Page 8 of 9
Posted: Wed Feb 24, 2010 5:37 pm
by VashHash
On a side note a co worker of mine didn't beleive i RIT dyed these he thought they were factory
Posted: Fri Jul 16, 2010 4:13 am
by Bluntrauma
So, I wanted to bring this up to pose a question. I am thinking of buying a yellow Atlantic Salt to dye. I am wanting to get a neon green. Has anyone tried this or, do you think it would work using this formula I found on an unrelated forum?
http://forums.insidelacrosse.com/showth ... p?t=122448
Posted: Fri Jul 16, 2010 9:54 am
by SMI
TooSharp wrote:Here is a pic of my orange H1 Ladybug. I'll be pocket carrying this one with change\usb drive and what ever else makes it in there. I'll report back it a couple of weeks with a wear report.
Dude that orange is very very sweet.
I actually messed around with my camera a few weeks back and created some pics of possible dye colors. Thought it might give people a rough idea of what the dyes may look like on their frn handles.
http://spyderco.com/forums/showthread.p ... =40+colors
Posted: Fri Jul 16, 2010 10:47 am
by JNewell
Bluntrauma wrote:So, I wanted to bring this up to pose a question. I am thinking of buying a yellow Atlantic Salt to dye. I am wanting to get a neon green. Has anyone tried this or, do you think it would work using this formula I found on an unrelated forum?
I'm not an expert, but I've done some dying, and I'd bet that works well on white FRN. Not completely sure about results on yellow, but it's worth a try.
Posted: Fri Jul 16, 2010 1:35 pm
by Bluntrauma
I'm not sure either but I noticed that they used yellow dye and green dye. I figured since the knife was yellow already that there might be a possibility of achieving the right shade.
Posted: Fri Jul 16, 2010 7:05 pm
by Blue72
I was thinking of using the bright aqua blue dye to create a neon green on my yellow h1 ladybug
Posted: Fri Jul 16, 2010 7:17 pm
by JNewell
dd61999 wrote:I was thinking of using the bright aqua blue dye to create a neon green on my yellow h1 ladybug
Won't work - the yellow FRN doesn't "mix" with the blue dye. You'll get something blue, not green.
Posted: Fri Jul 16, 2010 7:19 pm
by Buckles
JNewell wrote:Won't work - the yellow FRN doesn't "mix" with the blue dye. You'll get something blue, not green.
x2 i used a royal blue dye on my yellow atlantic and it came out dark blue
Posted: Sat Jul 17, 2010 1:45 am
by lamarrk
Are you you all just dropping the whole knife into the dye?
I realize some of the handles aren't removable and that's probably what has to happen. Has anyone noticed a negative impact on the metal parts, such as rust, corrosion, or patina changes?
I may have missed the answer to my question, and I apologize if someone's already posted it.
Posted: Sat Jul 17, 2010 2:48 am
by Buckles
lamarrk wrote:Are you you all just dropping the whole knife into the dye?
the only knife i have dye'd was the atlantic which has H1 steel. i have not seen any change in the steel what so ever, i do not know how the other steels will react though
Posted: Sat Jul 17, 2010 9:15 am
by Blue72
I have done a vg-10 ladybug and it had no effects whatsoever. Just clean the knife when you are done and it is good as new
Posted: Sat Sep 25, 2010 7:17 am
by Cave Dave
Inspired by the OD green Ladybug I did an olive drab this morning for my PE Aqua Salt. I had wanted to get a black PE and a yellow SE. But the place I ordered was all out of black. I needed a way to differentiate the knifes while in the sheath though and different colored lanyards just wasn't doing it.
Check out the results. I like this better than the black!
The close up shows a bit of color bleed through from the yellow. It spent about 5-7 min in the rit dye. I would take it out every few min and give it a hot water rinse to check dye penetration. I thought I over did it but just kept rinsing it off in very hot tap water and it lightened up a bit. I am very happy with the results so far.
Posted: Sat Sep 25, 2010 8:16 am
by CanisMajor
I like the OD, nice work!
Canis
Posted: Sat Sep 25, 2010 11:19 am
by Blue72
Yes just keep in mind if you spend a lot of time in the water the dye will fade and it will need to be dyed again.
With RIT color remover you can strip about 95% of the dye and change colors if you like
Posted: Sat Sep 25, 2010 9:45 pm
by THG
I haven't dyed any knives, but I got a free pink ipod shell and dyed it black. After a couple weeks in my pocket daily, the corners are starting to rub off. Also, it comes off in large amounts when it comes in contact with soap water or alcohol, but it doesn't come off at all with water.
Posted: Sun Sep 26, 2010 12:44 am
by SaturnNyne
Very nice, Dave! Definitely better than black.
Posted: Sun Sep 26, 2010 7:43 am
by cosmo7809
Very very nice!
I am looking for a color to dye my pink manix.... :eek:
Posted: Sun Sep 26, 2010 7:51 am
by Bluntrauma
That looks much better than black. Great job and good looking blade!!
Posted: Sun Sep 26, 2010 9:17 am
by Jester
Has anyone tried dyeing the gray FRN? Wouldn't be as great as white (or maybe natural/undyed FRN ;) ?) but at least it is neutral.
Posted: Sun Sep 26, 2010 11:21 am
by Creepo
Jester wrote:Has anyone tried dyeing the gray FRN? Wouldn't be as great as white (or maybe natural/undyed FRN ;) ?) but at least it is neutral.
If you wanted a dark color it should theoretically work fine, lighter colors will probably end up being grayish or so.
