Whale Rescue blade
- defenestrate
farns wrote:I know this isn't directly related to the whale blade but I got to searching and check out 13 seconds into the video.
Humpback Whale Rescued Link
I do believe it was an Atl Salt
The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants
- phillipsted
- Stuart Ackerman
I have just spent the last two hours sitting and chatting with Mike Morrisey, the man in charge of whale rescue in NZ..
Sal and Taz were kind enough to send him two whale blades, and I was able to handle one of them...
Mike had it bolted to a steel round bar, which fits into an extendable paint brush tube holder...
My meeting was to design and make a new blade for cutting rope using the "kegging method"...
The blade is attached to the rope, and the rope is attached to a bouy...and the whale diving down hopefully causes the rope to be cut when the bouy floats...
I was able to see and read the NZ Whale Rescue Manual...interesting stuff...
H1 would be the best steel for the job, but as that is a no-go, I will experiment with other steel that I have...
That said, I must get a Spyderco whale blade...it is something that I will find a need for... :D
My website...
http://ackermancustomknives.com/
Facebook...
https://www.facebook.com/ackermancustomknives/
Facebook...
- Stuart Ackerman
Too expensive...mattman wrote:three whale rescue blades in a "treble hook" configuration suspended a sufficient distance under the bouy, cutting edge up...?
The treble or quad hook works well, but we are looking for a more aggresive method of line severing...
My website...
Facebook...
Facebook...
- Stuart Ackerman
If scissors means moving action...rust will kill that soon enough...
A fixed Vee type blade to hook onto the rope is the idea...with a small "twist"...that bit I will mention later on, after testing...
The aggressiveness will hopefully be a result of the edge design...
My website...
Facebook...
Facebook...
Just saw this video on weather.com. http://bcove.me/xacq5tjn at about 25 seconds it looks like a curved blade at the end of a pole. Wonder if the Spyderco rescue blade was used.
Chris
Chris
Be Excellent to each other.
