Thank you,
Keep your knives sharp, but your stones sharper.
:D
Thank you,
Deadboxhero wrote: ↑Thu Dec 28, 2023 7:37 pmthe high toughness of AlOx, can also be a downfall because it will not break down and self-sharpen with use. AlOx simply goes to dull which further decreasing cutting performance.
Definitely something that can be explored in more detail to see the differences that different SiC grit sizes can have on performance and wear on the stones.RustyIron wrote: ↑Sat Dec 30, 2023 2:07 pmDeadboxhero wrote: ↑Thu Dec 28, 2023 7:37 pmthe high toughness of AlOx, can also be a downfall because it will not break down and self-sharpen with use. AlOx simply goes to dull which further decreasing cutting performance.
Dude! This post is particularly timely.
Last night I was flattening/restoring some stones, and was pondering my Sharpmaker rods.
I'm no expert on abrasives or ceramics, but I imagine the Sharpmaker rods as being aluminum oxide held together by some kind of magical ceramic spell. It stands to reason that through use, the exposed aluminum oxide on the surface of the rods will become polished, thus degrading performance.
Would it make sense to periodically touch up the surfaces of the Sharpmaker rods with silicon carbide on a glass plate? It seems like a good idea.
Deadboxhero wrote: ↑Sat Dec 30, 2023 2:25 pmDefinitely something that can be explored in more detail to see the differences that different SiC grit sizes can have on performance and wear on the stones.
Thanks! Both those blokes know a thing or two about knives and stuff. I think I'll try it out on a couple round ceramic rods that I just use for unimportant tasks.pinchyfisher wrote: ↑Sat Dec 30, 2023 11:38 pmI believe the conclusion from the likes of Sal and Cliff Stamp is that the ceramic stone will to some extent take on the aggressiveness (or lack of) of the lapping compound used.
Deadboxhero wrote: ↑Tue Jan 02, 2024 12:12 amFinished grinding and sharpening more CATRA blades for Dr Larrin, also some metallography. Looking forward to seeing his article about it.
It is a nice "USB microscope" it is designed for soldering. It's not quite as good as a real microscope though.RustyIron wrote: ↑Tue Jan 02, 2024 10:38 amDeadboxhero wrote: ↑Tue Jan 02, 2024 12:12 amFinished grinding and sharpening more CATRA blades for Dr Larrin, also some metallography. Looking forward to seeing his article about it.
There you go again being a bad influence. You should know by now that most of us are weak and lack the discipline to resist fancy new toys.
How about telling us a little about that Andonstar contraption sitting on your desk? My own USB microscope is great for the forty bucks I paid, but really, it's a kiddy toy. Your pictures are great, and I just assumed you had a 'scope that you heisted from NASA. I just googled on "Andonstar," and discovered that they make models that can be had for little more than pocket change.
Being a cheapskate, part of me wants to just order up the cheapest one available. But I'm also an undisciplined child, and want to order the biggest one I can find. Since you have some experience and have already figured it out, what model should I get?
Thanks!
For sure. One thing to note- I used 60 grit loose SiC and the ceramic broke the SiC down pretty rapidly to a fine size. Depending how far you go with lapping you may need to replace/refresh your SiC. I imagine if you don't it'll end up being counterproductive. Keep us posted!RustyIron wrote: ↑Tue Jan 02, 2024 10:25 amThanks! Both those blokes know a thing or two about knives and stuff. I think I'll try it out on a couple round ceramic rods that I just use for unimportant tasks.pinchyfisher wrote: ↑Sat Dec 30, 2023 11:38 pmI believe the conclusion from the likes of Sal and Cliff Stamp is that the ceramic stone will to some extent take on the aggressiveness (or lack of) of the lapping compound used.
