ED Schempp Persian Sprint Run?
The micarta is yellow linen and is kind of hard to get now. I think that manufacturer (Bark River) stopped using it because of too great colour variations.The Deacon wrote:
Giraffe bone would be sweet. So would that "butterscotch" micarta Sverre showed, if it could be obtained, and especially if it could be contoured a bit (like on the Byrd Harrier) to show off its grain.
Contoured slabs show of linen micartas very well so +1 on that.
Lignum vitae is a nice, if a bit plain, wood for knives and smells great as well :)
No hurry Sal
Looking forward to the pics Paul :D
Sverre
Persian
Sal,sal wrote:OK, let's chat.
We probably couldn't do anything before late '09 or early '10. We've got quite a few models "in-the-works" so there is already a queue.
I believe the maker has capacity so production can be done during the '09 year.
Maybe we can Ed to Chime in.
Sprints are always an iteresting project. The changes are always fun.
Damascus is possible, but usually quite expensive and out of the budget of many interested. I would guess blade or bolster would be possible, but I'd have to talk to the maker to see if they can do it.
I don't think a flat grind would be a problem.
I would want to make it lighter, but that's just me. Maybe holes in the liners, but I understand from another thread on another forum that some don't like the skeletonized liners?
Would you want to keep the bolsters or go to a full scale?
A larger hole is probably possible, but would require some new tooling. It would also change the "look" of the knife. What size hole would interest you Paul?
Woods are available, but limited. I don't think I'd go with a G-10. I think the "spirit" of the design would be happier with a non G-10 material. Maybe giraffe bone?
We have had some samples made with different materials. Maybe we can get some photos put up? Paul, if I sent you some protos to shoot, do you think you could post them? We're not set up to do really good photos in-house.
If we pull the Boye dent, we have to shrink the lock well.
Please don't make it lighter. I like the balance just fine the way it is. I would prefer Ed do a patterned Damascus for the bolsters. No real changes are necessary of course. The original remains a very solid, well thought out design.
"There is no weapon more deadly than the will." Bruce Lee
"The most pervasive and least condemned form of dishonesty is not doing the best you can." Colonel Jeff Cooper
The Persian
I'd be delighted of course to see a sprint run. Thank you for the interest.
When I made the prototype I had a difficult time in finding scale material because of the curves and width it requires wide material for scale. The width of the scales takes most all natural materials out of the equation. I like stag bone for cost and for application and it is a fairly traditional material but it is hard to procure the width necessary.
I do prefer the smooth handle material for two main reasons. My pocket does get abraded by the scale material every time the knife is stored or retracted from the pocket, so I like smooth material. The design is used as a skinning knife by many hunters and the smooth surface avoids two problems, abrasion to the hand in long and hard use and the difficulty cleaning after the project is done. I'd like to see a burgundy, blue, ivory or green Micarta for the handle material.
To avoid any retooling costs the design is fine by me. I wouldn't mind seeing the hole one more millimeter in diameter.
The hollow grind adds the back of the grind line to accentuate the curve of the blade. A 3/4 saber flat grind would be nice, still accentuating the lines of the knife while it would give the flat grind geometry advantages it would not change the look as a full flat grind would do.
Take Care...Ed
Take Care...Ed
The Man hath spoken !
Let's make it happen in '09 :D
Ed, I'd agree on the grind lines accentuating the curve. Whilst not as prominent an upswept curve as on the Chinook , the grind lines make it look a lot smoother and curvier than it actually is.
I would LOVE to see a different micarta colour, and if it be good for Sal/ Spyderco, maybe even a different bladesteel. I would like to see H1 employed in this case or maybe even ZDP.
Blue micarta ... mmmmm, burgundy micarta ....mmmmmm, ivory micarta ...mmmmm :p Obviously with the design of this traditional 'ethnic' folder, the more conservative colours are more complementary to it. However, as per Spyderco's bucking of trends and melding of modern interpretations of traditional designs, the suggestion of more 'contemporary' hues might make it more appealing to those who like it a tad funkier :)
Whatever the outcome I'm sure both Ed and Sal can get something to satisfy the nuttiest of Persian fans..... nuts anyone ? :D
Cheers
Thanx Ed,
I think that if the Persian is being used for skinning, then the hollow grind is best. In skinning, the depth of the cut is not great (as in cutting cardboard for example) and the thinner edge goes higher up the grind.
I think I can add a mm to the hole size, there might be a very slight increase in the width (to maintain structural integrity).
It is a beautiful design worth effot.
BTW, The current National Geographic features the history of the Persian area. We have some close friends that were born in Persia.
Ed Schempp wrote:I'd be delighted of course to see a sprint run. Thank you for the interest.
Take Care...Ed
Mr. Schempp,
Thank you for sharing your thoughts. I cannot wait for this knife. In case of micarta, I will need at least two. :) :p
I'm fine with Burgundy or Green Micarta, though I think Ivory Micarta might be my preferred choice. I just like how Ivory Micarta almost colors like real Ivory with time. Only thing is that I'd want something other than plain SS bolsters with the Ivory Micarta to offset them. Obvious choice would be Damascus, but I'm sure there are some other cool options.
"A Delica is still a better weapon than a keyboard and a sour attitude..." Michael Janich
Dark Nickle... Yeah... The smoke chrome look. That sounds nice on a light color.Halfneck wrote:I'm fine with Burgundy or Green Micarta, though I think Ivory Micarta might be my preferred choice. I just like how Ivory Micarta almost colors like real Ivory with time. Only thing is that I'd want something other than plain SS bolsters with the Ivory Micarta to offset them. Obvious choice would be Damascus, but I'm sure there are some other cool options.
In the time of chimpanzees, I was a monkey.
Give us clear vision, that we may know where to stand and what to stand for - because unless we stand for something, we shall fall for anything.
~ Peter Marshall, US Senate Chaplain 1947
- donutsrule
Thanks Ed & Sal!
Your comments are indeed appreciated!
I think whatever you decide will be fine ,as long as a C83
re-appears ,hopefully with Green micarta.
It's a beatiful knife but the bolsters seem to scratch very easily ,any suggestions for the new version?
Thanks to all who contributed here!
Keep up the excellent work Sal & Crew!
And Ed keep those marvelous designs coming ,I can hardly wait for the Barong & Khukri!
Regards,SSB :spyder:
- The Deacon
Thanks for the input Ed, and huge thanks for being ok with another run of the C83. :D
Micarta, in just about any color, would be fine. It's practical, decently attractive in its own right, pocket friendly, and doesn't hurt as much to replace as more expensive materials might for those who feel they'd be happier with something else.
- Jenner 515
- jimbo@stn24
Would definetely take one or two home. Not really a fan of ivory, but burgundy micarta especially, or green or blue micarta would be my preference. This time I will hang on to 'em.
Gave the two I had to a dear friend that hunts and really liked the first one I gave him. Kinda mad at myself in regards to the second one. He reports that on the last two elk taken he has used them both and they have displaced his old Portland made Gerbers for some duties with game. Easily two of his favorite knives. Mine as well, they are beautiful knives Sal and Ed. Well done.
WTC #1455
When time allows, pictures would be wonderful. Thanks in advance! :cool:sal wrote:We have had some samples made with different materials. Maybe we can get some photos put up? Paul, if I sent you some protos to shoot, do you think you could post them? We're not set up to do really good photos in-house.
Larger hole and skeltonized, yes please. To be honest, a sprint run with black micarta would be just fine by me.
The bolsters should be mandatory. Besides Damascus, are there any other design changes that can be done to the bolsters that would still keep the classy look?
- The Mastiff
I'm another one that found that the bolsters scratched easily and fairly deeply on my users. I'm generally pretty carefull not to keep my good knives in a pocket that has anything, including lint in it.They are the only spyders I've really had that trouble with. The design itself is as functional as it is beautiful, and I really love the feel of it in my hand ( the large one especially).
It would be a must have for me, and I'm cutting way back on buying. Joe
