CPM 15V Sprint sharpening and performance thread
Re: CPM 15V Sprint sharpening and performance thread
SFO had about 40 in stock as of 15 min ago. Go get ‘em!!!
Mule Team Army 001
MNOSD 008
MNOSD 008
- Slalomnorth
Finally sharpened my pm2 tonight. It has been performing well with just the factory edge so I haven’t needed to sharpen it really.
Started with dmt 325, burr both sides no problem. Moved to dmt 600 flipped burr. Then deburring strokes. Deburred VERY easily, and I’m not just saying that. A few light strokes on unloaded basswood to clean up any residual burr. No strop, done. Really good aggressive edge barely whittles hair.
These pretzels are making me thirsty
True story, this 15V deburrs better than anything I've sharpened before.
MNOSD member #0035
MNOSD member #0035
First day on the job, cut a few bits of boxes and cut through a scrap piece of wiring harness, no noticable difference to the edge. I will say though, it wasn't quite as sharp as other new Spyderco's I've gotten, would really only scrape-shave but it's still having no problem making clean cuts through things. I plan on using the factory edge until it's significantly dull or until I start seeing edge damage.
I'm probably late to this party and can't tell y'all anything you don't already know but I was out doing yard work today and beat on my Shaman pretty good. I didn't bother with any pics because it was just routine stuff, mostly saplings and weeds but I did cut a couple really thick jumbo sized zip ties. The edge didn't see any significant changes, didn't seem any more dull but also this knife came surprisingly less sharp than most that I've received. I did have a moment of absolute frustration after trying to cut through the zip tie about 3 times before it made the cut and remembered why I prefer serrations so much but overall I'm impressed so far with this steel. I was planning on using the factory edge for a while but I decided to touch it up on my Sharpmaker and I was really impressed with how it sharpened up, it was a far easier and more responsive experience than Maxamet and based on that alone I would buy this steel again over Maxamet.
Sometimes with Maxamet it just feels like I can't get past like 80-90 percent sharp if that makes sense, like I can't quite get it as sharp as other steels no matter how many passes on a stone I make, even if I start with a lower grit and burr it and do my best to deburr it. Maybe this is micro chipping or whatever, I can't see any burr or chips with my 10x loupe so if it's chipping out it definitely is micro in size. These edges still cleanly slice phone book paper but won't push cut. Doing the same sharpening technique (basically just Sharpmaker DVD stuff) I got a hair popping sharp edges and can whittle the hair on my arm if I'm steady enough to not cut clean through it.
It's overall a weird feeling not using serrations after so many years. I would assume the chances of seeing SE 15v are low, but then I was also shocked to see SE K390 so who knows. I would really love to try it in a Golden made knife like my Native 5 with some nice wide, low angle serrations so I can micro bevel it on the 15 degree slots.
Sal if you're reading this you should just make me a one-off and mail it my way, I'll even pay for the knife and I'll let ya know how it goes
Oh, I just realized there isn't a 15V Native 5 yet so you can make it a Shaman
- Deadboxhero
Hmmm... that's a pretty dramatic difference.
I have a some 1.0 and 0.25 micron from Ken Schwartz, enough to last the rest of my life at the rate I use it. Now I'm tempted to try the Gunny Juice, just to see for myself.
Finally pulled the trigger on some 1micron Gunny Jucie. Can’t wait to see how it does.
Deadboxhero aka Shawn. Tried to post a question on the YT thread but couldn't. Care to share what you're sharpening progression was on that Manix?
You'll definitely enjoy it. Admittedly haven't tried all the competing products out there, but have tried a few of the diamond paste style compounds over the years and Gunny Juice just blows them out of the water. Applies and dries in a couple of minutes, no gummy/stickiness feeling to it, no heat needed, and it just cuts amazing. The hype is real.
Obviously works well with 15V and been using it on my PM2 and Manix examples with great results. I should've bought the larger bottles of it
I was confusing 25 nm with 25 micron for a minute there. They're not the same right?
I have really been enjoying the finish off of a DMT 600 F credit card hone I use. It's 25 micron and a continuous electroplated diamond surface, but it is about 13 years old now so it's WELL broken in.
It makes for an extremely bitey and aggressive finish, but still able to whittle and tree top arm hair. My bare-minimum test is usually if I can pass it under my chin against the hairs and catch them and the 15V gets there so easily. It really makes me wonder why, and I think it must have something to do with the hardness and the carbide level, because the only other steel I have experienced that with is ZDP-189
- Deadboxhero
125um
40um
14um
0.5um
0.025um
- Deadboxhero
1000nm=1umkennbr34 wrote: ↑Thu Apr 13, 2023 2:37 pmI was confusing 25 nm with 25 micron for a minute there. They're not the same right?
I’ve never seen a 0.025um compound, where did you manage to get one from? I have not seen abrasives that fine before, even in optics polishing (0.050 micron is the finest I have seen).
I have .025 micron poly diamond spray from Ken Schwartz. I suspect that's where his is from, too.electro-static wrote: ↑Fri Apr 14, 2023 12:01 pmI’ve never seen a 0.025um compound, where did you manage to get one from? I have not seen abrasives that fine before, even in optics polishing (0.050 micron is the finest I have seen).
Currently testing: M398, D3, SLD-Magic
Favorites: 10V, s90v
Wishlist: S290, Vancron, S125V, K890
18 Spydies, 15 steels
13 Maxace, 9 steels
13 Maxace, 9 steels
Performed like a beast
And after. I just wiped off with finger
Still shaved hair after as well
New Cedric and Ada Gear edge retention test just dropped:
https://youtu.be/vWR9yGLmM1k
Has it outperforming K390, Maxamet, and Rex121 on just the first edge after the factory edge.
Truly impressive. BBB and Spyderco knocked it out of the park!
