What makes S90V so special?
Re: What makes S90V so special?
I've had more burr issues with S90V than S110V, 90 just feels soft by comparison and I have an easier time getting sharp edges on 110. Otherwise I can't really tell the difference in day to day use. I've also rusted both.
In my experience s90v is very well rounded. It's run a tad softer than s110v (which also has Niobium) so it has slightly less wear resistance. Sharpenability is higher than s110v (every steel is in my experience) and although it still prefers coarser edges it'll more readily take slightly finer grit finishes than s110v. I think at the same hardness s110v has slightly more toughness but with the typical hardness difference s90v is slightly tougher. It's not quite as stainless as s110v but the difference is negligible. S110v has a tad longer lifetime of cutting ability in regard to slicing but s90v excells at this as well. I think it's a great choice for EDC being more user friendly than s110v while still being at the threshold of the upper echelon of high alloy, high edge retention steels. It's almost like s30v, but cuts longer, slightly less sharpenability, likes coarse edges more, and slightly more stainless. I find it overall more enjoyable than both s30v and s110v for most purposes.
- JonLeBlanc
That's right it was an early one, and somebody please correct me if I'm wrong but isn't it a PM version of one of the 400-series steels? Like 460 or 420, something... IdkGenotoxic wrote: ↑Thu Aug 22, 2019 4:41 pmThis is very true, actually come to think if it S90V was one of the first ultra high end steels to come to the market. Since then we've just be flooded with so many options haha, nothing to complain about though!JonLeBlanc wrote: ↑Thu Aug 22, 2019 4:03 pmWell, to my knowledge S90V is a "prototypical" high-carbide particle steel, and at this point there may not be much novelty in that class of metals, but it's still very hard and quite corrosion resistant. I only own one knife with an S90V blade but based on the freakishly long time it holds it's edge I'd say it is a step up from S30V, at least in that respect. Just my two shekels lol
S60V/440V was 440C with a bunch of vanadium added. Iirc S90V was made to address the issues that 440V had? Could be wrong about that. Now i think they reintroduced S60V with tweaks that also fixed problems with the original.JonLeBlanc wrote: ↑Fri Aug 23, 2019 7:35 amThat's right it was an early one, and somebody please correct me if I'm wrong but isn't it a PM version of one of the 400-series steels? Like 460 or 420, something... IdkGenotoxic wrote: ↑Thu Aug 22, 2019 4:41 pmThis is very true, actually come to think if it S90V was one of the first ultra high end steels to come to the market. Since then we've just be flooded with so many options haha, nothing to complain about though!JonLeBlanc wrote: ↑Thu Aug 22, 2019 4:03 pmWell, to my knowledge S90V is a "prototypical" high-carbide particle steel, and at this point there may not be much novelty in that class of metals, but it's still very hard and quite corrosion resistant. I only own one knife with an S90V blade but based on the freakishly long time it holds it's edge I'd say it is a step up from S30V, at least in that respect. Just my two shekels lol
- Deadboxhero
Not at all.JonLeBlanc wrote: ↑Fri Aug 23, 2019 7:35 amThat's right it was an early one, and somebody please correct me if I'm wrong but isn't it a PM version of one of the 400-series steels? Like 460 or 420, something... IdkGenotoxic wrote: ↑Thu Aug 22, 2019 4:41 pmJonLeBlanc wrote: ↑Thu Aug 22, 2019 4:03 pmWell, to my knowledge S90V is a "prototypical" high-carbide particle steel, and at this point there may not be much novelty in that class of metals, but it's still very hard and quite corrosion resistant. I only own one knife with an S90V blade but based on the freakishly long time it holds it's edge I'd say it is a step up from S30V, at least in that respect. Just my two shekels lol
They just used 440 17%cr and 420 14%cr amounts as starting points and added the carbon vanadium needed to blast em out with super hard Carbides that they would shrink with PM.
440v/s60v and 420v/s90v
Larrin crushed all the crucible steel history, it was facinating to talk to him about it. Turns out they had several other verisons I was not aware of until he told me about them such as 420vn and s145v that they decided not to develop.
Is it true S90V is a little more stable at the edge meaning less prone to small dings and chips than S110V? I have super limited use with S110V but my S90V knives never seem to take damage through normal cutting where as even just S30V will have some micro chips after breaking down a lot of boxes.ZrowsN1s wrote: ↑Thu Aug 22, 2019 7:38 pmThere are pluses minuses and trade offs to all steels. I was talking to someone not too long ago about why they preferred S90V to S110V. S110V has greater wear resistance than S90V but is not by coincidence harder to sharpen. They found S90V to be for them a better balance of wear resistance and ease of sharpening than S110V. It does best with a coarse edge, but I find it holds a polished edge nicely too. And it is fairly stainless.
In short if you're looking for something that is a small step back from the extremes of S110V, S90V is a little more of a balanced steel, while still being high performance, wear resistant, stainless high carbide steel.
Interesting... did it rust through testing pushing the steels to their limit or just normal use?
Was S145V created and deemed too extreme after the first round of testing or was it just a steel formulated on paper that never came to reality?Deadboxhero wrote: ↑Fri Aug 23, 2019 7:58 amNot at all.JonLeBlanc wrote: ↑Fri Aug 23, 2019 7:35 amThat's right it was an early one, and somebody please correct me if I'm wrong but isn't it a PM version of one of the 400-series steels? Like 460 or 420, something... IdkGenotoxic wrote: ↑Thu Aug 22, 2019 4:41 pmJonLeBlanc wrote: ↑Thu Aug 22, 2019 4:03 pmWell, to my knowledge S90V is a "prototypical" high-carbide particle steel, and at this point there may not be much novelty in that class of metals, but it's still very hard and quite corrosion resistant. I only own one knife with an S90V blade but based on the freakishly long time it holds it's edge I'd say it is a step up from S30V, at least in that respect. Just my two shekels lol
- Naperville
Sal, Eric and all the good folks at Spyderco are some of the luckiest people in the world, and we are a close second.
Spyderco employees working with R&D, get to work with steels we have never heard or previously seen. Yea, I'm a steel nerd and I cannot think of a better company.
I Support: America’s Warrior Partnership, Second Amendment Foundation(SAF), Gun Owners of America(GOA), Firearms Policy Coalition(FPC), Knife Rights; The Dog Aging Institute, Longevity Biotech Fellowship, https://andrewsteele.co.uk/ageless/how-you-can-help/
- JacksonKnives
It should be, slightly, if everything else is the same (hardness, geometry, optimization of HT.Genotoxic wrote: ↑Fri Aug 23, 2019 9:55 amIs it true S90V is a little more stable at the edge meaning less prone to small dings and chips than S110V? I have super limited use with S110V but my S90V knives never seem to take damage through normal cutting where as even just S30V will have some micro chips after breaking down a lot of boxes.
S90 is pretty chippy compared to something like M4, and that's still not a steel I've had much luck with below 12DPS.
IMO, with any high-carbide steel you need the thickest edge that still allows the slicing you need in the materials you're cutting, and then find an edge finish that's easy to maintain with your sharpening gear. Micro-bevels can help in most cutting, but if you're loading S90V from the side you can blow out a chunk from a thin edge.
For a work knife or a kitchen knife I'll take it to a scary low angle, then keep increasing the angle every time I sharpen until I'm no longer grinding back scary chips.
S90V feels like the "classic Spyderco flavour" to me. There are other steels that are better on paper, and I wouldn't blame them if they retired it, but S90V is a good balance that will always have a prominent place in the showcase.
I have never found s90v chippy at 26-30 inclusive. I've also not found s110v chippy at 22-24 inclusive. I didn't own any s90v knives long enough to really push the sharpening angle. But it cut 4-5 inch thick rope saturated in silt, mud, and grit dredged up from Jacksonville and Charleston Harbors at less than 30 inclusive without chipping. And let me just say that this is absolute torture on an apex. Some lines would blunt s110v in on cut (from 300-400 grit hair whittling to borderline severe edge damage - working edge gone), so s90v certainly isn't too delicate at the apex in my experience. But it didn't hold the working edge quite as long as s110v when subject to such torturous cuts.
- Deadboxhero
Well that sounds very exciting when you put it that way but I like to speculate that back in the late 1990's when they made it they decided on having a better balance of attributes for industrial wear and cutting needs not fancy pocket knives directly.
So they weren't seeing back than what makes you so excited to see in a knife today.
Genotoxic wrote: ↑Fri Aug 23, 2019 9:59 amWas S145V created and deemed too extreme after the first round of testing or was it just a steel formulated on paper that never came to reality?Deadboxhero wrote: ↑Fri Aug 23, 2019 7:58 amNot at all.JonLeBlanc wrote: ↑Fri Aug 23, 2019 7:35 amThat's right it was an early one, and somebody please correct me if I'm wrong but isn't it a PM version of one of the 400-series steels? Like 460 or 420, something... Idk
- Location: Northern California in the heart of the Gold Country
I kinda grew up with CPM S90V and if I was limited to one blade steel for the stainless application it would be 90V. CPM S110V is very close in all aspects but somewhat harder to work with. CPM S30V and ELMAX in that class would be a close second, Simple operations like drilling on CPM S110V require caution or it will be one drill one hole on the smaller bits like 1/8 inch. Early on I made a lot of fillet knives with 90V but now feel it is overkill and like CPM 154 or CPM S30V for them. All the higher alloy grades trade ductility for hardness and wear resistance and heat treat ( hardness) edge geometry, plus sharpening have to be optimized to the task. Torsion and chopping loads are the worst for high alloy high hardness blades CPM S90V has a nice balance for a hunter or bird and trout or everyday carry blade.
We now have a whole stable of great blade steels that are more alike than different but CPM S90V stands out in my mind. Crucible has made some small, small, changes since first introduced that have helped with heat treat and grinding and finishing. Phil
Your posts and sheer presence here are always appreciated.Phil Wilson wrote: ↑Fri Aug 23, 2019 1:49 pmI kinda grew up with CPM S90V and if I was limited to one blade steel for the stainless application it would be 90V. CPM S110V is very close in all aspects but somewhat harder to work with. CPM S30V and ELMAX in that class would be a close second, Simple operations like drilling on CPM S110V require caution or it will be one drill one hole on the smaller bits like 1/8 inch. Early on I made a lot of fillet knives with 90V but now feel it is overkill and like CPM 154 or CPM S30V for them. All the higher alloy grades trade ductility for hardness and wear resistance and heat treat ( hardness) edge geometry, plus sharpening have to be optimized to the task. Torsion and chopping loads are the worst for high alloy high hardness blades CPM S90V has a nice balance for a hunter or bird and trout or everyday carry blade.
- Deadboxhero
Phil, I just got a bar of the newer s125v from Niagara. They have made improvements over the old batch you experienced that was having some issues back in the day.
Really pops up in Hardness and has more aggression on the rope than what I've experienced with the other stainless grades from Crucible.
- curlyhairedboy
Phil, thanks again for chiming in!
For one thing it is a very high wear resistant steel that still retains some desirable qualities in mass produced knives intended for the general public, namely some modicum of toughness and stainlessness.
Another huge factor is marketing. It was one of the first ultra premium super steels, it has good name recognition, has a bit of a ring to it, and is pretty well regarded and adopted throughout the industry. Kind of like m390 currently.
I enjoy S90V because like M390 (and it’s counterparts) you get great edge retention without super high hardness. For me that means it’s a little tougher and easier to maintain than some of the other high hardness stainless steels. It may lose that razor edge somewhat quickly but I love that it seems to hold a working edge forever. It also likes a coarse edge meaning I spend less time taking it down to finer grit stones.
Normal use, in my pocket. I've had it both from sweat and rain but sweat is the big one. I've never had it so bad that it wouldn't wipe off or that it pitted but I've had spot rust.
