Yes, 100% agree here. This would probably be #1 on my wish list.electro-static wrote: ↑Fri Mar 17, 2023 12:37 pmI think the biggest gap is: thin in the pocket slicey folders with a good blade to weight ratio.(skinny knives with a minimal pocket footprint).
Some sprints and colabs are, but in terms of regular production spyderco knives there isn’t much there to compete with the likes of a benchmade bugout or 940 osborne in terms of pocket footprint.
Biggest gap in the Spyderco lineup?
Re: Biggest gap in the Spyderco lineup?
NON salt MAGNACUT
The biggest gap that I see is that despite having an amazing Salt line, Spyderco doesn't have a really good PFD knife. The Enuff Salt was one of my early Spydercos and even several years later I still keep trying to like it, but the sheath retention just isn't adequate. I also find the Enuff a little heavy and clunky for that purpose and I'd love a thinner and lighter PFD knife to appear in the salt line someday.
Good one. I use the Saver Salt for a PFD knife, but I'd much rather have a fixed blade. The Saver is so wide that it'll barely fit in my PFD's pocket that was specifically designed for carrying a knife, so it's hard to get it out. I have an Enuff Salt, and this spring I'll probably attach its sheath to the kayak, since the knife itself is fine, it's just heavier than I'd like.SchoonerBum wrote: ↑Fri Mar 17, 2023 3:50 pmThe biggest gap that I see is that despite having an amazing Salt line, Spyderco doesn't have a really good PFD knife. The Enuff Salt was one of my early Spydercos and even several years later I still keep trying to like it, but the sheath retention just isn't adequate. I also find the Enuff a little heavy and clunky for that purpose and I'd love a thinner and lighter PFD knife to appear in the salt line someday.
A good solution, I think, is to simply make an Enuff 2 sheepfoot version with its thinner bladestock, in the original blade length and in a Salt steel.
have you guys seen the kydex sheaths that are designed to deploy a folder when you draw it out? i wonder if something like that would work.
I've never seen a sheath like that! Any suggestions?
I had never heard of them until you mentioned it. Now I've watched some YouTubes showing them. Sure it would work if I had one custom made for a Salt folder.
Several times I have almost sacrificed a Pacific Salt SE to make a PFD knife by totally rounding the tip to semi-circular, and dulling the portion of the non-serrated edge that was left. Such a knife with an auto-deploy sheath could be the ticket. The knife by itself would just be an even bigger Saver.
Still, I'd rather just have a blunt fixie with a truly lightweight kydex sheath that could be paracorded to my PFD. All of this has gotten me thinking about it again, so now I need to go mess with varius PFD/knife combos.
dsm wrote: ↑Thu Mar 16, 2023 4:49 pmI've been getting acquainted with the forum, and was inspired by Jazz's thread which led to the Delica wharnie (here: viewtopic.php?f=2&t=70607). In the spirit of that thread, what is an area of the current Spyderco lineup (i.e. not including retired models) that you think leaves something to be desired?
[*] A smaller knife with the BBL, like a mini-Manix 2 or Manix 2 LW. The Manix is a bit large for my use, but would still like to carry a BBL more frequently.
[/list]
What do you think?
Another year, another thread of bumping up the Para3-sized Manix, to complement Spyderco's Military/Paramilitary2/Para3 lineup. Maybe this is the year that Eric will listen?
Those are explicitly banned in Massachusetts and I suspect it’s not the only state. Might be worth looking into local jurisdictions for anyone considering one of those sheaths.
- Nick
thanks for the heads up! i hadn't thought of that. sounds about right for massachusetts though. i'll have to see if i can find anything in florida law about it.
Coastal wrote: ↑Fri Mar 17, 2023 6:41 pmI had never heard of them until you mentioned it. Now I've watched some YouTubes showing them. Sure it would work if I had one custom made for a Salt folder.
This is what I use: REI has them and if you’re a co-op member you can get 20% off certain times like right now!!!
- Naperville
Black Bear Custom Kydex did do them but I don't see it on his website anymore. He did one for me that deployed a Spyderco Military S110V. I sold the knife and kydex sheath as one unit about 3 months ago on AZCK.
https://blackbearck.com/
EDIT: Auto Deploy Sheaths
https://blackbearck.com/products/
I have one, but it's steel. I should have bought the titanium one, but I'm not even sure it was available when I bought mine. The steel one will rust just sitting in my garage, so I don't use it. It's a good idea, though, and now that you brought it back to my attention and I've discovered the Ti version, I'll probably give it another look. Thanks!SaltyCaribbeanDfly wrote: ↑Fri Mar 17, 2023 7:26 pmCoastal wrote: ↑Fri Mar 17, 2023 6:41 pmI had never heard of them until you mentioned it. Now I've watched some YouTubes showing them. Sure it would work if I had one custom made for a Salt folder.
In current production the Ikuchi is king (as mentioned earlier)dsm wrote: ↑Thu Mar 16, 2023 4:49 pm*snip*
[*] A thin, light, low-height EDC blade. Something in the 2.5"-3.5" blade length range would make sense. I love the Delica and enjoy my Para3 LW as well, but I think the Spydie-hole in both of these causes the knife to jut into the pocket too much in certain situations. I'm thinking of something like a thiner Smock with less choil and recessed liners.
*snip*
My fave in that department, tho discontinued, is the Baby Jess Horn. You could get lucky and find a NIB example for not too much.
It does have an old school traditional vibe. I like mine a lot. I carry it clipless with a bead. The clip is meh.
https://www.spyderco.com/catalog/detail ... rade-/1061
More mid to high end linerlock models. Especially in the more "hard use/outdoor department", so something like a linerlock Caribbean or linerlock Shaman.
To get us started, I would love to see three new things:
- A larger (3") version of the Dragonfly with a high edge hardness/retention tool steel. Preferably still as thin as possible. I know the Caly Jr. is a past favorite, but unfortunately they are no longer in production.
What do you think?
That ! A 2.75''-2.90'' Dfly would be a helluva folder. The ultimate spyderco for me.
Marius
( Rabindranath Tagore )
I purchased the Ti blunt Neko last night. Thanks for reminding me of this concept in general!SaltyCaribbeanDfly wrote: ↑Sat Mar 18, 2023 7:43 am
Found the Ti version…just wish Sal would make one in magnacut w/a tiny trademark hole in the blade section
My kayak knives will now consist of the Ti Neko on my PFD, and a Pacific Salt loose in the boat. Lance wouldn't agree with this, but I consider my Waterway and Siren too valuable to risk over the side.
