RIT-dyed white spydies -- how are they holding up?
VashHash
#141
Post by VashHash »
On a side note a co worker of mine didn't beleive i RIT dyed these he thought they were factory
Bluntrauma
#142
Post by Bluntrauma »
So, I wanted to bring this up to pose a question. I am thinking of buying a yellow Atlantic Salt to dye. I am wanting to get a neon green. Has anyone tried this or, do you think it would work using this formula I found on an unrelated forum?
http://forums.insidelacrosse.com/showth ... p?t=122448
Sometimes you gotta kick at the darkness until it bleeds daylight.
AKA: Liveitloud on Blade Forums, USN, EDC, Benchmade forums and basically everywhere but here.
liveit_loud on Ebay.
SMI
#143
Post by SMI »
TooSharp wrote:Here is a pic of my orange H1 Ladybug. I'll be pocket carrying this one with change\usb drive and what ever else makes it in there. I'll report back it a couple of weeks with a wear report.
Dude that orange is very very sweet.
I actually messed around with my camera a few weeks back and created some pics of possible dye colors. Thought it might give people a rough idea of what the dyes may look like on their frn handles.
http://spyderco.com/forums/showthread.p ... =40+colors
JNewell
#144
Post by JNewell »
Bluntrauma wrote:So, I wanted to bring this up to pose a question. I am thinking of buying a yellow Atlantic Salt to dye. I am wanting to get a neon green. Has anyone tried this or, do you think it would work using this formula I found on an unrelated forum?
I'm not an expert, but I've done some dying, and I'd bet that works well on white FRN. Not completely sure about results on yellow, but it's worth a try.
Bluntrauma
#145
I'm not sure either but I noticed that they used yellow dye and green dye. I figured since the knife was yellow already that there might be a possibility of achieving the right shade.
Blue72
#146
Post by Blue72 »
I was thinking of using the bright aqua blue dye to create a neon green on my yellow h1 ladybug
JNewell
#147
Post by JNewell »
dd61999 wrote:I was thinking of using the bright aqua blue dye to create a neon green on my yellow h1 ladybug
Won't work - the yellow FRN doesn't "mix" with the blue dye. You'll get something blue, not green.
Buckles
#148
Post by Buckles »
JNewell wrote:Won't work - the yellow FRN doesn't "mix" with the blue dye. You'll get something blue, not green.
x2 i used a royal blue dye on my yellow atlantic and it came out dark blue
8 :spyder:'s and counting
AtlanticSalt, Endura, Endura4 FFG, "Custom" Native, Delica4, Bug, Honeybee,Grasshopper, Poliwog, TasmanSalt, Forager
lamarrk
#149
Post by lamarrk »
Are you you all just dropping the whole knife into the dye?
I realize some of the handles aren't removable and that's probably what has to happen. Has anyone noticed a negative impact on the metal parts, such as rust, corrosion, or patina changes?
I may have missed the answer to my question, and I apologize if someone's already posted it.
Buckles
#150
Post by Buckles »
lamarrk wrote:Are you you all just dropping the whole knife into the dye?
the only knife i have dye'd was the atlantic which has H1 steel. i have not seen any change in the steel what so ever, i do not know how the other steels will react though
Blue72
#151
Post by Blue72 »
I have done a vg-10 ladybug and it had no effects whatsoever. Just clean the knife when you are done and it is good as new
Cave Dave
#152
Post by Cave Dave »
Inspired by the OD green Ladybug I did an olive drab this morning for my PE Aqua Salt. I had wanted to get a black PE and a yellow SE. But the place I ordered was all out of black. I needed a way to differentiate the knifes while in the sheath though and different colored lanyards just wasn't doing it.
Check out the results. I like this better than the black!
The close up shows a bit of color bleed through from the yellow. It spent about 5-7 min in the rit dye. I would take it out every few min and give it a hot water rinse to check dye penetration. I thought I over did it but just kept rinsing it off in very hot tap water and it lightened up a bit. I am very happy with the results so far.
CanisMajor
Post by CanisMajor »
I like the OD, nice work!
Canis
Dare. Risk. Dream.
"Your body may be gone, I'm gonna carry you in.
In my head, in my heart, in my soul.
And maybe we'll get lucky and we'll both live again.
Well I don't know. I don't know. I don't know. Don't think so."
- Modest Mouse "Ocean Breathes Salty"
Blue72
#154
Post by Blue72 »
Yes just keep in mind if you spend a lot of time in the water the dye will fade and it will need to be dyed again.
With RIT color remover you can strip about 95% of the dye and change colors if you like
THG
#155
Post by THG »
I haven't dyed any knives, but I got a free pink ipod shell and dyed it black. After a couple weeks in my pocket daily, the corners are starting to rub off. Also, it comes off in large amounts when it comes in contact with soap water or alcohol, but it doesn't come off at all with water.
Im not good at sharpening, even with a sharpmaker. How get your blade good can your blade with an edge pro system? - Bladeforums user
Has anyone really been far even as decided to use even go want to do look more like? - Some Online Meme
SaturnNyne
#156
Post by SaturnNyne »
Very nice, Dave! Definitely better than black.
"Nothing makes a knife maker-designer feel better than to see their efforts used." -Ed
~ My knives list ~
~ Knife photos ~
cosmo7809
#157
Post by cosmo7809 »
Very very nice!
I am looking for a color to dye my pink manix.... :eek:
Bluntrauma
#158
That looks much better than black. Great job and good looking blade!!
Jester
#159
Post by Jester »
Has anyone tried dyeing the gray FRN? Wouldn't be as great as white (or maybe natural/undyed FRN ;) ?) but at least it is neutral.
Creepo
#160
Post by Creepo »
Jester wrote:Has anyone tried dyeing the gray FRN? Wouldn't be as great as white (or maybe natural/undyed FRN ;) ?) but at least it is neutral.
If you wanted a dark color it should theoretically work fine, lighter colors will probably end up being grayish or so.
