S35VN has the same hardening response, so there is no issue with getting it hard. It would be expected to have a slightly lower wear resistance than S30V, but this is needed to get the toughness and grinding/polishing improvement required. This decrease in wear resistance would be expected to be on the order of 10-15% only which would be at most a 5-10% difference in a CATRA result. There would thus be FAR more difference from one blade to the next than between two knives in the two steels.The Mastiff wrote: It might take a bit of adjusting to get the geometries and hardness right with this still relatively new steel.
Note even if you take fairly dramatic steel differences such as S30V and ZDP-189 and you take a half dozen blades of each, some of the S30V ones can match and even over take some of the ZDP-189 ones in long term wear comparisons, again due to differences in the steel itself from batch to batch, then issues with heat treatment, etc. . If you average the results of the S30V blades and average the results of the ZDP-189 blades you will see a clear advantage from ZDP-189 in such work, but point to point ones can be misleading.
