Show your Mule
standy99
Re: Show your Mule
#1221
Post by standy99 »
I’m up for a set of 100% infill NylonX with bolts.
Whatever the cost + shipping. Send me a PM when you want.
Happy to test them out and give feedback
Black would be easy to spruce up with a 1mm G-10 liner in lime green or orange.....
Can you start a thread with 3D printing scales :cool:
izzoyournizzo
Re: Show your Mule
#1222
Post by izzoyournizzo »
I'll reach out once I've perfected the prototypes. There is still some fitting that I am still working through.
We have been discussing in the thread "Mule Scale CAD files?".
Thanks for your interest.
TomAiello
Re: Show your Mule
#1223
Post by TomAiello »
Standy, if you grab the file from the thread, you can probably get them printed locally.
In the USA there are on-line services that do it, but the best place I've found is my local public library. They have a reasonable quality 3d printer and just charge you for the filament (and will let you bring your own filament in if you want to print in something they don't have).
The Meat man
Re: Show your Mule
#1224
Post by The Meat man »
Finally finished the handles for my PD#1 Mule. Ebony wood scales with brass corby bolts, epoxied. It's my first attempt and I'm really pleased how it turned out!
Sanded to 400 grit and finished with boiled linseed oil and paste wax.
- Connor
TomAiello
Re: Show your Mule
#1225
Post by TomAiello »
That looks great, Connor!
How did you find working with the ebony? That stuff always gums up my sandpaper something fierce.
The Meat man
Re: Show your Mule
#1226
TomAiello wrote:
Sat Feb 27, 2021 2:02 pm
Thanks! I had to clean off the spindle sander drum fairly frequently with a rubber sanding eraser, but other than that it worked fine. I used the spindle sander for a lot of the rough shaping, along with a hand-sanding block of 36 grit. The finer grits (120, 220, and 400) I sanded by hand as well.
- Connor
RustyIron
Re: Show your Mule
#1227
Post by RustyIron »
The Meat man wrote:
Sat Feb 27, 2021 1:46 pm
Hey... that's pretty nice. Lovely work.
TomAiello
Re: Show your Mule
#1228
Post by TomAiello »
The spindle sander is definitely one of my most used tools for handles. And the sanding erasers are really useful, especially with woods like ebony (or ironwood!).
Re: Show your Mule
#1229
Both Rusty and Connor have made some very nice wood scales recently, great work fella's!
Xplorer
Re: Show your Mule
#1230
Post by Xplorer »
:eek: Wow that ebony looks great! You did a really nice job on this handle :) . Ebony is one of the few species that is naturally oily enough while also dense enough to make a great knife handle without any stabilizing. Such a great choice IMO.
Well done Sir!!
@ckc_knifemaker on Instagram.
The Meat man
Re: Show your Mule
#1231
RustyIron wrote:
Sat Feb 27, 2021 3:49 pm
Thanks! It was a lot of fun and simpler and easier than I thought. Of course, it helped I was able to use my dad's vast array of woodworking tools. :)
Sat Feb 27, 2021 5:19 pm
Thanks Rick! Now I need to think of sheaths. I have a leather one for this Mule but nothing for the SPY-27. Hoping maybe I can either make or get a Kydex sheath made.
Xplorer wrote:
Sat Feb 27, 2021 6:53 pm
Well done Sir!!
High praise! :o Thank you! It's not perfect but I was surprised how well it turned out. I like dark woods and ebony is one of my favorites. I'm going to try some canvas Micarta for the SPY-27. I think I will use removable bolts for that one, though.
- Connor
izzoyournizzo
Re: Show your Mule
#1232
Beautiful Ebony handle Connor. Something to be proud of. Is it common to epoxy the bolts? Is it that epoxy is put in between the bolts or are the bolts epoxied to the wood?
TomAiello
Re: Show your Mule
#1233
Post by TomAiello »
Corby bolts and epoxy are usually used together. You grind (sand, really) the bolts off, so there is no way to get them out anyway. You basically epoxy the scales to the knife, and then dip the bolts themselves in epoxy and screw them into place. The bolts are great for holding everything in place while the epoxy sets, and the combination makes the handle extremely secure for the long term (basically forever, if you've done it well).
Xplorer
Re: Show your Mule
#1234
Post by Xplorer »
The Meat man wrote:
Sat Feb 27, 2021 7:33 pm
... Now I need to think of sheaths. I have a leather one for this Mule but nothing for the SPY-27. Hoping maybe I can either make or get a Kydex sheath made.
Both leather and kydex sheaths are projects you can handle yourself if you want to. I can walk you through either one if you'd like. If you decide to make one, PM me and I'd be happy to discuss the tools and supplies you'll need for whichever one you prefer.
TomAiello
Re: Show your Mule
#1235
Post by TomAiello »
Be careful. That's how I started this journey, and now I'm on my way to collecting my own vast array of tools... :)
standy99
Re: Show your Mule
#1236
Post by standy99 »
Great job, looks tidy.
Henry_P
Re: Show your Mule
#1237
Post by Henry_P »
Very nice! Great job.
Para 3 Maxamet | Para 3 CruWear DLC | Smock M4 Jade G-10 | Shaman Z-Wear Micarta | Salt 2 LC200N Wharnie | Chaparral Birdseye Maple | Lil’ Native S90V CF | Dragonfly 2 20CV | Ladybug K390 | CRK Small Sebenza 31 S45VN PJ
The Meat man
Re: Show your Mule
#1238
standy99 wrote:
Sun Feb 28, 2021 12:29 am
Henry_P wrote:
Sun Feb 28, 2021 10:28 am
Thank you everyone for the kind words! :)
izzoyournizzo wrote:
Sat Feb 27, 2021 8:53 pm
Thanks! The way I did it was, I spread the epoxy on the flat side of the scales and on both sides of the actual steel tang of the blade. The corby bolts got thoroughly coated with epoxy as I pushed them through the holes and tightened them up. That way every mating surface got coated, plus the bolts got sealed with epoxy in the threads.
I should add that before coating with epoxy I first roughed up the wood and steel surfaces with some 80 grit sandpaper, as instructed on the epoxy package. (Although the steel did not scratch very easily.)
- Connor
The Meat man
Re: Show your Mule
#1239
Xplorer wrote:
Sat Feb 27, 2021 10:36 pm
Thanks for the offer! I will definitely keep it in mind. :)
- Connor
Bemo
Re: Show your Mule
#1240
Post by Bemo »
Awesome job! I was told by a wood worker that with really oily woods that wiping down with acetone first to cut some of that oil creates a better bond with the epoxy. Is that something any of you really knowledgeable handle makers have heard as well?
