Rex45=Hap40?
Larrin
Re: Rex45=Hap40?
Post by Larrin »
Albatross wrote:
Thu Aug 27, 2020 8:19 am
That's interesting. Is there an industry standard maximum allowance for sulfur content?
Not really. Not unless there is a European spec I don’t know about. There may be specific industries like aerospace with more rigorous restrictions but for knife steel they are just making the steel with their normal practices to try to minimize sulfur and they probably don’t throw away anything unless it is abnormally high.
When I compared composition measurements from Crucible, Carpenter, Uddeholm, and Bohler the sulfur levels were pretty similar. https://knifesteelnerds.com/2020/03/30/ ... echnology/
There are certain steels occasionally made to be “free machining” with intentional sulfur additions but those aren’t typically used for knives.
wrdwrght
Re: Rex45=Hap40?
Post by wrdwrght »
Chemically the same does not mean the same user-experience. Remember heat-treat and blade geometry are also factors, and other things being equal, are more significant.
So has said our own Larrin.
Takuan
Re: Rex45=Hap40?
Post by Takuan »
Larrin wrote:
Thu Aug 27, 2020 10:08 am
Yes they are the same steel, a very common PM high speed steel in Europe especially. The European designation is 1.3244. It’s sold under a lot of trade names like ASP2030, S590, and Vanadis 30.
Thanks, Larrin. I continue to learn a lot from your expertise (both here and on the Knife Steel Nerds website).
"We cannot live better than in seeking to become better."
--Socrates
Takuan
Re: Rex45=Hap40?
Post by Takuan »
Larrin wrote:
Thu Aug 27, 2020 8:09 am
Takuan wrote:
Wed Aug 26, 2020 8:29 pm
According to Spyderco’s steel comparison chart ( https://www.spyderco.com/edge-u-cation/steel-chart/), they do seem to have very similar chemistry in terms of carbon, chromium, cobalt, molybdenum, tungsten, and vanadium. REX45 seems to have manganese, silicon, and sulfur, which are not included in HAP 40.
Mn and Si is in every knife steel so if they aren't listed it's just because the amounts aren't shown in the datasheet. Sulfur is usually not an intentional addition but an impurity, so some datasheets will list a maximum allowable amount.
This reminds be a bit of the FDA policies that allow certain "tolerable" amounts of rodent hair and insect parts in our food. :)
--Socrates
Albatross
Re: Rex45=Hap40?
Post by Albatross »
Takuan wrote:
Thu Aug 27, 2020 10:22 am
As I typed the question, I was thinking about the time I heard that peanut butter contained a certain, "tolerable" amount of undesirables. I would like to meet the person who deemed this "tolerable", because I would describe it a bit differently... :mad: :confused:
Karl_H
Re: Rex45=Hap40?
Post by Karl_H »
I wouldn't worry too much about the maximum allowable contaminants (S, P, etc.) in the material specs for knife steels, particularly HIP PM steels. The PM process essentially prevents large non-metallic agglomerations from forming and inter-granular corrosion is not a major concern for knife use.
I doubt the casual knife user would notice much difference in the edge stability between Spyderco's HAP40 and REX45. I appreciate the stainless steel cladding on HAP40. All else being equal, I prefer for HAP40 for the stainless steel cladding.
I believe only the Seki models have been offered in HAP40. Only Golden models have been offered in REX45.
I hope that we will eventually see mass production of SS clad tool steels for cutlery in the United States. I also hope that SS clad HAP40 is eventually offered for Taichung models, such as the Ikuchi.
SubMicron
Re: Rex45=Hap40?
Post by SubMicron »
As others mentioned, compositinally the two are very similar, almost the same. As delivered by Spyderco, the difference between the two seems to be the hardness and the fact that their HAP40 has a stainless SUS410 outer jacket. Neither HAP40 or REX-45 are stainless.
Whether the assumed lower hardness in HAP40 is a byproduct of the SUS410 cladding, or if its intentional and by design, I'm very happy with it's performance as delivered. My HAP40 Dragonfly appears to have higher fine edge stability than my ZDP-189 Dragonfly.
HAP40 doesn't have to be run at balls-to-the-wall high hardness for it to be amazing.
I use HAP-40 and REX-45 at work in the Dragonfly and Lil Native. I bring each with me everyday. I'm impresed with both.
With the higher hardness of REX-45 comes better edge stability which gives the benefits of a more durable edge that can provide better overall edge retention.
Erich
Re: Rex45=Hap40?
Post by Erich »
Takuan wrote:
Thu Aug 27, 2020 8:39 am
Thanks! So would you say the primary difference between REX 45 and HAP 40 is the heat treatment (if there are significant differences, that is)?
Thanks, I was wondering if they were equivalent. How does HAP 40 compare to CPM M4 in terms of wear resistance? It seems like it would be very close.
dan31
Re: Rex45=Hap40?
Post by dan31 »
M4 will wear a bit better than HAP40 given equivalent heat treat.
