work knife suggestions.
JAfromMN
Re: work knife suggestions.
#41
Post by JAfromMN »
GoldenSpydie wrote:
JAfromMN wrote:I won't get another lwt manix unless I find a awesome deal. A s30v g10 manix in combo edge and ffg might be nice.
If you want, I could look around at the seconds sale in November for a Manix for you. IIRC, hollow ground Manixes (PE and CE) were $35. I think that the S110V ones were $50, and I didn't see any other lighteweights. There may have been some flat ground G10 Manixes, but I don't remember.
Also, I could pick up a Military for $50-75 ish.
I sent you a pm
JAfromMN
#42
Post by JAfromMN »
endgame wrote:How about the worker
They look to delicate at the tip for a work blade. For me anyway.
anagarika wrote:Gayle Bradley. It's designed as work knife.
Not so easily slip up the blade, check out the old bradley thread on BF:
http://www.bladeforums.com/forums/showt ... y-Hard-Use" onclick="window.open(this.href);return false;
I will read through that post on bladeforums.
JAfromMN
#43
Post by JAfromMN »
I'm going to try find a Bradley I can mess with to see if I care for it.
The blade steel is what's pushing me to try one.
I'm still unsure of the slip factor. Ill have to hold one and maybe use it a little before I buy one.
spyderg
#44
Post by spyderg »
spyderg wrote:
Absolutely loving my Crow2 at work. Not a very long blade but thick, (strong) yet flat ground so still a good slicer. I modded the blade shape so it's nice and comfortable while closed in hand, (great while driving pallet truck but don't want to put knife away). Really like the CTSBD1 steel too.
I don't know what I do wrong but I can't get a decent lasting edge on a Byrd. I've tried. I can sharpen everything from 420j2 to zdp189 but not a Byrd.
Have you tried the CTSBD1 yet? I find it very easy to sharpen. It holds a decent edge as well, not as lasting as some steels but for a work knife, (for me anyway) it's plenty good enough especially 'cause it can bump metal racking or concrete and if that happens I need to sharpen regardless of the steel. The Crow 2 is just a great little work knife if you don't need a long blade.
HarleyXJGuy
#45
Post by HarleyXJGuy »
I thought for sure I posted here that I have a S30 Millie you can try out of you want.
JAfromMN
#46
Post by JAfromMN »
HarleyXJGuy wrote:I thought for sure I posted here that I have a S30 Millie you can try out of you want.
Ilk take your kind offer man
I'm good to pm you.
JAfromMN
#47
Post by JAfromMN »
I'm stuck
Ce endura I need or the harpy I have wanted to long.
Headbanging
farnorthdan
#48
Post by farnorthdan »
Thats easy...both of course. :D
HarleyXJGuy
#49
JAfromMN wrote:I'm stuck
Headbanging
It is easy like Dan said.
Get a Millie.
farnorthdan
#50
Headbanging
Get a Millie.
:p :D
JAfromMN
#51
Post by JAfromMN »
Headbanging
Get a Millie.
:p :D
I'm borrowing Harley's :cool:
JAfromMN
#52
Post by JAfromMN »
farnorthdan wrote:Thats easy...both of course. :D
I will in time. :spyder:
I've never owed a ce endure. I really need to.
I'm getting the harpy tonight. :p
I've waited long enough. :p :p
3rdGenRigger
#53
Post by 3rdGenRigger »
We should start a pool now on how long it takes him to carry the Harpy in combination with a Millie. I think it's a good possibility...especially in a work environment. SE Hawkbill and Millie combination is just so versatile for almost anything.
All Glory To The Hypno-Toad
---> Branden
JAfromMN
#54
Post by JAfromMN »
3rdGenRigger wrote:We should start a pool now on how long it takes him to carry the Harpy in combination with a Millie. I think it's a good possibility...especially in a work environment. SE Hawkbill and Millie combination is just so versatile for almost anything.
We'll see.
I carry a multitool or Swiss knife to back up my spyderco.
I doubt you'll see with em both often.
If you do I better be using them both.
Ripping and Slicing
JAfromMN
#55
Post by JAfromMN »
I ordered a older vg10 harpy this evening.
I wanted tip down only. I don't like all the extra holes in stainless so I when i found a Old display shelf stock model like I wanted I bought it and it was a few bucks cheaper. :)
Its vg10 with the lock cut out.
Its matches my endura 2 besides the steel.
Now the wait. :eek:
elena86
#56
Post by elena86 »
Cruwear Manix
#57
Post by Doc Dan »
For a work knife you cannot beat the good ol' Endura. If you break it, you are not out a lot of money. It has great traction, even when wet or greasy. Its that simple.
The Millie is a great knife but longer in blade than the OP's knife laws allow, if I remember correctly. Plus, if you break it, you are out the cost of three Enduras.
SpydyLover1234
#58
Post by SpydyLover1234 »
I'd go endura as that is what you're used to
HarleyXJGuy
#59
Doc Dan wrote:For a work knife you cannot beat the good ol' Endura. If you break it, you are not out a lot of money. It has great traction, even when wet or greasy. Its that simple.
Millie is right at the four inch limit in his state.
tr4022
#60
Post by tr4022 »
Am I the only person in the world who finds the Bradley folder impossible to close one-handed? If you look at a scale with ease of closing at one end and lock strength at the other, the Bradley definitely falls much closer to the lock strength end than the sweet spot between the two. Just sayin'.
I will throw in a vote for the serrated Pacific Salt. Wonderful knife.
Tod
