Best slicer made by Spyderco?
- Random Chance
My best slicer hands down is the J.D. Smith. The blade is thin from edge to spine so there's less to drag and it glides through stuff. The Centofante 3 also is a pretty good slicer with the thin blade stock and the hollow grind. The Caly 3.5 is no slouch either, thin behind the edge and great ergos.
- razorsharp
An H-1 fillet knife is a super-slicer
Yeah I will concur that the newer H-1 USN Catcherman may actually have the best slicing ability of any Spyder to date. But the MBS-26 models do sharpen pretty nicely.razorsharp wrote:USN catcherman :p . Otherwise Caly 3, 3.5, Chaparral, I hear the chokwe and sage are crazy slicers too
Now I also do like the older AUS-8 full SE Catcherman for all types of food prep>> I even like the Spyderedged version much better than I do the CE version>> The AUS-8 blades were considerably thicker thus inhibiting their slicing ability somewhat.
The newer/thinner H-1 version should be here to stay in my opinion. An H-1 fillet knife just makes perfect sense all the way around :cool:
Not much help here...cause I honestly think the best slicer is my gray FFG Delica....well outta my bunch anyway...
My Spydies: Sharpmaker • Tasman Salt • Saver Salt • Ladybug Hawkbill Salt • Salt 1 • Blue/Gray Meerkat • Burgundy Meerkat • Manix2 Ltwt Translucent Blue • Manix2 Ltwt Blacked Out • Manix2 Backlock • Ladybug 1 Red • Blue UKPK • Tusk • Blue Lava • Dog Tag • Bug • Honeybee • Grasshopper • Stepped Ti Chaparral • McBee • AEB-L Urban
Agree w / others who mentioned the Catcherman.
- razorsharp
Fred Sanford
In the 3" - 4" range I bet the Centofante III will out-slice everything you put up against it.
It really is that good.
The Centofante III has a 2mm blade and it's hollow ground which means that behind the edge it is most likely thinner than the Chaparral.
The newer Catchermans much thinner
First of all you have 3 generations of the Catcherman model. The older AUS-8 models which had a much thicker blade that was hollow ground was succeeded by a flat ground MBS-26 model which had a much thinner blade.razorsharp wrote:catcherman has a, what? 1.5mm stock and a nice thin hollow, its amazing for food
Now I do believe that the newest H-1 Sprint model has the same or close to the same thickness of blade as the MBS-26 model had.
Albeit all of the Catcherman models are super good slicers and are good for any type of food prep, field dressing, fish processing or any other cutting chore where a thin blade is advantageous.
I do not have the Catcherman, Chokwe, or Chapparal, so I cannot comment on their slicing ability. However, of all the 50+ Spyderco's I do have, the one that slices WAY better than the rest is the Junior. With its FFG design and wide bevel, it is the smoothest and sharpest knife I own for slicing. The handle design and jimping also made it really easy to grip and control.
The important thing was that I had an onion tied to my belt, which was the style at the time. You couldn't get white onions, because of the war. The only thing you could get was those big yellow ones...
- jackknifeh
- captnvegtble
- Farmer Brown
I'll second that, though I haven't tried some of the others listed above...SQSAR wrote:ZDP Stretch is the best Spyderco slicer I've got.
1. There is a time and place for everything.
2. Not everybody shares your views.
3. Common sense and basic courtesy gets one far.
4. Know your local laws.
5. "Sheeple" is a bigot's term.
- Orlando De Free
I've owned a few of the usual suspects i.e., Caly3 ZDP, Calypso Jr ZDP, and others with FFG. I've found that the best slicer I've used is the Anso Zulu with the high hollow grind. The comfortable handle also helps in positioning the knife for different angles of slicing.
Orlando
If you didn't get my dirty joke it's because you have no sense of humus - Mom De Free
:spyder: Currently own
Ladybug 3 se, Assist, Ladybug se w/photon, Techno, Rubicon, Manbug ZDP, Dice
