Am I the only one?
Pelagic
Re: Am I the only one?
#41
Post by Pelagic »
Bloke wrote:
Thu May 31, 2018 7:39 pm
Spydergirl88 wrote:
Thu May 31, 2018 7:13 pm
I've been practicing today and the best I can do is 3/4 open. Previously it was only 1/2 open :p baby steps
This may help ... if you’re trying to flick with your middle finger, hold your index finger parallel to the handle/scales. :)
I figured this may benefit from an illustration.
https://youtu.be/wKTYxk8dewk
Pancake wrote:
Wed Aug 14, 2019 10:20 pm
Are you a magician? :eek:
Nate wrote:
Thu Apr 04, 2019 4:32 pm
Doeswhateveraspidercan wrote:
Sat Jun 15, 2019 9:17 pm
You are a nobody got it?
PaleMoon
#42
Post by PaleMoon »
I can't flick most Seki lock backs without completely shredding my nails. Besides, it requires so much concentration and weird hand contortions that it just isn't worth the time or effort in the end.
On the other hand, I can flick most liner locks without issue, both in regular and reverse grip. I usually won't flick the ones with the over-sized opening holes, however, as my fingers tend to get stuck in them.
The problem of a coherent civilization is the problem of living with ignorance and not being frustrated by it.
JT
#43
Post by JT »
Try the Yo2.
The thing just flies open with middle finger.. and it feels natural once you do it a couple of times.
qwkzotc
#44
Post by qwkzotc »
JT wrote:
Fri Jun 01, 2018 5:06 am
Try the Yo2.
This is a great lead in to my response. I could never flick my Spydies with middle finger and was amazed by the videos. Then, got a Yo-2 one day and it worked just fine. Suddenly found that it worked with all others. I'm thinking the YoJimbo is a good starting point/trainer for this technique, at least for me.
Ric
#45
Post by Ric »
Try to use the middle finger flick.
Try both hands - sometimes non dominant hand works better.
Compression locks are pretty easy to flick.
SF Native
#46
Post by SF Native »
Pelagic wrote:
Thu May 31, 2018 9:24 pm
I think this video is good. For smaller hands, technique and the right knife is important. Pm2, para3. Any compression lock should do. My lil temp is the best for me. Don’t just flick perpendicular to the scale. The flick is more up in the direction that the blade will be pointing. Adjust hands to give as much follow through as possible. Just my 0.02
#47
I learned the thumb and middle finger flick on a Persistence. It took a little practice at first but now it's second nature for me. I never try to flick my back locks. It doesn't work very well for me and I think it's hard on the locks.
The key for me is how I hold the knife. I use my thumb to press the butt of the handle into my palm. The index finger is near the pivot providing support. Like SF Native said, follow through is important.
Pelagic
#48
Post by Pelagic »
Lol, sometimes all it takes is (a) persistence.
#49
Successfully middle finger flicked open my dlc lil native on the first try! I was so excited lol
Ric
#50
Post by Ric »
Well done!
:D
NoFair
#51
Post by NoFair »
Easy on some, but I always thumb them open in normal use. More controlled and more than fast enough.
