Bottle Caps
I've opened a few beers with the spine of a spydie when the blade is fully closed. I don't rightly trust myself prying with a sharp open blade :eek:
I've used a different strategy a couple times, it's not the most effective, but I think it helps keep the spydie looking good. When I get home and have a beer I'll try to get some pics :D
MEMBER OF THE INTERNATIONAL ORDER OF THE SPYDEREDGE
I think the Kopa makes a perfect bottle opener! I don't have any pictures to illustrate my point but I will do my best to portray what I am talking about.
The end of the handle, opposite the pivot has a bit of a point to it. With the knife closed place the point under the cap and leverage as you would when opening with a lighter.
I have done this quite a few times and I cannot find a nick on my Kopa from it, It seems to get under the cap better than a lighter and provide more leverage than when using the spine of the blade.
- LowSpeedHighDrag
Since we are in a knife forum I would say you have at the least a bit of survialist in ya. Get a $1 bic, have fire, and a trustworthy errr soda opener on ya at all times, great combo. If you insist on using the $100+ knife than get a wave! Not only does it kick arss for what its meant for, it also opens errrr sodas without fooking up your high dollar blade.
I guess from making all these nice re-scaling you get thirsty and need a beer to clean your throat from dust...Tricod wrote:I actually have a bottle opener/prytool/screwdriver tool on my keychain (one of my Rhinopry tools) but still use my knife more, I think its cause I can get to it faster, and from a sitting position. :rolleyes:
Brad
Maarten
member of FFG Club
member of FFG Club
Nothing cleans the throat of fiberglass dust like a bee.... err soda :)MAT888 wrote:I guess from making all these nice re-scaling you get thirsty and need a beer to clean your throat from dust...
Brad
(ok seriously, I use a respirator, fiberglass dust is nasty nasty junk)
GarageBoy wrote:What is that cool framelock?
Thats my Daws model, as well as my EDC. Its a singlesided frame lock with handmade carbon fiber on the other side. 3 3/8 blade length.
Brad Southard
Southard Knives
Southard Knives
- uhiforgot
If I can do it with my Lava, you can do it with your stretch :cool: you just need a higher starting angle for the pry and a higher, tighter grip on the bottle neck.gldfshkpr wrote: :D Nice. My SS Stretch would be perfect but for the bevel.![]()
A very wise man once told me "Eat to live; don't live to eat." ...To my knowledge that's the only stupid thing he's ever said.
I've always done it like this.Tricod wrote:Here is my method.
Its very Important to realize that you can cut yourself, really quite badly if you do this wrong. So dont try this at home :D or after a third errrr... Soda....
Its just me at home tonight, so I had to take the photos with one hand, thats why there are no in action shot.
The idea is to grip the neck of the bottle up high just below the lip of the cap. The use the spine of the blade underneath that lip and have the blade resting on top of your knuckle. Then you grab the knife and rotate away, using the leverage to remove the cap.
Also shown is how to do it with a smaller knife, just dont use the blade of a small knife, as it will cut you!!! Badly!!!!
Cut myself once (with a non :spyder :) , but I had looked at the bottom of too many Sodas.... at the time.
All the wide bladed spydies do this very well :D
Sverre
I'll try it. But...uhiforgot wrote:If I can do it with my Lava, you can do it with your stretch :cool: you just need a higher starting angle for the pry and a higher, tighter grip on the bottle neck.
Well, this is working out nicely for me. The cap pops off and flies up into the air as if on springs. It also leaves the cap in perfect shape for re-capping if needed. It's much more comfortable and effective than using a lighter (for me).
I was a bit concered it would put stress on the blade and loosen the pivot. That doesn't seem to be the case after about 12 opens so far. Still not sure about long term use. I'd still like to see a Spydie with an opener on the handle somewhere.
kb
Stretch
Para Military
[SIGPIC][/SIGPIC]
Stretch
Para Military
[SIGPIC][/SIGPIC]
here's one idea...
I rarely ever used the clip on my Native 3... now modified to do double duty. Hope the choice of bottle opener is acceptable out there in Golden
Excellent modification :D :eek:cwt wrote:I rarely ever used the clip on my Native 3... now modified to do double duty. Hope the choice of bottle opener is acceptable out there in Golden![]()
People say, oh it's dangerous to keep weapons in the home, or the workplace. Well I say, it's better to be hurt by someone you know, accidentally, than by a stranger, on purpose. - Dwight The Office
It's okay for me to talk about my job, as long as I'm not specific. I am the Sergeant of a three-man Rapid Tactical Force at one of America's largest indoor retail shopping areas. - Gecko_45
The more you learn about knives, the better Spyderco looks. - Sal
Heh. I doubt it's worth much. A firmer opening action would be achieved by permanently attaching the opener to the scale, say by epoxy or something (or ultimately having the opener 'claw' be part of the scale itself).gldfshkpr wrote:Whoa. Please explain the mod. I'd copyright that!
Instead what I've done is trimmed off most of the Native 3's wire clip, bent the remaining ends through the hole in a cheap (in this case, a bar freebie) opener so that the opener can rotate but sits flat on the scale when not in use. It wouldn't even work except that the Spydie clip wire is very stout.
At this point the N3 is my 'Franken-knife', taking on the experiments I wouldn't do to every Spydie I have.
One (or three) small stab(s) for man, one giant leap for mankind not to die of thirst. :D By the way, be careful with the hand that holds the bottle. :eek:
Usually I rather use my Victorinox SAK and Camillus USAK to open bottles than my valuable spydies or damascus knives.
JB
P.S. "... it's all right now, I learned my lesson well. You see, ya can't please everyone, so ya got to please yourself..." (Ricky Nelson - Garden Party)
JB
We need locking :spyder: folders, at least a D4, with very small :spyder:holes (no one-hand function, only trademark) for legal carry in Germany!
If I could only keep one of all my knives, it probably would be a D4.
Ever tried, ever failed, no matter.
Try again, fail again, fail better.
(Samuel Beckett)
(Samuel Beckett)
