I want a 4” Spydiechef
Re: I want a 4” Spydiechef
Evil D wrote:
Wed Jan 05, 2022 8:54 am
Wed Jan 05, 2022 7:05 am
I always wonder why food prep people don't just bring something cheap and simple, like a Z Cut knife along with them when they plan on using a knife on food. Cheap, plenty of cutting edge, no problems with gunk in the pivot and what not. Problem solved.
This is Inching towards the same type of logic that anti pocket knife people use against us.
Why don't pocket knife people just bring along scissors for :insert hundreds of things here:
Why don't pocket knife people just bring along a utility knife for that cardboard box
Why don't those pocket knife people just bring along a seatbelt cutter
It goes on and on because a pocket knife is a compromised cutting tool, it is a jack of all trades tool meant to take the place of as many cutting tools as possible. Dogging on guys for cutting their food makes the same amount of sense as doing the same for cutting up a box instead of using a utility knife.
Besides, if you really want to see just how well your knife slices and just how sharp it is, go slice a tomato as thin as possible. If you get gunk in the pivot........
David, since I am sure you did NOT read my post from 20 minutes before yours, it is almost spooky how you said almost exactly / literally the same as I did there... :flushed see here: viewtopic.php?f=2&t=91486#p1587168
(just a short quote out of MY post:
" Why don´t people always bring a box cutter when opening packages and processing cardboard?
- Why don´t people always use scissors for cutting of threads and stuff like that?
- Why do people make fire or cut a walking stick with their EDC folder and don´t bring a larger scandi grind fixed blade?"
kobold
Post by kobold »
Don't forget to ask Marcin too! :-)
I would imagine Marcin Slysz would need to be the one to redo and submit a design for a larger Spydiechef.
SG89 wrote:
Wed Jan 05, 2022 9:02 am
Make a sheath and you can carry a Z Cut in your pocket...
I think you are perhaps missing the point here (not meant offensively!)
I could say along those lines:
"Make a sheath and carry scissors"
"Make a sheath and carry a box cutter"
"Carry a small fixed blade in a sheath GENERALLY
Again: For MOST tasks an EDC folder is not the most perfect cutting tool. It is MEANT to be a Jack of all trades.
Why should food prep be treated differently than other cutting tasks?
And as David and I laid out: If one loves Spyderco-pocket knives, cutting food is an excellent way to experience and compare their designs.
(Plus: EDC tasks often or most times occur without one having planned for that particular task before hand. True also for food prep (on the road. In kichens of dull-knives-people and so on).
kobold wrote:
Wed Jan 05, 2022 9:09 am
Who is "Marcin"? :thinking (Honest question, no idea..)
JRinFL
Post by JRinFL »
Wed Jan 05, 2022 8:34 am
Agreed. Why would I want to spend hundreds of dollars on food prep knife that is already sub-par for the job being a folder? And if you really have to use a folder, Victorinox makes a very inexpensive food prep folder.
I get and respect your arguments, but on the other hand: If one follows through on your logic, at what point is an EDC knife obsolete anyway?
- Why don´t people always bring a box cutter when opening packages and processing cardboard?
- And so on..
What I am trying to say:
- Even our best EDC folders are very often "subpar for the/a job" than a cheaper, but dedicated for that specific cutting task (cutting) tool would be!
- Many here do and enjoy to do other "dirty", risking-gunk-in-the-pivot jobs aside of food prep with their Spydies (I certainly do!)
For me a big part of the fun, fascination and joy this hobby brings exactly IS to have a great, universal, do-it-all folder in pocket, that still will be "master of none".
And experience and getting to know its capablities, pros, cons, and limits in as much and as varying tasks as possible.
/ That said, there are also a practical side to food prep of folders:
- If one is a lot on the road like me (bike, car, on foot) when working or in the outdoors when not, the folder in the pocket actually often IS the best tool available for food prep (and knives like the Endura do an amazing job then)
- Sometimes I am in the kitchens of friends, and my folder definitely is the sharpest and best for food prep knife there...
- Cutting food with various folders is a really good way to compare theit blades, grinds and so on...
/ Last thing: I think THIS forum is not at all about always looking for the "cheapest and most simple" solution anyway... :winking-tongue
If we use your logic and arguments, that only confirms that there is no need for a 4 inch SpydieCHEF because any 4 inch EDC knife is sufficient for the task. Not to mention, but I am anyway, that most other EDC knives are far better suited to other EDC tasks over any version of the Spydiechef. But if people want a $300+ food oriented folder, who am I to stand in their way?
kobold
Post by kobold »
Wed Jan 05, 2022 9:13 am
Mr Marcin Slysz, the designer.
kobold wrote:
Wed Jan 05, 2022 9:16 am
Thanks!
I (wrongly) thought his name was MarTin..
This just proves my point. We can think our way around using pocket knives if we want to, most of the world already does. Why are we here? Why do some people care if I cut some veggies with a folder? I swear food prep is the latest triggered version of batoning.
That´s true, though I would not literally say "NO need" (for a 4 inch SpydieChef)
But my post was about that I personally generally don´t see why food prep should be (for me arbitrary) excluded from possible EDC folder tasks. I mean, for many people tasks like cutting of a thread, opening a package, whittling a stick or whatever occur just once a month or so, as might be cutting an apple or sandwich (food prep!). But IF we start out by saying we carry a or even the most perfect EDC folder for any task that might occur (perhaps when no other cutting tool is at hand) food prep is as good as others.
And about "we (absolutely) don´t NEED a 4 inch Spydiechef: Well, I think INSIDE the "Jack of all trades" folder thing people still lay their focuses on different things. If one knows in their day to day life mostly appear "cutting of a thread" tasks, they will go for a shorter folder for example. If one knows they might do quite some food prep they might grab a Spydiechef. I personally tend to see long bladed, light ffg folders as the for me (!) best suited EDC knives, cause I feel such folders are the most versatile, and I happen to do a lot of tasks with my knives.
i could get by with my hawkbill ladybug for almost everything i need to cut day to day. i carry other knives because i enjoy them. need doesn't seem to belong in a discussion on this forum.
JRinFL
#32
Post by JRinFL »
Wed Jan 05, 2022 9:31 am
Well, yeah. Once I bought more than the one I needed I realized I had a problem. :shush
#33
Evil D wrote:
Wed Jan 05, 2022 9:21 am
Don't forget prying.
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
Gsg9
#34
Post by Gsg9 »
Marcin had a larger SpydieChef 2 prototype quite a while ago
https://www.instagram.com/p/BfGw29Lh-s_/
Don't think Spyderco would make it,,,
Larger would appeal to fewer people, although Spyderco advertises them for kitchen for rock jumping etc they are made to appeal to general EDC category to sell more of them,
And bigger would probably be more expensive, is this the new price after 15% ?
https://www.dlttrading.com/spyderco-spydiechef
bearfacedkiller
#35
Post by bearfacedkiller »
Folding pocket knives are multitools that are used for whatever a person wants to use their knife for. There is almost always a better tool than your pocket knife but you always have your pocket knife with you.
I don’t have any issues with folks who want to do food prep with a folder. I sometimes do if I need to cut something for my son. I have also cut up a lot of limes with my folder. I like cocktails. To each their own.
I use a box cutter to cut up cardboard but I don’t get on here and complain about people using their pocket knives to do it when there is a tool designed for it. People can use their knives however they want, it’s their knife.
JRinFL
#36
Post by JRinFL »
Dang. Now I am an "anti". Who knew?
I think I'll punch out of this thread.
donutsrule
#37
Post by donutsrule »
My Spydiechef is a regular in the rotation (and made food prep life easier when we visited my parents on New Years -note to self:bring sharpmaker to parents' house next time!).
I'd happily buy one with a longer blade if made.
#38
i want a spydiechefchete. 🤔
#39
Wed Jan 05, 2022 12:07 pm
Hahaha, yours...for the low price of $800!!
#40
JRinFL wrote:
Wed Jan 05, 2022 10:40 am
Same here bud, I'll go enjoy my food with my Z cut that is sanitarily waiting for me in my kitchen drawer instead of the knife in my pocket that's got lint, tape gunk, rubber, rope and plastic residue on/in it :cheap-sunglasses
