Page 3 of 3
Re: Very Disappointed
Posted: Tue Jan 01, 2019 11:08 am
by Lodestar
Just a suggestion for part of your issue (even though I know you don't want to deal with this on a new knife):
To loosen, you can try heating the pivot a bit with a hair dryer or some hot water to loosen it up, obviously with the latter you will need to blow out the knife with compressed air or flush it with alcohol/cleaner/oil.
If you are/were able to loosen your pivot and the action is not "drop free" or able to "flick" like you want:
Try to loosen the lock bar screws (smaller screws next to the pivot) and see if that frees up the action.
I did that on my first PM2 out of desperation after the pivot screw did almost nothing to free up the blade action to what I saw in videos (cue some cursing of spyderco and the koolaid drinking compression lock lovers on my part). For some reason that immediately and forever freed up the action, and made the blade drop free, even surprisingly after tightening the lock bar back to quite snug (cue, ahhh that's why people like the compression lock). Seriously a 10 second fix to massive frustration.
Would suggest this to anyone who has a PM2 with a "drop free" action that performs poorly, or less than others they have handled.
Posted: Tue Jan 08, 2019 9:48 am
by Brianv
Sal, I put the knives in the mail to Golden yesterday. Thank you.
Posted: Tue Jan 08, 2019 10:28 am
by Wartstein
If you'd care to report back how it went then, I'd apreciate that. Though I am sure Spyderco will take good care of you anyway. :)
Howsoever, enjoy your knife when it comes home to you again! ;)
Posted: Tue Jan 08, 2019 1:41 pm
by Brianv
I will report back when the knives get back to me.
Posted: Tue Jan 08, 2019 1:59 pm
by Wartstein
That'd be nice!
Posted: Tue Jan 08, 2019 9:30 pm
by Orianatristana2
Firstly, you should calm down and then try to fingure out your issue, if not, you can try to contact to Admin via email directlt
Posted: Tue Jan 08, 2019 10:10 pm
by sal
Hi Brianv,
Thanx, I'll alert customer service.
Hi Orianatristna,
Welcome to our forum.
Posted: Thu Jan 24, 2019 9:13 pm
by Brianv
Thank you Sal and thank you Spyderco! I received our two PM 2's back today and I couldn't be more pleased! The work was done very well, exactly the way I asked and returned within their turn around time. I think they went above and beyond what they had to do. Thank you again, Sal and Spyderco!
Posted: Thu Jan 24, 2019 10:33 pm
by Wartstein
Thanks for reporting back, enjoy your knives! :)
Posted: Fri Jan 25, 2019 1:12 am
by emanuel
I think you might be venting on the wrong issue here. I had a similar problem, but not knife related. The culprit: my screwdriver bit was harder than the screws, so it was damaging them in this same way. A proper screwdriver steel should be softer than the screws so that it wear itself out instead of the screw head. Its one of the few cases where you want your tool to wear instead.
Posted: Fri Jan 25, 2019 3:42 am
by archangel
See I told you it'll be fixed.
Posted: Fri Jan 25, 2019 5:37 am
by Bloke
Posted: Wed Jan 30, 2019 8:23 am
by SpyderSeth
What is the current turn-around time for repairs? I have one in transit back to Spyderco.
Posted: Sun Feb 10, 2019 7:42 am
by Brianv
When I sent my knives back to Spyderco the turn around was three weeks.
Posted: Sun Feb 10, 2019 8:16 am
by Doeswhateveraspidercan
From within the U.S. I experienced about the same 3 weeks turn around with shipping both ways not bad at all . As I recall mine was closer to 2 1/2 weeks
Posted: Sun Feb 10, 2019 8:24 am
by SpyderSeth
Thanks. They told me 4-6 weeks, but I assumed that was just the default answer. They have had the knife for 10 days, so hopefully not too much longer.
Posted: Sun Feb 10, 2019 11:46 am
by knivesandbooks
Just for comparison, Spyderco took less time than other companies, for me. The three times I've sent to Spyderco it took a month. I've sent 2 to Benchmade and they were 6 weeks both times and one to ZT that took 2 months. I haven't done a warranty or anything else anywhere else so I don't have other comparisons.
Posted: Sun Feb 10, 2019 5:32 pm
by npad69
Not being condescending or anything but I hope they didn't use philips driver on those. I've seen a lot of my friends commit the same mistake not realizing there are screwheads other than flathead/standard and philips.
Been using el-cheapo chinese torx drivers on mine and I never had any problems (even with loctite)
Posted: Sun Feb 10, 2019 7:29 pm
by Pelagic
Uhh, what? I just read that and it translated in my head as:
"I'm not saying they're stupid or anything, they just did one of the dumbest things imaginable".
Lol!
