capid1 wrote:
Yes, I can albeit you can't go heavy handed and have to use a bit of soapy water.
Thanks, I tried that years ago but could not prevent cutting the paper, however I sharpen fairly fast.
In regards to random quotes as if they make an argument, especially when they are about a hundred years old, that isn't a practical or even sensible way to argue especially when the words in context have changed significantly in the last 100 years.
One of Rutherfords quotes :
"Anyone who expects a source of power from the transformation of these atoms is talking moonshine."
It should be obvious this isn't true today, and if you argued it was because Rutherford said it 100 years ago then that is just silly. In the same way you can make any silly argument by just quote mining someone, creationists do it all the time to argue against evolution.
This is one of the main ones :
"To suppose that the eye, with all its inimitable contrivances for adjusting the focus to different distances, for admitting different amounts of light, and for the correction of spherical and chromatic aberration, could have been formed by natural selection, seems, I freely confess, absurd in the highest possible degree. "
This is from Darwin's own work and if you take it completely out of context it seems to say that evolution (as he proposed it happened) could not explain the development of the eye (and similar complicated organs). However if you read it in context it doesn't say that at all.
If you want to make an actual argument that statistical methods are not necessary in the scientific method then use references on modern scientific method, current peer reviewed literature, and modern curriculums.
If you actually can do this and prove it then at a minimum you would not only easily have a PhD in applied math (which would win any number of awards) you would revolutionize all of modern science.
Good luck.
As an aside, in this thread, the following claims have been made :
-all of Roman's work (peer review, published data with 100+ references) has been discounted as it disagrees with anecdotal data and Roman is just a shill (even though his arguments are all referenced in published data)
-the scientific method can be ignored in empirical methodology without consequence
Yet what strikes people are the most outlandish claim is my statement that is is actually possible to know properties of steels and not simply have opinions on them.
Here is the frank reality, an opinion is a position you hold which does not have supporting data to make a claim of objective truth, that is what the word means.
There is lots of information available on steels, from the ASTM references, the patents, and the well respected references from Krauss, Verhoeven, Landes, etc. .
It is not necessary to simply have opinions, you can actually know how they behave if you make the effort to learn.
Now if you don't want to do this, that is fine, but it is pretty silly to claim because you can't/won't then no one else can either and that it is impossible to know anything and it is all "just opinion".
