Anyone use a safety razor?
Re: Anyone use a safety razor?
I did for some time, but it was too annoying and sometime dangerous especially around the neck area. I use a metal safety razor now and I don't regret it one bit.
A metal safety razor, as in one you put a single double edged blade in, and not one of those disposable top multi blade things?
The Henson I bought my wife is supposed to be safe and not cut your skin. Some guys use them when they need to shave in a hurry because they do not have to worry about getting cut. When hers comes tomorrow or the next day, I am going to shave with it and find out. I'll let you know. They are not expensive and the blades are 10 cents and don't fill up landfills with plastic.
- kennethsime
Dan, that Henson you linked looks really cool - please let us know how your like it once it comes in. I think that's the first time I've considered buying another razor.Doc Dan wrote: ↑Mon Dec 13, 2021 8:21 amThe Henson I bought my wife is supposed to be safe and not cut your skin. Some guys use them when they need to shave in a hurry because they do not have to worry about getting cut. When hers comes tomorrow or the next day, I am going to shave with it and find out. I'll let you know. They are not expensive and the blades are 10 cents and don't fill up landfills with plastic.
I'll let you know. it should be here tomorrow or the next day. I hope to be able to test it tomorrow night. Right now, it has to beat my EJ DE89, which out shaves my Razorock Game Changer with either head (although by a small margin). However, I've been told to expect a mild feeling smooth shave in which I will not think the blade is doing anything and then find my face surprisingly smooth. I called Henson and spoke to one of the owners named Jonathan (I think). Nice guy. He recommended that I buy the medium for myself. He said I will get a good shave with the standard that I bought my wife, but the medium might be more to my liking because I shave with those other two razors and like them. He also said that the categories of efficient, aggressive, and etc. do not apply the same way with Henson razors as with regular razors. The Henson experience is different. We'll see. If this works out, this could be the razor that allows fast shaves when in a hurry without worry of getting cut.kennethsime wrote: ↑Tue Dec 14, 2021 8:47 amDan, that Henson you linked looks really cool - please let us know how your like it once it comes in. I think that's the first time I've considered buying another razor.Doc Dan wrote: ↑Mon Dec 13, 2021 8:21 amThe Henson I bought my wife is supposed to be safe and not cut your skin. Some guys use them when they need to shave in a hurry because they do not have to worry about getting cut. When hers comes tomorrow or the next day, I am going to shave with it and find out. I'll let you know. They are not expensive and the blades are 10 cents and don't fill up landfills with plastic.
If anyone is interested, I found a great forum called Badger and Blade to hang out and discuss razors (including straight razors and safety razors) and everything related to shaving.
My wife's new razor. It shaves really nice, as long as you keep that flat angled part on your face. Then, you have no blade feel at all and it shaves nice and close. This is the mild version. I am going to get a medium in January. I am not sure what color, though. I am torn between blue, that golden brassy tan, black, or Military Green (Olive).
- kennethsime
Green for me, but I’ll wait for your review. ;-)
With the mild, which is the normal one, I got a good shave when I held it the way intended. When held properly and without pressing, the razor felt so smooth it was as if I were simply wiping off the foam. There was no blade feel at all, then.
I'll let you know about the medium, but it will be next month, sometime. This is a nicely made razor. All of the tolerances are extremely tight and the tungsten insert to keep aluminum on aluminum scraping when putting on the handle fits like it was molded into the plate. Very nice touches. The top cap, where you load the razor, has two protrusions, like normal. These fit into two corresponding holes in the lower plate that is a very exact fit. Because of this, there is no wiggling of the blade, even before putting on the handle. Really nice.
The fact that this company makes parts for satellites, the Mars Rover, the International Space Station, and a lot of other things that require tight tolerances and extreme quality really shows up on the razor.
Bloke is back and at it, again!
- kennethsime
Hey I’m not fat, just big boned!
I figured out the riddle of the Henson. It has a different angle for shaving than my other razors by about 10*. My other razors shave at close to 30*, but the Henson is pre-set at maybe 35* to 40* or something. Anyway, once it is on your face at the right angle it is amazing.
I have been experimenting with different blades in my Edwin Jagger DE89 and RazoRock Game Changer .68-P and .84-P. For my face (only) I have found that the Feather blade in the DE89 is unbeatable. The shave is close and smooth. However, the Feather in either Game Changers is slightly harsh for my liking (me only), though I get a good shave. I tried Gillette Wilkinson Sword in all of them and did not like that blade at all. It was snagging and dragging. I tried the milder Rapira blade in the Game Changer .84 and while that did tone it down, it was still not as smooth and gentle as the DE89. I am going to try it in the .68 later with a 24 hour beard and see what that is like. Next up will be the Voshkod blade.
Okay. I put the Rapira blade in the Game Changer .68 and it did a wonderful job. So, apparently, since these razors are a bit more aggressive than my DE89 they need a slightly milder blade. Nice to know.
Tomorrow I am going to try the Feather blade in the Henson (before I had an Astra in it) which is uber sharp.
Very interested in this, subbed!
Okay. I used the Feather in the Henson and it did really well. I mean, I got a shave as good as I can get, or better with any multi-blade throw away or cartridge razor. Two passes and done.
Yesterday, I got out my Game Changer. I was thinking of selling it because, though it shaved close, it was sort of harsh. At the advice of the guy at the shop I put a milder Voshkod blade in it and WOW! The shave was baby butt smooth in only two passes. My wife even commented on how smooth my face was. Not only that, the razor itself was very smooth on my skin. No harshness, no dragging, no pulling, just smooth and gentle.
Fascinating. I’ve always operated under the assumption that a razor blade is a razor blade. Clearly not. Would you describe the blade by sharpness only, or is there a degree of spring stiffness that plays a part in their performance? I can see how the Henson would be unaffected by any blade springiness since it is so thoroughly supported out to the edge. But other models seem to have varying degrees of unsupported blade material.
