fWIW, not just you. Not working for me with cellular data or home cable, phone and computer.Sharp Guy wrote: ↑Wed Sep 15, 2021 1:08 pmI've tried two different browsers on work PC, logged in & logged out, cleared cache etc. No bueno. Our ISP isn't blocking anything that I'm aware of. Then I tried 4 different browser on my phone. WiFi & cell connections, logged in & logged out, cleared history-data-etc, no good. Then I did the same with my work phone and Chrome & Safari. Chrome didn't work logged in but I did see the pics after I logged out. Safari worked both logged in and logged out. I noticed previously that I don't see your pics but there are a few people that post pics that I also don't see. I usually don't worry about it and keep scrollingAccutron wrote: ↑Wed Sep 15, 2021 8:32 amYou're the second person to tell me that in the past few days. I host pics on my own HTTP webserver...no third party image hosting. Unless your ISP has randomly blocked my IP address, or requires HTTPS for some reason, they should load just fine.
I just had my wife check from her phone, and the pics loaded for her.
Para 3 legit or clone?!
Re: Para 3 legit or clone?!
If it works when you're not signed in, and it doesn't work when you are, it's probably applying protection settings. Google circulates blocklists, and my IP could've randomly ended up in a blocked range. Google also doesn't like HTTP because it's not secure, and may be blocking non-HTTPS depending on your settings.Sharp Guy wrote: ↑Wed Sep 15, 2021 1:08 pmI've tried two different browsers on work PC, logged in & logged out, cleared cache etc. No bueno. Our ISP isn't blocking anything that I'm aware of. Then I tried 4 different browser on my phone. WiFi & cell connections, logged in & logged out, cleared history-data-etc, no good. Then I did the same with my work phone and Chrome & Safari. Chrome didn't work logged in but I did see the pics after I logged out. Safari worked both logged in and logged out. I noticed previously that I don't see your pics but there are a few people that post pics that I also don't see. I usually don't worry about it and keep scrolling
If your web browser is set to connect via HTTPS, then many pictures will not show by default. You can sometimes work around that by right clicking the little broken image icon and selecting "open in another tab" or similar verbage. Most browsers now are set to not allow secure (HTTPS) and insecure (HTTP) on the same page. There are very good reasons for that, so I don't recommend changing the setting. Just use the workaround. Your browser might be set to ONLY allow HTTPS connections and in that case you will not see the pictures even with the workaround.
Ok that explains why it works with one Iphone but none of my other devices. Regardless, I don't really care if I can see your pics or not. I just thought it might be helpful for you to make it so everyone can see what you're postingAccutron wrote: ↑Wed Sep 15, 2021 2:23 pmIf it works when you're not signed in, and it doesn't work when you are, it's probably applying protection settings. Google circulates blocklists, and my IP could've randomly ended up in a blocked range. Google also doesn't like HTTP because it's not secure, and may be blocking non-HTTPS depending on your settings.Sharp Guy wrote: ↑Wed Sep 15, 2021 1:08 pmI've tried two different browsers on work PC, logged in & logged out, cleared cache etc. No bueno. Our ISP isn't blocking anything that I'm aware of. Then I tried 4 different browser on my phone. WiFi & cell connections, logged in & logged out, cleared history-data-etc, no good. Then I did the same with my work phone and Chrome & Safari. Chrome didn't work logged in but I did see the pics after I logged out. Safari worked both logged in and logged out. I noticed previously that I don't see your pics but there are a few people that post pics that I also don't see. I usually don't worry about it and keep scrolling
Sorry for continuing to derail this thread
Right click on the broken image icon, open in new tab worked for me, thanks!JRinFL wrote: ↑Wed Sep 15, 2021 2:26 pmIf your web browser is set to connect via HTTPS, then many pictures will not show by default. You can sometimes work around that by right clicking the little broken image icon and selecting "open in another tab" or similar verbage. Most browsers now are set to not allow secure (HTTPS) and insecure (HTTP) on the same page. There are very good reasons for that, so I don't recommend changing the setting. Just use the workaround. Your browser might be set to ONLY allow HTTPS connections and in that case you will not see the pictures even with the workaround.
Spydergirl88
3 Nats, 1 Chap, 1 Sham, 1 Urb
I have to right-click and open them in a new tab, otherwise it just looks like a broken image link.
So it goes.
The jimping is also wrong, as well as the flat where a choil would meet the flat (not sure of the proper nomenclature). The countersink into the torx screws doesn't appear to be the correct angle either.phaust wrote: ↑Wed Sep 15, 2021 10:12 amPretty easy to tell those from the real. G10 grip pattern is off, digicam G10 pattern has the wrong colors, ragged edges on the G10 at least on the digicam one, black paint is either not dlc or is some kind of shiny dlc rather than flat, bug logo on the blade is all off (for example the lower legs are blobs rather than curved inward), and satin screw finish all blatantly different. Pivot T-size might also be too small(?), can't tell for sure from the pics there. Seem pretty easy to tell those anyway from the real given the huge amount of discrepancies.
Are you guys comparing my pictures or the pictures of the clones?!
