.
I see, said the blind man.
Buddafucco wrote: ↑Wed May 10, 2023 4:02 pmI would think something like a Micarta Shaman would be a good candidate. Having the thicker scales might allow for a recessed divot area around the button. Possibly less button sticking out and/or also kind of a safety like the Boye detent?
I can not overemphasize how good this idea is. That sir is genius. It could potentially be done without the button actually sticking out beyond the surface of the handle, and a recess in the G10 would provide a good tactile sense for where the button is.
Mule
Mule Team Army 001
MNOSD 008
MNOSD 008
Awesome!
It would be really great if the Military 2 with SE, the PM2 with SE, The Shaman with SE, and the Native Chief with SE could be considered for the first round of the button release knives.
Thank you Sal.
Mongo1958
****John3:16****
****John3:16****
Evil D wrote: ↑Wed May 10, 2023 5:39 pmBuddafucco wrote: ↑Wed May 10, 2023 4:02 pmI would think something like a Micarta Shaman would be a good candidate. Having the thicker scales might allow for a recessed divot area around the button. Possibly less button sticking out and/or also kind of a safety like the Boye detent?
I have rather little experience with any kind of button operated locks (unless one counts the axxis lock "lock tabs" "buttons" - they are really not in use in a traditional sense)
So my only concern and possible con about / in a button comp.lock would actually be accidental release during hard use (which, as said, I can recall two times being mentioned on this forum even concerning the current "tab" comp.lock).
Is this likely in any way?
Recessing the button a bit would certainly a remedy for that then, right?
Wartstein wrote: ↑Wed May 10, 2023 11:37 pmEvil D wrote: ↑Wed May 10, 2023 5:39 pmBuddafucco wrote: ↑Wed May 10, 2023 4:02 pmI would think something like a Micarta Shaman would be a good candidate. Having the thicker scales might allow for a recessed divot area around the button. Possibly less button sticking out and/or also kind of a safety like the Boye detent?
I'd say it's possible, but I don't know if I'd say it's more or less possible than a back lock. One of the worst cuts I've ever had was from a back lock that I squeezed too hard and unlocked it and it folded onto my pinky finger. I'd say it depends on where your grip is positioned during use, and if they did use a Shaman and are able to recess the button that would make it far less of a concern.
