Green Para2's are back
JNewell
#201
Post by JNewell »
I got the two side by side in bright sunlight. I would say the texture is the same, but the color is slightly different. You'd only notice side by side in good light, but the 2014 knife is a little more green and the 2013 version is slightly grayer. You can see the color difference in the picture in Henry's post directly above. The G10 texture looks different but in person I would say they're not, or at least not enough to make any difference in grip or wear on your clothes or anything like that.
senorsquare
#202
Post by senorsquare »
My experience with G10 textures is that it varies from knife to knife. My blue para 2 has significantly different textures on each side of the same knife, one side is very coarse and the other side is super fine. This photo is two sides of the same knife -
senorsquare
#203
JNewell wrote:I got the two side by side in bright sunlight. I would say the texture is the same, but the color is slightly different. You'd only notice side by side in good light, but the 2014 knife is a little more green and the 2013 version is slightly grayer.
Seems to me that the 2014 run is a bit of a darker green as well.
JNewell
#204
Post by JNewell »
senorsquare wrote:Seems to me that the 2014 run is a bit of a darker green as well.
It's hard to get it right with words and my color vision in the green range is a little off, but I'd say the 2014 is brighter/greener and the 2013 is darker/grayer.
tvenuto
#205
Post by tvenuto »
I didn't pull out the forum native to see if the colors were identical, but I imagine they are. However, in my picture (with the brussel sprouts) the light was a little low and everything appears a shade darker than it does in real life.
Henry - get both
#206
Post by Henry - get both »
The scales are not nearly as rounded on the new one:
xceptnl
Post by xceptnl »
I was just curious. I didn't have time yesterday to do a macro comparison side-by-side, but my memory told me the texture was different. As for the color, I could care less if the shades varied infinitely from one Green Para to the next. I did also note the rounded corners as Henry did. I attribute this to the two different employees with different techniques so each one can be a bit different. I appreciate these subtle differences, they remind us that these knives are made by hand (mostly) and are not mindlessly thrown in a holding bin until ready to be packaged. Each is constructed with it's own mirco-character.
*Landon*
bh49
#208
Post by bh49 »
RadioactiveSpyder wrote:Should I get mine all out for a dark green photo shoot? Plus, you missed the coolest one - the Forest Green Dragonfly!
Group photo will be great.
I am not a dragonfly fan. I like Kopa's blade much more. But I would buy dark green G10 dragonfly.
jalcon
#209
Post by jalcon »
Does anyone have this around their lanyard tube? I find that the G10 around the metal tube is kind of pressed up and uneven. The other side is actually slightly worse. My Satin Pm2 seems to be perfect, with the metal showing around the rim perfectly and consistently around the entire edge, and on both sides. :confused:
JNewell
#210
Post by JNewell »
I noticed the same difference shown in Henry's picture (difference in the radius at the edge of the scales).
jalcon
#211
Post by jalcon »
Lol at flippers on Ebay. Nobody's buying them and they just keep getting cheaper. Hooray, I think the PM2 hype is over.
sir_mike
#212
Post by sir_mike »
jalcon wrote:Does anyone have this around their lanyard tube? I find that the G10 around the metal tube is kind of pressed up and uneven. The other side is actually slightly worse. My Satin Pm2 seems to be perfect, with the metal showing around the rim perfectly and consistently around the entire edge, and on both sides. :confused:
Yeah, so what is the deal with the lanyard ring tube? Mine is like your pic! Is it flawed or something that got passed QC check???
Liquid Cobra
#213
Post by Liquid Cobra »
Untitled by liquid cobra, on Flickr
Mine has it too!
@liquid_cobra
Spydersense
#214
Post by Spydersense »
I just noticed that my credit card was charged today from Knife Works. Maybe the second batch has arrived and will ship tomorrow?? I sure hope so. :D
Time for another :spyder:!
-Matt
JNewell
#215
Post by JNewell »
jalcon wrote:Lol at flippers on Ebay. Nobody's buying them and they just keep getting cheaper. Hooray, I think the PM2 hype is over.
I honestly hope you're right about the second part, but I wouldn't hold my breath. ;) IMHO, ridiculous pricing is not a positive thing - it just makes knives that should be used into shelf or closet queens.
senorsquare
#216
Interesting. I got one of the newer ones out of the most recent batch and the scales are nicely rounded like the lower knife in the photo. It's the most comfortable para 2 I've owned to date.
Henry - get both wrote:The scales are not nearly as rounded on the new one:
Henry - get both
#217
senorsquare,
Which number is on the outside of the box of your para? Is it 1376 or is it 1402?
A picture of the g10 would be cool.
DougC-3
#218
Post by DougC-3 »
When I got my first PM2 (not the green one), I thought PM2's didn't feel very comfortable in hand. Later when I got my green one last year, it seemed much more comfortable. At first I thought it was because the scales weren't as rough but finally it dawned on me that the scales on the green one were radiused (beveled, chamfered, rounded over, whatever) and the scales of the other one weren't. Sometimes these nearly subliminal things can give you a negative impression without it being obvious what's causing it.
Note to self: Less is more.
senorsquare
#219
Henry - get both wrote:senorsquare,
I'll check the code on the box and post a photo this evening.
senorsquare
#220
Code on the box is 1348.
Untitled by senorsquare, on Flickr
