New Caly III ZDP, Chipped already
Cliff Stamp
Post by Cliff Stamp »
Metal cutting can be highly random due to method as a little twisting in the cut can chip an edge. You can cut a piece of wire ten times and get no damage and then significant damage on the next. I would not be concerned with visible chipping just from one cut. Since the edge is chipped use it to to some scrap cable 10-20 times and see what happens. If it continues to happen then you know there is a problem with the existing edge, then you sharpen and repeat it to see if that fixed it. It is a knife, not a rose, they only improve with use as you get more familiar with them.
-Cliff
anthonyc
Post by anthonyc »
knife is already in the mail, i have a few others to hold me over till i get it back. on a side note, is the notch at the heel of the blade supposed to be there?
anthonyc
Post by anthonyc »
update
got my caly back, better than new. thank you spyderco!
mrappraisit
Post by mrappraisit »
Woo Hoo! Have fun with the "new" and improved Caly!
After enlightenment, the laundry.
