Show those Edges !!!!!
- Orion's Belt
- ChapmanPreferred
Better now...
Sad to say this unit was very blunt NIB.....or maybe I am just spoilt....but it is way better now.....
...and Blue is my favorite color...
Finished with Japanese natural water stones....
Best I could do with what I have so far----30 degree back bevel and 40 degree micro bevel on the sharpmaker. Used diamond, medium, fine, and finished with ultra fine. I need to get a strop and some compound!
Best photos I could take with my phone:
-Ryan
-Techno, cruwear Mule, Dragonfly 2 FRN, Assist, Endura FRN ATS-55 SE, Endura SS aus-6 PE, Persistence(Wife's)
-Wicked Edge
-Wicked Edge
- chuck_roxas45
Yes, very nice result from the sharpmaker indeed.MadRookie wrote:That is a very pretty edge off the sharpmaker - well done!
Thanks :Dchuck_roxas45 wrote:Yes, very nice result from the sharpmaker indeed.
I figure once I get a strop with green compound that should make even more of a mirrored finish, is that true???
-Ryan
-Wicked Edge
-Wicked Edge
Thanks! I would like to be able to make a mirrored finish like you can! And take nice photos too lolMadRookie wrote:That is a very pretty edge off the sharpmaker - well done!
-Ryan
-Wicked Edge
-Wicked Edge
Yo:
The green chromium oxide paste pans out at 0.5 micron, which is much, much finer than the Spyderco Sharpmaker Ultra Fine Rods - 0.5 microns = approx 30k grit - that is very fine, but will take many, many strokes per side for a mirror polish....especially if the deeper scratches from the previous grits were not completely removed.
Having said that, the issue is not so much the mirror relief bevel, but the actual cutting bevel - I would recommend that you focus your stropping efforts on that - to ultimate your edge sharpness...
....just my 2c....
....just my 2c....
What would you recommend after the UF stone on my SM to get the best mirrored edge? :DMadRookie wrote:Yo:
....just my 2c....
-Ryan
-Wicked Edge
-Wicked Edge
- razorsharp
http://www.youtube.com/watch?v=9OQ7Sb00 ... e=youtu.be
Heres a video of my para, did a vid cause my camera doesnt take very good edge pics
MachSchnell
You do not really want a mirror cutting edge for an EDC - you loose the bite....rg02 wrote:What would you recommend after the UF stone on my SM to get the best mirrored edge? :D
Only the relief edge on my M390 is mirror finished - the actual cutting edge (micro bevel) is finished much courser so that it still slices efficiently.
For final finish, strop with the Chromium Oxide, but raise the angle ever so slightly to ensure that you are hitting the very edge of the edge.
A 0.5 micron edge finish is scary, screaming sharp - you don't need more...
MachSchnell wrote:That M390 looks silly sharp... How does it perform at high polish like that?
Still working with the factory edge on mine and it seems to be holding up really well. Once it needs to be re-worked it's game on!
"Only the relief edge on my M390 is mirror finished - the actual cutting edge (micro bevel) is finished much courser so that it still slices efficiently."
MachSchnell
Just watched your vid - that is one super good looking edge!razorsharp wrote:http://www.youtube.com/watch?v=9OQ7Sb00 ... e=youtu.be
What did you use for the final polish - is there a micro bevel ??
Well done!
- razorsharp
Thanks a lot.MadRookie wrote:Just watched your vid - that is one super good looking edge!
Well done!
It was done on sandpaper to 2000 grit, then done with 7u, 5u, 2.5u, and 0.5u paste on paper the same thickness as teh sandpaper.
The back is at im guessing 13-14 degrees per side , really dont know, the microbevel is lansky medium ceramic crocksticks(I guess 600-800 grit) at 17 degrees a side, refines on a 0.5u strop. It has teeth, and splits hair. :) . Im not a very big fan of polished cutting edges , the only knife I do a polished edge on is my SB caly cause that seems to like that edge more and holds its bite
[img][IMG]http://i1211.photobucket.com/albums/cc4 ... -01094.jpg[/img][/IMG]I spent a little more time on this one [img][IMG]http://i1211.photobucket.com/albums/cc4 ... -01069.jpg[/img][/IMG] I got to buy a sharpmaker.
I do all my edges free hand with a spyderfile kit.
My favorite Spyderco is the one I'm carrying now :p
