This is a pretty good assessment and I concur with pretty much all of it, although I would probably be fine using the Nilakka as a hiking/work knife if I put a thicker bevel on it. I have the same criticisms as Brock, sharp edges, tight clip, etc., but still this is one of my favorite Spyderco designs. Overall a very nice cutting tool that could use a couple of tweaks.Brock O Lee wrote:Once I discovered thin edges, I realized that I quite enjoy having a variety of thicknesses at my disposal. It is one more aspect of this hobby to experiment with and enjoy. I will certainly not take my Nilakka as a primary knife on a hiking trip or on a construction site, but it is perfectly robust enough for typical cutting tasks around the house and office: food, cardboard, packages etc. I use it for the same tasks as the other thin full-height convexed folders with micros like the Caly 3 SB and Stretch SB, and I never had an issue with them either. In fact my Caly SB is thinner behind the edge than the Nilakka.
I have a few criticisms:
- the handle is thick, so it does not carry as unobtrusively as most of my other Spydercos.
- sharp edges/corners on the G10 - I sanded them down, which improved the ergos, but it is not a melt in the hand type of handle.
- the clip is tight, and presses down on a screw hole in the G10, which grabs your pocket on a draw - fixable with some sandpaper.
Still, it has a lot going for it. It is an impressive slicer in a striking design, lockup is solid and smooth, it is very flick-able, and mine had the usual flawless Taiwan fit and finish.
I would very much love to see a Nilakka sprint with a different steel (M4? K390? Cruwear?!?)
