My friend, I have never met anyone as absolutely insanely obsessed with edges, edge formation, and sharpening perfection than my friend Shawn (Deadboxhero). To this day he still blows me away with the depths and lengths he will go to in an effort to create a perfect apex. Although I am one who is beyond reluctant to believe anyone regarding any knife related details until I've tested it and proven it myself I have learned through time, testing and many, many conversations that Shawn is the ONE AND ONLY person who can tell me about edges and I would be wasting my time to double check his info. If Shawn says it's a burr...my dude...it's a burr.
You're absolutely correct. Steel not only suffers molecular consequences due to chemical reactions (after all, mixing with oxygen on a molecular level is the actual definition of burning) but it also flows like a liquid as all things do as well. Adding water amplifies chemical interactions and adding salt water creates a perfectly conductive environment for corrosion to run wild. With some steels (like M4 in my experience) you can actually experience a notable edge degradation from corrosion due to salty humidity alone in just a few weeks if you're looking closely enough. Varying degrees of environmental stresses combined with the wide variety of steel types used for knives means that there are lots of people who will indeed experience molecular consequences that we experience as dulling.
Spydergirl88 wrote: ↑Wed Sep 08, 2021 7:08 amI've opened boxes of kitchen knives made in the 60s never used that were still razor sharp.
Or like this?Buddafucco wrote: ↑Wed Sep 08, 2021 4:50 amWhat if next time you sharpen, you then seal the knife in a baggy or something with a desiccant pack? For science?
That’s an interesting possibility to consider. Hmmm.bearfacedkiller wrote: ↑Wed Sep 08, 2021 5:59 amI asked Mr. Stamp about this years ago and his theory was that during sharpening there was some elastic deformation and that with time the edge would “relax” a little and lose a little bite.
I don’t know if that is true but it has always stuck in my head.
There's always a burr unless proven otherwise.
That's why it's called ruling things out. You have to start with the obvious most likely culprits before you can move into talking about the higgs bosons and quantum tunneling for reasons why the edge went dull.dj moonbat wrote: ↑Fri Sep 10, 2021 4:13 pmI don't think @Deadboxhero has enough information to state conclusively that it's a burr. But I do think that the best guess is that it wasn't all the way sharp; we're probably just looking at a situation where OP thought he was putting away a sharp knife but wasn't.
Xplorer wrote: ↑Wed Sep 08, 2021 10:54 amMy friend, I have never met anyone as absolutely insanely obsessed with edges, edge formation, and sharpening perfection than my friend Shawn (Deadboxhero). To this day he still blows me away with the depths and lengths he will go to in an effort to create a perfect apex. Although I am one who is beyond reluctant to believe anyone regarding any knife related details until I've tested it and proven it myself I have learned through time, testing and many, many conversations that Shawn is the ONE AND ONLY person who can tell me about edges and I would be wasting my time to double check his info. If Shawn says it's a burr...my dude...it's a burr.
Because of my experiences with Shawn, every knife I make has an edge created with a very special vitrified CBN stone he created and all of my edges are final sharpened using techniques he taught me on the specific stones he told me to buy.
If you haven't checked out the videos Shawn does on sharpening and all the other apex related stuff he geeks about, check out his videos on You Tube. https://youtu.be/nHrGs3hCzgg
Best,
CK
Deadboxhero wrote: ↑Fri Sep 10, 2021 6:38 pmThere's always a burr unless proven otherwise.
There's always some residual burr from when you break off the main burr, the base of the burr remains. That's when the real deburring begins.
Without proper deburring all you're doing in some cases is straightening that weak piece of metal out, some steels/hts are very prone to stubborn burrs as well.
Most people mistake this wispy, foil edge for a sharp edge because it is still capable of "cutting paper" and "shaving" but this weak piece of metal is not stable and can curl over even in hours depending on the severity etc
