Under the microscope
dbcad
Post by dbcad »
Magnification is always enlightening, being able to share that information via sharp pictures is not that easy. Thanks Clip :)
You can learn a lot from magnification. My own 15X lighted loupe opened a whole new world in edges with my failing eyes.
A 100X or 200X would be interesting to see, especially to notice the variability within a single sharp knife's edge ;) :D
Charlie
Clip
Post by Clip »
Pictures from today, still freshly sharpened.
The metallograph has a color camera and 50-1000x capability. Although the lenses are labeled with those magnifications, I think they're slightly different (comparing 63x on the stereo microscope and the 50x on the metallograph, they don't match up)
Also, found the option in the program to take a multi-layered picture so now the high mag pics are sharp with no DOF issues.
50x
100x - should've taken a multilayer here but didn't think about it. At this level and above, you can really start to see how the blade is wearing. I'm excited to see how different steels compare at 100-200x because I think that'll give me some idea of how the edges deteriorate over time (whether by rolling or chipping, etc).
200x - as I mentioned before, I retook these next pictures to get rid of the DOF issues. I hate that I wasn't able to find the exact spot I had before, but at 200x the blade seems a mile long through the eyepiece. I'll make sure to hold it still in the upcoming pictures.
500x
1000x
Chris
Clip
Post by Clip »
:) dbcad, ask and you shall receive.
Chris
Lagrangian
Post by Lagrangian »
Absolutely _amazing_ photos! :)
Many thanks for showing them to us.
I very much like how you are able to combine multiple images (multi-layered) into a single image to avoid the problem with depth-of-focus. Those very high magnification images are beautiful.
Do you do requests?
(1) Can we suggest you to try some stuff? (ie: specific knife + specific sharpening + cutting tests) You can always say no. ^^;
(2) Would you take photos of knives we lend to you? (To check our own sharpening technique and cut tests.)
"What grit sharpens the mind?"
--Zen Sharpening Koan
Clip
Post by Clip »
Lagrangian wrote:Absolutely _amazing_ photos! :)
Do you do requests?
Thanks! The DOF issue was killing me until I dug out the manual and found some more functionality with the program. On my Canon I would've just cranked the aperture up and dragged the shutter to compensate for reduced light.
Requests:
I'd love for you guys to throw ideas out there, and I wouldn't mind trying them if they sound reasonable and I've got some spare time to use the equipment. I think it'd be neat to try apples-to-apples comparisons. Gimme some suggestions!
As for taking pictures of knives you guys lend: Again, wouldn't mind doing this at all. I think it'd be a great way to test way more steels, grinds, and sharpening techniques than I could ever get my hands on. I'd like input from members more experienced in shipping and receiving to chime in with a process that works for them and keeps everyone happy.
So yes to both!
Chris
Niles
Post by Niles »
Fantastic images! Thanks for sharing.
I'd love to see as many comparisons as you can muster.
Do no harm. Do know harm.
computernut
Post by computernut »
Nice photos! I was thinking of getting a 15x loupe but 1000x is impressive!
phillipsted
Post by phillipsted »
Wow. You can see the way the steel "smears" as you sharpen it - I'd love to see a burr at this magnification - I bet it would look like a big wave cresting at Oahu.
TedP
Worry less - Breathe more...
Spydie Fanatic #185
jah
Post by jah »
Wow, very cool, thanks for sharing!
Jerry
dbcad
Post by dbcad »
Terrific pictures!!!! :D , Thanks Clip, I do want a microscope, but a good one is beyond my reach. Your pictures are quite interesting. What blade material are you looking at? It would be very interesting to compare images like these between different blade materials.
Absolutely fascinating what magnification can show you :)
Charlie
Clip
Post by Clip »
Thanks guys! I should've mentioned it in the first post and I'll update. This is hollow-ground 154CM on the Manix2. I sharpened it on the 17° setting on the Lansky sharpener and when measuring with my calipers, I calculated it was something like a 28° inclusive angle.
Monday I should be able to check factory sharpened Elmax, CPM-M4 and CPM-S30V. Another test I've been thinking of is prepping and polishing the 154CM followed by etching to try and look at the carbides. If it works and I can repeat the process with the other blades I'll be able to compare carbides in the different steels.
Chris
Clip
#32
Post by Clip »
Received the M4 Manix2 and the S30V Dodo today. Threw the Dodo onto the table and got factory edge pictures at 10, 25, 40 and 63x. I should be able to get the higher-mag ones as well this evening. Don't know if I'll be able to do the Elmax and M4 today but there's going to be something new in this thread tonight!
Chris
Donut
#33
Post by Donut »
Chris, I was wondering if you're locked at a 90 degree straight angle? What kind of view of the Spyder logo texturing would you be able to give us?
-Brian
A distinguished lurker.
Clip
#34
Post by Clip »
The metallograph is built for a 90° angle so you can put mounted samples on the stage and look at them. Since the light comes up through the lens, reflects, and goes back down this works the best. However, I've been throwing the knives up any way I can get them to cooperate with the combination of stage and lens and it's working fine. I usually have to crank the light way up to get enough to reflect back to give me a decent picture. I'll try a few different angles pointing at the bug tomorrow to see.
Chris
Clip
#35
Post by Clip »
As promised, here are pictures of a factory fresh orange S30V Dodo. Looks like the blade is sharpened at a steeper angle on the bug side compared to the origin side. I'll try and get pictures of the slightly different grind tomorrow. The 10-63x pictures were on the origin side, what I guess is close to a 20° angle on my Lansky sharpener. The pictures from 50-1000x are on the bug side, 17° according to Lansky . I got a good technique down with this blade because it was so short. We'll see if it works tomorrow on the M4 Manix.
On these next four pictures, it almost looks like the factory puts an extremely small secondary bevel on the edge. The light seems to catch or dodge it. On the higher magnifications where I was looking at the 'belly' of the hawkbill, I didn't see the same thing happening.
10x -
25x
40x
63x
50x
100x
200x
500x
1000x
Chris
Drkknight614
#36
Post by Drkknight614 »
That 1000x magnification is nuts. Love it. That dodos not chipped but seems to have a wavy edge. But thats why sometimes all you need to do is a few mintues of stropping and you can totally transform and edge from crazy sharp to, holy crap laser sharp.
Manix 2 DLC, Delica 4 FFG, Ladybug 3,County Comm H1 Ladybug 3 , Endura 4 FFG G10, C94 UKPK Leaf, Atlantic Salt, Military Camo DLC,Sage 1 Para 2 DLC, Delica 4.
Clip
#37
Post by Clip »
Speaking of, does anyone have a good link on how to get started stropping?
Chris
C.L.L 97
#38
Post by C.L.L 97 »
Clip wrote:Speaking of, does anyone have a good link on how to get started stropping?
Look up stropman.com(great strops). The pics are great, I never thought that's what a knife edge would look like,it's really cool...
I have a question about loupes, what is the best ones to get,and how much do they go for??
Thanks
Caden's :spyder:'s-g10 dragonfly, digicamo para2,bug,honeybee,sharpmaker.
Newest :spyder: manix 2 lightweight.
:spyder: top wishlist: junior,D4,E4,,h1 D'fly salt,h1 ladybug salt,g10 manbug,caly3•3.5,all sprint para2's
Have to have= brad southard flipper, gayle bradley:spyder:
"combat knife is actually 10% weapon and 90% tool".~ Al Mar
Clip
#39
Post by Clip »
C.L.L 97 wrote:Look up stropman.com(great strops). The pics are great, I never thought that's what a knife edge would look like,it's really cool...
Thanks
I'm sure people more knowledgeable will chime in but I think people get something in the 10-20x range.
Chris
holymolar
#40
Post by holymolar »
The wavy edge on the Dodo appears to be the result of the deeper cuts. They continue all the way to the edge and it is particularly evident in the 100x and 200x views. I would like to see if that wavyness straightens out by removing those deeper cuts after reprofiling with higher grits (such as choseras).
