Show your Mule
Agent_Ohm
#281
Post by Agent_Ohm »
Marion David Poff wrote:Halpern Titanium has just released new handles scales for the Spyderco Mules...
New Colors!
Full Coverage?
You can see a bit more at their USN Forum....
http://www.usualsuspect.net/forums/show ... p?t=462360
Or, for those who cannot enter that wonderful place... an image....
Having a soak in Mineral Oil.... It's great for the skin!!!
Marion
did you happen to take any pictures before you soaked them in mineral oil?
I would love to see the un-oiled scales in the brown and grey
In omnia paratus
Marion David Poff
Banned
#282
Post by Marion David Poff »
I should have a review shortly...
I have been pretty busy with other stuff in my life, plus I have been sick the last 4 days, dizzy spells, pretty weird actually...
But, I have a review of the new handles from Halpern, plus a couple of other reviews coming...
Marion
Marion David Poff
JLS
#283
Post by JLS »
Hope you get feeling better Marion.
My family has been sick for about a week, though I've escaped with just a cough so far due to the massive amounts of vitamin C and just being more a recluse than normal. Now I just need to get back out to the garage to work on Mules so I can show them here.
42 Spyderco fixed blades and counting...
Donut
#284
Post by Donut »
-Brian
A distinguished lurker.
Donut
#285
Post by Donut »
BananaBoy_S4 wrote:did you happen to take any pictures before you soaked them in mineral oil?
I took a couple pictures of mine.
http://www.spyderco.com/forums/showpost ... tcount=608
-Brian
GoMeR
#286
Post by GoMeR »
Heres one of my S35VN mules with my first attempt at scales. The g10 is finished out to 600 grit and then hand polished with some rubbing compound. :D Pics are mediocre, its rainy and overcast today so its pretty dark outside.
Agent_Ohm
#287
Post by Agent_Ohm »
Donut wrote:I took a couple pictures of mine.
Thanks! i kind of prefer the un-oiled look
In omnia paratus
potterma
#288
Post by potterma »
Thought I'd add a couple recently finished.
First up, black canvas with OD G10 liners. Stainless hardware.
Next up, Slate gray G10 over OD G10, Stainless hardware.
:cool:
www.KnifeRights.org
By Knife Owners. For Knife Owners.
CLB Designs
My Flickr Page
HaroldB
#289
Post by HaroldB »
Nice shots.
Great looking scales, as always ;)
bartch
#290
Post by bartch »
Here's mine, with green linen micarta.
I have a RAT RC-4 and love the looks and grip of the linen micarta scales, so i tried to reproduce it on my mule and Fallkniven F1.
I shortened the Kicker of the mule. I think it's way too long and prevents you from using it in the kitchen and food prep.
Cheers,
Bart
Marion David Poff
Banned
#291
Bart,
Those are good looking!
Marion
Marion David Poff
dsmegst
#292
Post by dsmegst »
Although I'm still very new at scales, I've done a few and here are two recent ones. They're both 9Cr18Mo Mules with G-10 scales.
First one is a removable textured black and yellow combo with a kydex sheath. The belt clips are Spyderco G-Clips on adapters for better balance and carry comfort.
(I need to wipe down the blade before a photo op)
And here's a top view:
Dan (dsmegst)
:spyder:
:spyder:
dsmegst
#293
Post by dsmegst »
The 2nd one is a black/blue layered scales and a kydex sheath to go along with it.
I'm really pleased at how this turned out:
My other one is a factory 2nd S90V blade with some generic black plastic scales with plexiglass liners. It's not pretty and it scratches easily but it's a **** of a slicer with a 10 degrees per side edge. It's neat being able to see the holes and pins through the liner.
Dan (dsmegst)
:spyder:
:spyder:
2cha
#294
Post by 2cha »
Super awesome. Great work. The black-yellow combo is hot. Where did you get the screws for that? I've been surfing around trying to find some kind of spacer that I can put screws in to make removable scales and apparently haven't been asking google the right questions.
The "leaf" shape of the sheaths are very spydie and elegant.
bartch
#295
Post by bartch »
Wow Dan,
Those look amazing and nicely finished, beautifull work!
2cha, i used "long doorhandle tubes with thread." , i don't know the english name for them..i live in Holland, they fit exactly in te little mule holes. They are normally used to tighten the metal doorplates with a long screw. They are M4, european size.
Greetings
Bart
dsmegst
#296
Post by dsmegst »
2cha wrote:Super awesome. Great work. The black-yellow combo is hot. Where did you get the screws for that? I've been surfing around trying to find some kind of spacer that I can put screws in to make removable scales and apparently haven't been asking google the right questions.
Thanks for the encouraging comments. :) I really need some photography lessons. Everything's dark and the details are not showing up. :p
For the screw hardware, I contacted http://www.halperntitanium.com and bought the same set they use for their removable scales. Since I bought my G-10 material from them, I thought to give them a try.
I found that the spacer and screw diameters are too close to give much support to the scales. Instead of drilling out the scales all the way through to match the spacers, I had to partially drill in the undersides and create nested channels for them. Then I drilled some shallow divots for the screws on top. That left a thin bit of scale material between the top of the spacers and the screw heads for better support.
For the next one, I'm going to the hardware store to see if I can find matching screws with a bigger diameter so I can drill through the scales and not worry about strength. I'll probably shorten the spacers to make the screws fit completely flush too.
Good luck.
Dan (dsmegst)
:spyder:
:spyder:
CanisMajor
Post by CanisMajor »
Brown Halpern scales with a Blue Kydex made by Marion David Poff with a Spyderco G-Clip.
Thanks again Marion!
Canis
Dare. Risk. Dream.
"Your body may be gone, I'm gonna carry you in.
In my head, in my heart, in my soul.
And maybe we'll get lucky and we'll both live again.
Well I don't know. I don't know. I don't know. Don't think so."
- Modest Mouse "Ocean Breathes Salty"
Marion David Poff
Banned
#298
Glad to see you like it!
Thank you!
Marion
Marion David Poff
dsmegst
#299
Post by dsmegst »
One more to add:
Modded 9Cr18Mo Mule - my "Kitchen Mule" with a reshaped handle and a shortened guard. Natural G-10 over orange.
Dan (dsmegst)
:spyder:
:spyder:
ChapmanPreferred
Post by ChapmanPreferred »
dsmegst, That kitchen Mule is something I have been thinking about for a while. Nicely done.
Work EDC List
BRP: CF Military S90V
BLP: Forum S110V Native
[SIGPIC][/SIGPIC]
