Anyone into "traditional" folders?
- Midnightrider
Re: Anyone into "traditional" folders?
Are the Buck 110s still as good as they used to be? I have one from the 1980s but don't have it with me. I'd like to get another one. As I remember it the sheath was also excellent
Millies in 52100, S110V, CTS-204p, REX 45; M2 Cru-Wear, CPM15V, Magnacut; Native 5 Maxamet; P4 K390, PD#1; Pacific Salt SE/H1, PS2 LC200N; UK/PK; Autonomy H1
Wants/Wishes (only NIB and EU): Militarys in 52100, Maxamet, Cru-Wear
Yes, Virginia, that's a Purple Haze in my suit pocket :)
- xceptnl
I have only every owned the BG-42 bladed versions of the 110. I can't speak to their current heat treat recipe as I haven't used any of the 420HC blades that they have produced recently. I would expect the quality to be the same or similar to the older versions as they are still US made.Midnightrider wrote:Are the Buck 110s still as good as they used to be? I have one from the 1980s but don't have it with me. I'd like to get another one. As I remember it the sheath was also excellent
The quality is still good, but they use 420HC steel. They do use Bos heat treat to wring the most out of it, but it is still a bottom end steel. Copper and Clad and SK Knives work with Buck and make some with better steels, frame, and scale materials.
- Midnightrider
Interesting, I thought they were always 420HC. When did they change to it?
- xceptnl
The BG-42s were custom shop pieces if I recall correctly. They are available, but you have to hunt for them on the secondary market.Midnightrider wrote:Interesting, I thought they were always 420HC. When did they change to it?
Just picked up my second Barlow. Love these things.
- Mark
- xceptnl
That is a beauty Mark, probably my favorite of the synthetic covers that GEC produces. I do prefer the longpulls, but I love the sterile blades without the "banners?"
- bearfacedkiller
They have made the 110 with quite a few steels. I have come close to buying one in 5160 quite a few times. They have done S30V and 154CM too.
Thanks! Yeah, same here. Really like the long pull, and don't care so much for etching all over the blade. Usually a compromise with GEC, but man, what quality little blades. I know all that stuff is based on history though, so there's a lot of heritage Charlie C pulls from.xceptnl wrote:That is a beauty Mark, probably my favorite of the synthetic covers that GEC produces. I do prefer the longpulls, but I love the sterile blades without the "banners?"
Here's my other:
- Mark
- Midnightrider
Interesting. I did not know that. A 110 in 5160 would be a tremendous woods knifebearfacedkiller wrote:They have made the 110 with quite a few steels. I have come close to buying one in 5160 quite a few times. They have done S30V and 154CM too.
Ah OK so they were always 420HC, the standard model anyway. Thank you.xceptnl wrote:The BG-42s were custom shop pieces if I recall correctly. They are available, but you have to hunt for them on the secondary market.Midnightrider wrote:Interesting, I thought they were always 420HC. When did they change to it?
Back in the 70s, they were 440C. Unfortunately, the one I bought in 1976 was stolen about 20 years ago.Midnightrider wrote:bearfacedkiller wrote: Ah OK so they were always 420HC, the standard model anyway. Thank you.
- The Mastiff
Also:They have made the 110 with quite a few steels. I have come close to buying one in 5160 quite a few times. They have done S30V and 154CM too
D2
CPM 154
440C ( first model)
425M ( second model)
BG 42 ( custom shop and some build outs in the 110 )
ATS 34
Various Damascus steels
The 5160 sharpens easier than any Buck I've seen. There are likely more. These steel versions are relatively common on the secondary market.
Joe
- Midnightrider
Sorry to hear that. I hate criminals. Had some stuff stolen, it's a bad feeling.dsvirsky wrote:Back in the 70s, they were 440C. Unfortunately, the one I bought in 1976 was stolen about 20 years ago.Midnightrider wrote:bearfacedkiller wrote: Ah OK so they were always 420HC, the standard model anyway. Thank you.
- Midnightrider
D2 sounds interesting. 425M rings a bell but maybe I am just hallucinating. Thanks everybodyThe Mastiff wrote:Also:They have made the 110 with quite a few steels. I have come close to buying one in 5160 quite a few times. They have done S30V and 154CM too
D2
CPM 154
440C ( first model)
ATS 34
Joe
- The Mastiff
The D2 models were made for a knife store that kind of specializes in this. I don't remember if it is the same store that had the run of 5160 -110's built but it might be. I saw the D2 models in stock as late as last week but they probably won't last much longer. I believe they also stated that Buck told them there will not be any more BG 42 runs made. That was always a low production number but popular steel. I had 2 custom shop 110s in BG 42 but got rid of one of them. It's a beautiful knife that really performs well with the Bos heat treat and I'm going to keep my last one the rest of my life.
Joe
Joe
The 110 was originally 440C and it was heat treated to get the most from that steel. Because of production changes they went to 425M in the 1980's. I do not remember when, but sometime in the early 1990's they switched to 420HC. There is a lot about this on the Buck sub-forum on Bladeforums.Midnightrider wrote:Interesting, I thought they were always 420HC. When did they change to it?
They did make some in BG-42 from the Custom Shop and limited runs. The same is true for D2, I believe. The do make one in S30V for Cabelas, currently.
Other steels have been made by Buck for specialty makers like Copper and Clad, and SK Blades. These two companies have done S30V, D2, and others.
- Midnightrider
Thanks guys. I guess mine just be 440 or 425 then since I bought it in the early 1980s. I can't put my hands on it now. I was so used to reading 420HC in the last decade I must have brainwashed myself into confusion.
I've never had a 110, but didn't Puma pretty much rip Buck off?
This one's from the 70's. It does get rather keen. Super keen even. :cool:
- Mark
- xceptnl
This is a great thread and we need to post here more. Today I am sharing my favorite model of traditional that I have ever encountered.
#15EO Scout with sheepsfoot longpull blades. No other slipjoint has ever caught my eye like this one. I blame a fellow forum member (prime77) for giving me the sickness.
