Elastic Ceramic. Wow!
archangel
Re: Elastic Ceramic. Wow!
#261
Post by archangel »
Thanks Sir!
Michael
Barmoley
#262
Post by Barmoley »
Interesting that you guys have good results sharpening these. I haven’t been successful so far using diamond stones of various types. Also, one of my larger knives took a bent to the blade. I didn’t know it could happen and I am very surprised it did. The blade was straight when I got it and was in my knife block. Couple of days ago I saw that someone jammed a smaller steel knife in the same slot, so I was worried that the steel knife might crack the ceramic. When I took the rahven out I’ve noticed that the blade now is bowing, has a bent to it. I don’t know how to straighten it without breaking.
The mule in it would be good and hopefully thicker as these are too flexible for my liking. Also, I hope mules come very sharp from the factory. Rahvens were ok sharp, but not as sharp as I like. My friend also ordered a set and his are not sharp enough to cut tomatoes cleanly, so that’s not good.
Fireman
#263
Post by Fireman »
There are many collectors now that would take up a lot of the purchases. I wonder how many miles would be made. The next question is what knives after that? Spyderco can sell a bunch of “Salt” knives to recoup the tooling and R&D costs. Sheepsfoot blade sailor knives would be cool. A ceramic waterway? Bow River?
Mule Team Army 001 (patched)
MNOSD 008 :usflag
LakeOconee
#264
Post by LakeOconee »
Yes, also in at $150, either 1 or 2, whichever is the limit.
:bug-red-white MNOSD Member #0037
Fireman
#265
Post by Fireman »
Barmoley wrote:
Sat Jan 22, 2022 4:36 pm
Sharpening this material is going to have a learning curve and the right tools. I am going to look into getting 1/2 micron diamond paste or spray to get hair popping sharp. The good thing is you won’t need to sharpen that often. Perhaps there can be someone or some company that will provide a sharpening service for these knives.
MNOSD 008 :usflag
#266
I have been most impressed with the sharing of knowledge in this sub forum. I'm betting that some will learn a better way and share. When I spoke wit the factory making the blades, she said that they use a diamond belt, That's a good bit of knowledge. I believe we'll teach each other to do it or some will do it and offer it as a service. This is new territory for all of us so we have to assume there will be a learning curve. "We will go where no humans have gone before", Ceramic Mule Team.
Fireman
#267
Post by Fireman »
Sal, so are these manufactured in Switzerland?
These mules will make for an amazing light backpack knives.
MNOSD 008 :usflag
Barmoley
#268
Post by Barmoley »
The material definitely has potential. We just need to figure out an effective way to sharpen these. It is not straight forward and everything gets dull. I tried 1 micron on a leather strop and had very little success. Also tried vitrified diamond stones and edge pro matrix with wd40. Strop and Edge pro matrix were recommended by Roman who helped develop this material for knives. It is good to hear that some of you had success, gives me hope.
Really looking forward to a mule with a stiffer blade. Also hope there will be enough made to be able to get one. Maybe higher price and it not being a steel will make it easier.
Fireman
#269
Post by Fireman »
was your 1 micron a diamond abrasive?
MNOSD 008 :usflag
Toucan
#270
Post by Toucan »
sal wrote:
Sat Jan 22, 2022 12:37 pm
Hi Michael,
Could be in the $150 range. Tooling is very expensive as is part cost.
It seems like a shame to invest in expensive tooling for a limited run. Especially considering how novel the material is, is there any chance on this being a continuously produced model?
archangel
#271
Post by archangel »
sal wrote:
Sat Jan 22, 2022 9:37 pm
CMT. :smiling-cheeks
Imagine this test balloon flies. Maybe there's a chance for at least one or two further models with a Spydiehole? One larger and one smaller than the CMT, both true outdoor blades? Technically it wouldn't be competition to Rahven's kitchen line knives...
Michael
Barmoley
#272
Post by Barmoley »
Fireman wrote:
Sun Jan 23, 2022 1:37 am
Yes, only used diamond abrasive on this.
FullScaler
#273
Post by FullScaler »
While I have not sharpened this specific type of elastic ceramic. I have spent some time learning on my wife's ceramic kitchen knives.
I found that finer grits of diamond for longer times on the stones was the trick.
I started with coarser grits (300 - 600) and while they felt sharp and cut well in the kitchen, they were not what I would call shaving sharp. After looking closely under a loupe and micro photographs I could see that the coarser grits were not really abrading away and refining the edge. But, were instead, taking tiny micro chips out of the edge and made a very aggressive micro toothed edge.
After stepping up to my finest DMT diamond plate, XX Fine. (About 8000 mesh, 3 micron) I had much better results. Instead of starting at medium grits like I would with most steel I started at X Fine (1200 mesh, 9 micron) and worked for a long time, then stepped up to XX Fine and spent a lot more time.
This gave me great results on my wife's regular ceramic kitchen knives and will be my first plan for the elastic ceramic mules.
My basic tips would be, twice or three times as Fine a grit, for three to five times as long as normal steel. And a very, very, light touch on the stones. Definitely not to be rushed or attempted when you are short on time.
Https://BladeProtection.com
#274
Fireman wrote:
Sat Jan 22, 2022 10:03 pm
Hi Fireman,
She said they were in fact manufactured in Switzerland. I asked specifically because of all of the Chinese manufacturing these days, which seems to be mostly grabbing an existing market, but with a lower price.
They also said they really didn't want to make their own line, but it was a way to get their product out into the market place. We discussed distributing their product in the US, but their financial requirement at this time was more than we were willing to commit. The Mule team is a "first date" to see how and what we can do together.
Fireman
#275
Post by Fireman »
:smiling-heart-eyes Looks like Spyderco has expanded its international manufacturing. I hope this “date” goes well and we see a variety of successful projects
MNOSD 008 :usflag
Barmoley
#276
Post by Barmoley »
FullScaler wrote:
Sun Jan 23, 2022 9:29 am
Thanks for the recommendation. Roman suggested not to use diamond plates with flexible ceramic, so I haven't tried. I've tried 1200 matrix stone and 2k vitrified diamond in addition to 1 micron on leather.
Fireman
#277
Post by Fireman »
Does anyone else think the ceramic mule might make a good lightweight neck knife? Perhaps a modified swick would too.
MNOSD 008 :usflag
hereiamu1
#278
Post by hereiamu1 »
TomAiello wrote:
Sat Jan 22, 2022 1:07 pm
I'll still be in for two at $150.
Me too
emanuel
#279
Post by emanuel »
Barmoley wrote:
Sun Jan 23, 2022 12:36 am
You need a middle ground between too hard and too soft. A diamond stone will micro chip this material. Leather is too soft and seems to round the apex. I believe this is why my sharpening on paper on a cardboard backing with diamond paste of 1 micron is successful, it's similar in its physical attributes to the diamond pad Roman was mentioning in one of his vids regarding sharpening.
Fireman
#280
Post by Fireman »
MNOSD 008 :usflag
