Page 2 of 2
Posted: Wed Jan 23, 2013 9:13 am
by Brisket
Once I get a patina to my liking I wipe the blade with Marine Tuf-Cloth. I have one SB Caly 3.5 that I wiped with a Tuf-Cloth from the beginning that has never developed a patina. I've also polished off existing patina and started over again.
kbuzbee - I'm curious about the wire clip you added to your GB Air. How is that attached.
Posted: Wed Jan 23, 2013 9:20 am
by kbuzbee
Brisket wrote: - I'm curious about the wire clip you added to your GB Air. How is that attached.
short answer - Dremelled a channel between the scale and the liner. I put a bit of epoxy to strengthen it but I'm not sure that was required. Seemed pretty strong without it.
Ken
Posted: Wed Jan 23, 2013 9:25 am
by d.2.the.p
I was initially considering submerging the blade in vinegar in order to get an even patina like this (pics courtesy of mongatu on blade forums): http://www.bladeforums.com/forums/showt ... Blue/page4
However, after seeing some of the pics in this thread, I may need to reevaluate.
Posted: Wed Jan 23, 2013 11:06 am
by Brisket
kbuzbee wrote:short answer - Dremelled a channel between the scale and the liner. I put a bit of epoxy to strengthen it but I'm not sure that was required. Seemed pretty strong without it.
Ken
Clever solution. Thanks for sharing.
Posted: Sun Jan 27, 2013 1:57 pm
by gbelleh
I just forced a patina on my new SB Caly 3 last night. This time, after previously applying Tuf-Glide to the pivot area, I dipped just the blade into a cup of white vinegar for about 25 minutes. Then, used some fine steel wool to even out the finish.
I like how it turned out. It's a little more evenly colored than the Caly 3.5 that I cut a strawberry with. The strawberry produced more of a rainbow effect. I find them both very interesting to look at. Here are some pictures.
Posted: Sun Jan 27, 2013 2:02 pm
by kbuzbee
Nice job photographing the 3.5! Those rainbow patterns are hard to catch.
Ken
Posted: Sun Jan 27, 2013 2:55 pm
by linuxology
natural patinas are better imo as illustrated in the photos.
Posted: Sun Jan 27, 2013 3:30 pm
by defenestrate
I think I might try to get that rainbow patina on my M4 Manix2, but I'm trying to keep the M4 Mili as clean as as plausible. That may change.
Posted: Mon Jan 28, 2013 12:03 am
by dub
I really like how these patinas look. I don't want to force mine, but once it happens naturally, what should I do to resist rust? That's what I'm really worried about.
Looks like the steps would be:
Tuf-Glide around the pivot/tang
Use the knife
Patina occurs
and then what to prevent rust? Is wiping it after each use enough?
Thanks guys!
Posted: Mon Jan 28, 2013 9:55 am
by d.2.the.p
KW emailed and told me that they won't have enough stock to fill my order, and I can't seem to find these anywhere else other than the bay. Sad face :( . At least I got some good information on patinas by starting this thread.
Update w/pic!
Posted: Tue Feb 05, 2013 9:23 am
by d.2.the.p
So after having received that email, a week later something showed up on my doorstep. Surprise! They were able to fill my order afterall!
I ended up going with a grapefruit patina. I really like how it turned out. Here it is:
[ATTACH]21452[/ATTACH]
Posted: Wed Feb 06, 2013 7:21 pm
by DiKa
d.2.the.p wrote:So after having received that email, a week later something showed up on my doorstep. Surprise! They were able to fill my order afterall!
This is very nice.
